| This is a discussion on Subwoofer Location? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; So I just got my new Kenwood KSC-SW10 Subwoofer and think it'll get installed over the weekend. However, when I ... |
Subwoofer Location?
| Member Join Date: Oct 2006
Friends: 0 | So I just got my new Kenwood KSC-SW10 Subwoofer and think it'll get installed over the weekend. However, when I do get it installed, I'd like input on where to mount it. I've heard of two options that are attractive, both with pluses and minuses:
| Senior Member Join Date: Jan 2008 Location: Altadena
Friends: 0 | Put it under the seat. If it is too much bass, use the wired remote to turn down the gain. Trust me, once you start feeling the bass, you'll be wishing you had more. Subwoofers and bass is about moving air, if it is located in the enclosed compartment, you will not have the air movement you need to feel the bass. You'll end up with more rattle than nice smooth bass. |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 128
Friends: 33 | I'm no expert but I recall being told by an audiophile that the bass speaker should be further away than the other speakers which is why good car sound systems have the bass in the back and hatch backs are preferred. How about in or above the rear left side storage bin? |
Ideally you would want the sub in the rear of the vehicle facing backward bouncing the front waves off the rear wall of the vehicle. There are two waves that eminate from the sub, the front wave, and the rear wave. By bouncing one of the waves off the rear wall, it reinforces the other. If you face it forward, the rear wave cancels some of the front wave. There is a crude diagram about cancellation on the internet somewhere. I can't find it. The Kenwood unit is relatively small so having it under the seat should be fine. I guess there is only one way to find out! Give us a review after you install it. You can always move it.
__________________ Conrad 2008 Silver Touring no wheel covers 2003 Toyota Tundra Limited TRD 2004 Volvo S60R - Gone Missed 2004 BMW 330ci - Gone Missed Last edited by Steamboatsig; 02-07-2008 at 11:07 AM. | |
| Member Join Date: Dec 2007 Location: Silicon Valley
Friends: 0 | I put mine in the wrong place-maybe, rear compartment. I think it sounds great. They do put subs in trunks I think, and they sound great. If you do put it under the seat you can run the wires under the carpet & through the existing hole- I ran my remote control for it to there. I can hear it just fine in the rear compartment but as you know everyone has different taste in sound & music. I think it is a great, little, no hassle unit for sure. (I just did the SW10 a month or so ago). What you might do is wire it up & try moving it around & see if you hear much difference & then locate it in the best spot for your ears. Steve |
Friends: 0 | If you do mount the sub in the compartment in the trunk, how will you get to the spare? You would have to rig some sort of disconnect plug. I thought about mounting my amp in there, but the guys at the installation place were concerned about heat. Thats also when they asked me about a disconnect plug to remove the tray to access the spare. Just a thought. Btw, here is my sub. JL Audio 10"W3's with dual 2 ohm voice coils. I had a larger box loaded with two of these subs, but it was overkill in the Prius. Nevermind that the larger box weighed close to 75 pounds. ![]() ![]() This is where I mounted the EBC (External Bass Controller): Last edited by Steamboatsig; 02-08-2008 at 01:43 AM. |
Friends: 0 | I bet that one sounds great! Steve |
Friends: 33 | |
Friends: 0 | Quote: Nice photoshop job, by the way. Last edited by Steamboatsig; 02-08-2008 at 10:14 AM. | |
| Just another Onionhead Join Date: Mar 2007 Location: Texas
My Car: 2007 Prius Model: Package: #3 Thanks: 5
Friends: 0 | I have mine under the seat. The remote control is mounted in the triangular window area on the driver side, the wire is run under the carpet and up along the A pillar. Easy to reach to make adjustments if necessary. But this is rarely used now that I have the settings just right for just about every kind of music. No need to be concerned about too much bass. Once you have it tuned, it sounds great. The massage effect is a nice bonus. |
| location, subwoofer |
