This is a discussion on Engine oil drain plug gasket stuck on oil pan, help!!! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Changing oil first time. Gasket stuck on oil pan. Tried finger nails to pry and flat blade screw driver to ...
Old 10-08-2009, 05:05 PM   #1
2009Prius
2009Prius's Avatar
Friends: 19
Question Engine oil drain plug gasket stuck on oil pan, help!!!
Changing oil first time. Gasket stuck on oil pan. Tried finger nails to pry and flat blade screw driver to push on the gasket. Won't come off. (Don't want to damage the oil pan surface where the gasket sits either) Please help!
2009Prius is offline
Old 10-08-2009, 05:58 PM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: Engine oil drain plug gasket stuck on oil pan, help!!!
This will happen from time to time. What I do is to use a flat-blade screwdriver and a small hammer. Place the blade of the screwdriver on an edge of the gasket. Lightly tap the handle end of the screwdriver with the hammer, and the gasket will pop off.
It is good that you noticed the gasket was stuck. A less careful person would leave the old gasket on and then replace the drain plug along with a new gasket. This would probably result in a leak.
Patrick Wong is offline
The Following User Says Thank You to Patrick Wong For This Useful Post:
2009Prius (10-08-2009)
Old 10-08-2009, 08:30 PM   #3
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
putty knife may have a thinner tip
tochatihu is offline
The Following User Says Thank You to tochatihu For This Useful Post:
Old 10-08-2009, 08:43 PM   #4
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
Straight edge razor blade is my tool of choice for this.
dogfriend is offline
The Following User Says Thank You to dogfriend For This Useful Post:
Old 10-08-2009, 09:04 PM   #5
philobeddoe
ΜΟΛΩΝ ΛΑΒΕ
philobeddoe's Avatar
Friends: 6
i got a sweet kershaw that does the trick ...
where are you ... maybe another member can swing by and lend a hand?
+1 on Patrick Wong's post
many may not have noticed, resulting in a hassle
philobeddoe is offline
The Following User Says Thank You to philobeddoe For This Useful Post:
Old 10-08-2009, 10:16 PM   #6
2009Prius
2009Prius's Avatar
Friends: 19
Question Re: Engine oil drain plug gasket stuck on oil pan, help!!!
Thank you! It worked! I also wrapped a piece of plastic around the tip of the blade to avoid scratching the sealing surface of the oil pan.
Some other questions:
What if the gasket stuck on the plug?
Is it necessary to run the engine right away after the oil change or is it OK to wait until the next morning?
Thanks!
Old 10-08-2009, 10:33 PM   #7
philobeddoe
ΜΟΛΩΝ ΛΑΒΕ
Friends: 6
Thanks!
it's ok to wait until the next morning
i like to run it right away, let it warm up
check for leaks, pressure, etc.
then let it settle back in and check the levels
better to do it now ... than find out you have problem in the morning
Old 10-09-2009, 01:22 AM   #8
dogfriend
dogfriend's Avatar
Friends: 11
Agree, you can wait if you want. But don't forget to check one more time after it runs for a little while.
2009Prius (10-09-2009)
Old 10-09-2009, 02:07 AM   #9
uart
uart's Avatar
It really is better to run the motor straight after an oil change. The reason is that it usually takes a just a little bit longer for the oil to start to circulate the very first time you run it after the change (and even more so if the filter was also changed). So it's best to start it up straight away while it's still a little warm and while there's more chance of having some old oil still clinging to surfaces. There's just less friction and better lubrication if you do it straight away.
When I change oil (on a regular car) I like to :
1. Run the motor for a about 5 minutes to circulate the oil and warm the motor (but not so the oil is hot enough to burn you, I let it cool for about 10min if motor was at full operating temperature).
2. Change the oil.
3. Immediately start the motor and idle for about 1/2 to 1 minute.
4. Let it sit for 10 to 15 minutes and then recheck the oil level and add if necessary.
I haven't changed to oil on the Prius yet but I think I'd still follow the same procedure, except that I'd need to drive it to get the ICE running rather than just idling.
uart is offline
The Following User Says Thank You to uart For This Useful Post:
Old 10-09-2009, 02:54 AM   #10
sambojoho
Dittohead
Package: #8
2. Change the oil.
Nah, don't need to drive it to get the engine running. Just turn car on, and press down on the accelerator with the car in park. The engine will fire up and run for as long as you hold down the pedal. At least that's how it works on my 06!
sambojoho is offline
The Following User Says Thank You to sambojoho For This Useful Post:
drain, engine, gasket, oil, pan, plug, stuck
New Type Oil Drain Plug Gasket/Part Number? dorf Gen II Prius Care, Maintenance and Troubleshooting 1 06-18-2009 08:34 PM
Oil drain plug gasket (washer) question rudiger Gen II Prius Care, Maintenance and Troubleshooting 4 11-03-2007 10:47 AM
missing drain plug gasket ACORNBLUES Gen II Prius Care, Maintenance and Troubleshooting 13 09-26-2007 06:09 PM
Gasket for Oil drain plug dzitlow Gen II Prius Care, Maintenance and Troubleshooting 19 02-27-2005 01:49 PM
Oil Drain Plug Gasket berryman Gen II Prius Care, Maintenance and Troubleshooting 1 11-06-2004 06:26 PM
