This is a discussion on MFD issues on '04/'05 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ok, I took the advice of the members here on the board and completely disassembled my MFD unit. The problem ...
LinkBack (18) Thread Tools
Old 10-09-2009, 09:36 PM   #251
xunkn0vvnx
Default Re: MFD issues on '04/'05 Prius
Ok, I took the advice of the members here on the board and completely disassembled my MFD unit. The problem is:
I CAN'T FIND WHAT BOARD PIN 60 IS WHERE THE SOLDERING RE-FLOW NEEDS TO BE DONE.
Please help, I am using Hobbit's instructions and my car is literally in pieces. Which board does the repair need to be done to? I found a number 60 but it looks nothing like the one in Hobbit's pictures. Can somebody please help? Pictures would also be greatly appreciated. Thanks!!
xunkn0vvnx is offline
Old 10-10-2009, 07:00 AM   #252
maseace
Prius enthusiast
maseace's Avatar
It's a small rectangular connector in the middle of the board directly behind the LCD screen (the half that connects to the LCD screen board). The pins are very small and 59 and 60 are at one end of the connector.
My repairs only lasted a few months each time, so I ended up buying a newer used MFD on eBay for a little over $100 (the revised part number that fixed the connector problem).
maseace is offline
Old 10-10-2009, 09:06 AM   #253
northwichita
I followed Hobbit's instructions preceding the 60 pin repair, which were to
A pass with DeOxIt and several plug/unplug cycles seems
to clean all this right up, though, so I wouldn't say
the connectors are outright corroded.
This is for the main connection between the two circuit boards.
I put it back together and has been running fine this last
month.
Intermittent MFD display fixed with cleaning circuit board connection.
If you've already done this step then I just wanted to remind others.
If you don't see a break around that pin 60, perhaps it is somewhere else.
northwichita is offline
Old 10-10-2009, 09:16 PM   #254
xunkn0vvnx
After I took apart the MFD display and literally strained my eyes just trying to find the microscopic pins, I decided to just spray electrical cleaner rather than taking the soldering route. I would rate the soldering job expert and by no means a novice leveled task. I would be much more comfortable having the board worked on by somebody who has experience with this issue and not just a random electronics shop.
I reassembled everything and so far so good, the electrical cleaner did the trick. As for how long it will last, only time will tell.
Old 10-11-2009, 01:16 PM   #255
jayman
I'm wondering if the *real* reason why the combi meter display (The speedo, fuel gauge, PRND display, etc) fails is due to corrosion on one of the 4 connectors?
Folks have had the combi meter replaced, and naturally everything worked. I wonder if just disconnecting and reseating the connectors would have done the same thing?
I've had enough experience with that problem working on military electronics, especially communications gear, and industrial sensors in harsh chemical environments
jayman is offline
Old 10-13-2009, 09:47 AM   #256
xunkn0vvnx
UPDATE: I cleaned the connectors and the problem returned today. But what is interesting is that the problem only exists upon startup and only lasts for 30 seconds or so.
Old 10-13-2009, 10:59 AM   #257
artie
Sorry to hear that, I guess the connections will need soldering and good luck to "permanently" cure the problem.
artie is offline
Old 10-18-2009, 03:53 PM   #258
ButchDeal
Just had the problem on my '04 but with 157k miles I didn't think I would get any place at the dealer so I used Hobbits instructions to take it on. Dash disassemble was not too bad at all (done some of this before for lockpicks).
I used my camera to take this close up shot were you can clearly the the cracks. I made a fine point solder iron with a wire like Hobbit suggested and re-wetted all the points on this side. Worked perfectly.
ButchDeal is offline
Old 10-18-2009, 09:03 PM   #259
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
<edit> I need to learn to read peoples posts properly. What I have written below relates to the MFD not the combi-meter or upper display. Oops!<end edit>
I'm wondering if the reason people have had limited success with disassembly, clean and reassemble is because they are closing the gap in the cracked solder when reassembling? I suspect this to be the case. There is no doubt that the solder connection cracks. No point looking with the naked eye and no point running to the shop to buy your first ever soldering iron to repair this. If you have never done fine soldering before, a $1000+ part is not where you should be learning this skill. A tech skilled in repair of small circuit boards like those in laptop and PDAs will have the skill to do the repair. I saw mine under a microscope and the repair was beautiful. If your repairer does not have a microscope chances are he cant handle the repair. However just because he does have one doesn't mean he can though. I know a very crap mechanic with a full Snap-On tool kit!
Also be mindful of reassembling the MFD without putting any twisting loads on those plugs.
I'd wish everyone luck with this but it isn't luck you need, just a skilled technician.
Click the image to open in full size. All the warranty I need.
2004 silver base model Prius
patsparks is online now
Old 10-19-2009, 05:48 PM   #260
jayman
In the case of the MFD, we know there is an issue with poor factory soldering. With the combi meter, we really don't know yet
jayman is offline
ཀ or ཁ, issues, mfd, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/33923-mfd-issues-04-05-prius.html
Touchscreen problems This thread Refback 09-30-2009 08:52 AM
Mi Toyota Prius - Averķa en el DISPLAY - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 07-16-2009 06:58 PM
Datsun Z 240Z Parts, 240Z Triple Carbs, Best Carburator For 240Z - Thorogoodboots This thread Refback 03-14-2009 09:24 AM
Motor Swap Honda Civic, Jdm Honda Civic Si, Honda Civic Type S - Justtires This thread Refback 03-14-2009 05:59 AM
Toyota Of Lompoc, Toyota Of Greer, Toyota Mini Motorhome - Kias This thread Refback 03-09-2009 08:16 AM
Nissan 300Zx Timing, Nissan 300Zx Or Datsun 240Z Ownership, Nissan 300Zx V8 - Husabergparts This thread Refback 03-08-2009 06:28 AM
Prius MFD This thread Refback 02-01-2009 12:39 PM
CanadianDriver Green Reviews Used Vehicle Review: Toyota Prius, 2004 - 2008 This thread Refback 01-29-2009 01:23 AM
The display panel on our 2004 Toyota Prius doesn&#039;t work? - Yahoo! Answers This thread Refback 12-23-2008 06:09 PM
The display panel on our 2004 Toyota Prius doesn&#039;t work? - Yahoo! Answers This thread Refback 11-23-2008 12:15 AM
The display panel on our 2004 Toyota Prius doesn&#039;t work? - Yahoo! Answers This thread Refback 11-23-2008 12:01 AM
Re: Artie's Prius Problems!! - The Mainstreamers This thread Refback 06-01-2008 06:28 PM
Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-18-2008 10:44 PM
Prius MFD This thread Refback 05-07-2008 04:38 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-05-2008 08:58 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 04-23-2008 04:14 AM
Prius MFD This thread Refback 04-08-2008 12:55 PM
Lights failed on me today - GreenHybrid - Hybrid Cars This thread Refback 03-07-2008 08:30 AM
Prius Phonebook Issues Tadashi Gen II Prius Audio and Electronics 24 03-18-2009 09:34 PM
Maintenance issues with 1st generation Prius? paulccullen Gen II Prius Care, Maintenance and Troubleshooting 5 11-06-2007 06:06 PM
New Prius' Paneling Alignment Issues Ryn01599 Gen II Prius Main Forum 4 07-20-2006 06:36 PM
Al Gore on his Prius & earth issues Danny Prius and Hybrid News 62 06-25-2006 07:33 AM
Only 3% of Prius Owners have maintenance issues Danny Prius and Hybrid News 8 10-30-2005 10:32 AM
