This is a discussion on 2007 prius trunk hatch release rubber piece melted within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, When I try to open the trunk, the rubber piece that you touch in order to open the trunk ...
Old 11-04-2009, 03:19 PM   #1
wshpoon
Package: Navigation
Exclamation 2007 prius trunk hatch release rubber piece melted
Hi,
When I try to open the trunk, the rubber piece that you touch in order to open the trunk seem to have melted. My fingers turn black every time I try to open the trunk. Does anyone know what that rubber piece is called or the part number so that I can replace it? The dealer wants to charge me around $200 to do it, but I'd rather save the money and do it myself.
Has anyone else experienced that or is it the hot Florida weather that's the culprit?
TIA
-Wazir
wshpoon is offline
Old 11-04-2009, 04:08 PM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: 2007 prius trunk hatch release rubber piece melted
This is a new one. The switch costs $71 plus shipping at Champion Toyota, Houston:
Champion ToyotaWorld
$200 at the dealer is not bad considering MSRP for the switch is $94. Good luck.
Patrick Wong is offline
Old 11-05-2009, 10:12 AM   #3
richard schumacher
Destination: Eschaton
That is odd. Has it ever been exposed to some harsh chemical?
richard schumacher is offline
Old 11-06-2009, 08:34 PM   #4
alanh
Yeah -- it gets to 115F here, and mine hasn't melted. I'd suspect the chemical contamination.
alanh is offline
Old 11-11-2009, 11:04 AM   #5
epithumia
Mine has melted as well; it does get hot here in Houston, and I can't think of how it could have been chemically contaminated unless I drove through something that had no visible effect on the rest of the car. We don't even use it all that often.
The dealer wants $317 to replace it, which is somewhat hilarious. I believe this is a defect issue and am going to at least try to get them to fix it under the overly expensive warranty I was dumb enough to buy.
Also found out today that the stock tires need replacement after only 38K miles. Not really happy about that either.
epithumia is offline
Old 11-11-2009, 02:12 PM   #6
richard schumacher
The very air in Houston is chemically contaminated :_> At least you'll get some value out of the extended warranty.
Judging from reports here most people get less than 38K from the stock tires.
Old 11-12-2009, 01:05 AM   #7
edthefox5
edthefox5's Avatar
Originally Posted by wshpoon View Post
Hi,
TIA
-Wazir
Yup...... Tampa here and my 07's melted too. Hadn't opened the trunk for a few months and first time it felt like grabbing on to a candy bar. It sure got hot here last summer didn't it? Brutal.
Please post and let us know how the replacement went. Thanks.
edthefox5 is offline
Old 11-12-2009, 01:48 AM   #8
bedrock8x
My Car: Other Hybrid
One of my solution to melting plastic/rubber is to cut a piece packaging tape about the same size and tape over it.
bedrock8x is offline
black ink, hatch, melted, trunk
interior hatch release sciguy125 Gen III 2010 Prius Accessories and Modifications 8 10-06-2009 03:32 PM
Interior Hatch release? hobba Gen II Prius Main Forum 11 12-08-2008 09:00 PM
Manual trunk release? derkraut Gen II Prius Main Forum 22 11-14-2006 11:03 PM
Trunk won't release 2005 prius saechaka Gen II Prius Care, Maintenance and Troubleshooting 0 12-12-2004 02:51 PM
Rubber/Plastic Cargo Mat for the Trunk Jeff Gen II Prius Main Forum 6 03-22-2004 03:19 PM
