| This is a discussion on Creaking sound from rear suspension on 06 within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hey guys, Wondering if anyone else has experienced this or may have an idea for a solution... I've already asked ... |
| Senior Member Join Date: Nov 2005 Location: Mississauga, Ontario, Canada
My Car: 2006 Prius Model: Package: C Thanks: 0
Friends: 0 | Hey guys, Wondering if anyone else has experienced this or may have an idea for a solution... I've already asked the dealership on two occasions (before warranty expired) to investigate and they "don't hear anything". Anyway, I am getting this irritating creaking sound coming from the rear of the car, for about a year now. It started as a small creak when the car was rocked, such as when you put the shifter in Park on an incline and release the brake. It has gradually grown more consistent, often simply sitting in the car makes a creak, or driving low speed with a window open. Driving in a parking garage is much worse, with the echo. Of course, it's particularly irritating (embarrassing) with a hybrid, since that is all you hear when rolling at low speed! The car currently has 95K KM (~60K miles), but this has been ongoing since about 50K KM. Suspension otherwise seems fine, it's just an irritating noise that sounds like some joint needs lubrication. I plan to have a different dealer/garage have a look at it next time I get my oil changed, which will be very soon.... Has anyone else experienced this or have any suggestions? |
| Member Join Date: Nov 2007 Location: brisbane australia
Friends: 0 | lol i too am getting this sound, clunking sound, but on my front left wheel when i go over big bumps, i dont have a prius though, a petrol honda civic sedan |
Friends: 0 | This is simple. Does it make noise when you push up & down on the back of the car? If yes: Bad shocks. If no: Is it making noise when you cruise through the garage? If yes: Its not the suspension. Suspension does not make noise going down the road unless its being used as in turns bumps etc OR unless its really really corroded under there and the slightest movement makes it creak. Whats it look like under there? I think its the drum brakes. BTW, I believe the drums use the standard tensioners found in most cars. They are adjusted & tension by backing up and applying the brakes. There's not much going on back there. 2 shocks...brakes... 2 hubs spinning. BTW, this car requires the hold down springs replaced in the drums when the rear shoes are replaced as over time they heat up and lose tension and then a shoe starts dragging which I suspect is whats happening. If able jack up rear of the car and spin a rear wheel by hand with the brake off. See what it sounds like. Also with the wheel still on & off the ground shove a long 2x4 board under the bottom of the wheel there and pry up & down using a block like a seesaw on the wheel quickly actuating the suspension. Up & down real quick. You'll find it. Is someone who drives this car a 2 footed driver? Always riding the brake? You might just need a brake job all around. How do the front pads look? BTW, I periodically get under the whole car and spray down the entire suspension and all moving parts with spray grease. Not crazy just moving parts. Everywhere there's a joint or seal or a moving part. Except by the front brake pad area. I also spray silicon on the CV joint rubber boots too. Lose a boot and you lose a CV joint. It really helps cut down on corrosion under there. A greasy part will protect against water/rust. Plus you get a look at the bottom of the car. Look carefully for any leaks or corrosion.Or damaged /bent metal up front near skid plate. Cause Wife drives it sometimes too........Don't ask. Last edited by edthefox5; 08-05-2008 at 10:46 AM. |
Friends: 0 | Oh I forgot. Parking brake alignment spec's: 2001-2003-------5 to 8 clicks to engage 2004-and later---6 to 9 clicks to engage Check that because if the parking brake is mis-adjusted it might cause a shoe to drag when released. |
| Senior Member Join Date: Mar 2008 Location: San Diego, CA
Friends: 10 | I have this creaking noise also. Mine is a 2008, with 6200 miles. Everytime i park in my driveway and get out i hear it, and everytime i get back in i hear it. It seems to only do it when on an angle. |
Friends: 44 | Quote:
If not, then try engaging the parking brake with your full weight (depress the parking brake pedal as hard as you can), and see if you hear the noise. If not, then perhaps the problem is that the parking brake was engaged partially, so that it could slip as weight shifts around. | |
Friends: 10 | Quote:
| Junior Member Join Date: Feb 2008
My Car: 2008 Prius Model: Package: #4 Thanks: 0
Friends: 0 | I have this creaking noise also. Mine is a 2008, with 6200 miles. Everytime i park in my driveway and get out i hear it, and everytime i get back in i hear it. It seems to only do it when on an angle. Ditto 2008,7500 miles I have never used parking brake. It makes that noise when I come to a complete stop in garage or when I brake on an incline. it lasts for 2 secs max. I was wondering if toyota is using inferior shocks since I had this issue from day one. |
First, thanks for the detailed reply, it is much appreciated! How you explain it, I have a feeling you are probably right on the money. First, my wife doesn't drive, I am the only driver, and I do NOT drive with two feet nor am I heavy-footed (driving a Prius and all The sound is definitely very present as I "cruise" in the garage, and that is in fact when it is most noticeable. Sometimes sitting in the car or getting out will make a small creak as well (thus the reasoning for thinking it was suspension-related), but your brake shoe explanation seems to make more sense. The car currently has 97K KM on it, I had the brakes cleaned once by the dealer in January at 72K. The noise started before that, but has become more pronounced in recent months. I do have a jack and will try lifting the car up as suggested, and will report back on the results... Thanks again. | |
Friends: 0 | Your very welcome. Noises in my car drive me nuts too. Post on results. |
| creaking, rear, sound, suspension |
| Adjustable rear air suspension system | mrbigh | Gen II Prius Modifications | 14 | 06-14-2009 06:30 PM |
| LOUD creaking sound | bredekamp | Gen II Prius Main Forum | 2 | 10-22-2007 01:30 AM |
| Sound from the rear vent | seeh2o | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 02-16-2007 10:04 PM |
| Do you think the Prius rear suspension is too low? | silentak1 | Gen II Prius Main Forum | 8 | 12-05-2006 02:42 AM |
| Rear Suspension | Tideland Prius | Gen II Prius Main Forum | 3 | 12-19-2004 11:22 PM |
