This is a discussion on Multi-display/Cable Problem, Error Code B1248 - HELP! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Short Problem Description: Today the Multi-display in my 2005 Prius went haywire. I have a couple of after market plug ...
LinkBack (1) Thread Tools
Old 07-24-2009, 08:22 PM   1 links from elsewhere to this Post. Click to view. #1
gordonsta
Question Multi-display/Cable Problem, Error Code B1248 - HELP!
Today the Multi-display in my 2005 Prius went haywire. I have a couple of after market plug ins, but they have worked flawlessly since their installation over two years ago. I took it to the dealer and they came up with error Code B1248 - "AVC LAN Communication Impossible".
Detailed background:
Shortly after purchasing my 2005 Prius I added two aftermarket modules to the Multi-display. The first is the DICE iPod and the second is the Lockpick that unblocks video and audio inputs. The car has performed flawlessly since their install a number of years ago. Today I drove to a destination and parked the car for about 30 minutes. When I started the car I noticed that the Multi-display was not acting properly. I took it to the dealer and they reported that the initial tests showed an error code of B1248. They want $380 to tear into the dash and troubleshoot further. I picked up the car and brought it home. I removed the Lockpick plug-in but the symptoms were the same.
Last thoughts:
Wiring harnesses rarely just fail. Tomorrow I'm going to dig into the DICE iPod plug-in to see if possibly something there has worked loose. I would appreciate any other thoughts about what might have happened.
gordonsta is offline
Old 07-25-2009, 12:09 AM   #2
vertex
Default Re: Multi-display/Cable Problem, Error Code B1248 - HELP!
Last thoughts:
There are only two connections between the Gateway ECU and the MFD that can cause this problem, or the MFD is has no power. I don't know how these mods are installed. If you need the service manual pages, if you give me your email, I can email you the section.
vertex is offline
The Following User Says Thank You to vertex For This Useful Post:
gordonsta (07-25-2009)
Old 07-25-2009, 12:10 AM   #3
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
I think its likely that something in the Dice failed. Aftermarket electronics are rarely built to the same standards as OEM. However, there is a documented issue with the MultiDisplay in some 2004 and 2005 cars due to a design error.
Prius MFD
dogfriend is offline
The Following User Says Thank You to dogfriend For This Useful Post:
Old 07-25-2009, 04:34 PM   #4
gordonsta
Thumbs up Re: Multi-display/Cable Problem, Error Code B1248 - HELP!
Woo-hoo!!! Success!!! This morning I opened up the dash, unplugged the DICE iPod plug-in, powered on the car and the MFD started working properly.
Then I decided to go for broke. I powered down the car, replugged the DICE and powered on the car. Everything was still working. After powering down again, I unplugged the DICE, squirted a bit WD-40 on the contacts before reassembling everything and buttoning the dash back up. I tested it once again and everything was still good.
My last act was to reinstall the Lockpick plug-in. Everything is still working fine. Thank God for small miracles
b1248, code, error, multidisplay or cable, problem
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/65934-multi-display-cable-problem-error-code-b1248-help.html
Multi-display/Cable Problem, Error Code B1248 - HELP! - PriusChat Forums This thread Refback 07-24-2009 09:26 PM
multi/Nav display jone54 Gen II Prius Care, Maintenance and Troubleshooting 3 01-28-2009 10:30 AM
I've got an error code... fish_antlers Gen II Prius Technical Discussion 3 12-11-2007 10:22 PM
Error Code Question nyconrad Gen II Prius Technical Discussion 2 11-08-2007 10:32 PM
Need to see Error Code on my 05 Prius hilore Gen II Prius Care, Maintenance and Troubleshooting 6 05-23-2006 11:14 PM
P1121 Error code? GaryK Gen II Prius Care, Maintenance and Troubleshooting 2 09-05-2004 01:36 PM
