| This is a discussion on Segment MPG Calculator within the The File Library forums, part of the Gen II (2004-2009) Toyota Prius Forums category; [attachmentid=6513]Hi I created this little tool for calculating MPG for a segment. This could be useful if you are trying ... |
Friends: 0 | [attachmentid=6513]Hi I created this little tool for calculating MPG for a segment. This could be useful if you are trying out techniques to improve your FE and want to get some quick feedback on how you are doing. Dennis edit to correct instructions on how to use |
| Member Join Date: Jul 2006 Location: Houston, Tx
My Car: 2006 Prius Model: Package: #3 Thanks: 0
Friends: 0 | <div class='quotetop'>QUOTE(maineprius947 @ Feb 8 2007, 12:44 PM) [snapback]387093[/snapback]</div> Quote:
I wish I had known about your calculator this morning. My wife borrowed my car, and if I had the starting mileage, I could see what mileage she got today. | |
Friends: 0 | Glad you like it. Maybe a little log book in the car would work. I use the back pages of my mileage log to keep track of segments from time to time. Recently I made a trip back from a ski trip (downhill 1170 ft over 107 miles) and got about 61.5 MPG. Using my little tool I can see how my mileage has been since then (always returning to same place so no net change in elevation) so far its been about 55 MPG, which is not too bad considering the temp has been averaging 5 F here in Maine. Dennis
__________________ ![]() 83.7 mpg 629 mi best tank 51.4 MPG avg last 12 Tanks 4426 mi 53.8 MPG avg last 24 Tanks 9606 mi 57.8 MPG avg last 48 Tanks 21911 mi MPG data |
| Senior Member Join Date: Mar 2006 Location: Devonport, Tasmania
My Car: 2009 Prius Model: N/A Package: I-Tech Thanks: 3
Friends: 0 | <div class='quotetop'>QUOTE(maineprius947 @ Feb 8 2007, 01:44 PM) [snapback]387093[/snapback]</div> Quote:
Without both resets occurring at the same time the calculations done using your calculating tool will be inaccurate. If people are going to frequently use your tool then they should use the "B" trip meter. Zero the "B" setting when the MPG figure is reset and then take the "Start" and "End" distance figures from the "B" trip reading.
__________________ Australian 09 Gen 3 I-Tech Prius with side strips and rear bumper protector. | |
Friends: 0 | <div class='quotetop'>QUOTE(Orf @ Feb 8 2007, 08:20 PM) [snapback]387196[/snapback]</div> Quote:
Thanks for pointing this out, on my 2004 both the MPG avg and the distance reset when refilling (I think, I always do a manual reset, but I seem to remember when first getting the car and thinking about keeping a lifetime MPG on the display that it could not be done, I think this changed to how you describe in 2005 or 2006.) You are definitely correct that a reset needs to be performed when filling up in order for this segment calculator to work properly and that it is most accurate when used in combination with a trip odometer reset at fillup as well so you have the resolution to tenths of a mile. I will update the tool with this explanation. I am also updating the data to show my best segment from last summer which was a round trip with no net change in elevation avg speed about 30-35 mph over the segment. Dennis | |
| Junior Member Join Date: Feb 2007
Friends: 0 | the trip odometers work off the same system as the speedo and main odo, thus are up to 10% more than the actual distance driven! In my case, the mileage used to calculate the consumption is about 7% less than the one displayed on the odo! that's a big difference, i.e. 50 mpg vs. 47mpg... - Balt |
| 66.7 or 55.4 ? MFD or Calculator? | Prius Maximus | Gen II Prius Main Forum | 27 | 02-05-2008 06:26 PM |
| The Brain behind Netflix-60 Minutes segment | hb06 | Fred's House of Pancakes | 11 | 01-01-2007 03:32 PM |
| 5-Minute Segment With No Bar | NoVaSnow | Gen II Prius Main Forum | 13 | 05-18-2006 02:19 PM |
| Gas Tax Calculator | twenty8moons | Fred's House of Pancakes | 9 | 07-01-2004 03:33 PM |
| Hybrid Segment on CNNfn TV | DaveinOlyWA | Gen II Prius Main Forum | 2 | 04-29-2004 01:21 PM |
