| This is a discussion on How to replace driver's mirror? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi there, My beloved 2006 Prius suffered its first real damage last week when some creep knocked my driver's side ... |
| Junior Member Join Date: Feb 2009 Location: Midwest
My Car: 2006 Prius Model: Package: Base Thanks: 0
Friends: 0 | Hi there, My beloved 2006 Prius suffered its first real damage last week when some creep knocked my driver's side mirror clean off, then kept going. The dealer wants $400 to put a new one on. Two questions: Most of the online replacement mirrors are running 70 0r 80 bucks. But there's one from a company called Kool-Vue that's $37, for the heated power unit, complete. Has anyone had experience with this company? 2 - How do you remove and replace the old mirror? (The bottom of the stalk and the panel that fits into the door are still intact from the old one.) I have the standard audio package with the little speaker inside the door right where I would expect to find the mirror screws. |
| Junior Member Join Date: May 2006
Friends: 0 | I also need a passenger side replacement. I'll be interested in hearing anyone's experience with Kool Vue. |
Friends: 60 | I'd like to encourage both of you to use recycled parts, i.e., go to the junk yard. The mirror comes off fairly easily after you pull the little speaker straight out from where it's clipped onto the inside of the door. As I recall there are three 10mm nuts that hold the exterior mirror assembly to the door, but the illustration shows one nut (2). You can also look for the painted cover (4) to match your car's color; those just pop right off with a good yank, might need your fingernails. ![]() If you want to buy new, Discount Toyota Parts wants about $173.
__________________ Bill Bill.Merchant@PortlandHSD.info 2007 NL 5 Silver Wraith • 2005 BC 6 Silver Cloud Portland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com > < Follow me on |
| "Taxi"! Join Date: Aug 2008 Location: Ireland
My Car: 2006 Prius Model: Package: Base Thanks: 1
Friends: 0 | Thanks for the tip, Bill. As it turned out, a friend with a 2006 Prius had a mirror that was slightly damaged, which he replaced, being a rather fastidious fellow. He gave me his old mirror for nothing. A little spray paint on the mirror cover, some silicone to seal the crack that prompted the replacement, and I am back on the road. Your instructions for removing the mirror were spot-on! |
Friends: 12 | I had a similar problem with an early 90's Honda Civic some creep knocked off the passenger side mirror. I got a cheap replacement but the color didn't quite match. Good enough for me though |
| Junior Member Join Date: Apr 2009 Location: La Jolla, CA
Friends: 0 | [QUOTE=Bill Merchant;806602]I'd like to encourage both of you to use recycled parts, i.e., go to the junk yard. The mirror comes off fairly easily after you pull the little speaker straight out from where it's clipped onto the inside of the door. As I recall there are three 10mm nuts that hold the exterior mirror assembly to the door, but the illustration shows one nut (2). You can also look for the painted cover (4) to match your car's color; those just pop right off with a good yank, might need your fingernails. BILL - Have the same problem, but my replacement mirror assembly has a long lead, and the lead on the existing goes all the way into the door housing. Any tips on removing and replacing the interior door panel? |
Friends: 44 | See attached. |
Friends: 0 | These instructions were missing an important point for the 2007 Prius. In step 2, there is a snap-in plate under the door lever, and a screw behind it, that you have to remove first. This plate is inside the pocket in the bezel described in step 2. You'll see a groove in there, so stick your taped screwdriver in the groove and it pops of easily. Then unscrew the screw, THEN follow the instructions for #2 and all the rest. Also the screw mentioned later when popping off the entire door panel is not present in 2007. |
| driver's, mirror, replace |
| Your Height and the Driver's Seat | loyalty4life | Gen II Prius Main Forum | 78 | 12-30-2008 12:14 PM |
| WTB 2008 driver's side mirror - Any Color | dluks | Private Sales | 0 | 10-28-2008 01:38 AM |
| Driver's test -- who knew? | GreenIsGood | Gen II Prius Main Forum | 19 | 02-01-2008 02:40 PM |
| Distorted driver's sideview mirror | 8AA | Gen II Prius Main Forum | 8 | 11-15-2004 10:07 PM |
| How to Replace Passenger Side Mirror? | wkoteras | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 10-04-2004 12:52 PM |
< Follow me on
