| This is a discussion on BIG swing in mpg's on consecutive tanks - ??? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just had my first 50+ (53.1) tank and the next one is perplexing. The display said 53.9. I ended ... |
| Member Join Date: Feb 2007
My Car: 2004 Prius Model: Package: #8 Thanks: 0
Friends: 0 | I just had my first 50+ (53.1) tank and the next one is perplexing. The display said 53.9. I ended up putting 9.9 gallons in for 474 miles accumulated. What the...? My only possible explanation is the refueling procedure. I generally let the pump click off on it's own when I fuel up. This last tank filled up pretty slow while I recall the previous one filled up rapidly. Could this have created a bit of a volume gap that threw off the actual level? For the record, I did not change my driving habits or areas. In fact, I am really getting the hang of P&G. What really puzzled me was the difference in display versus actual mpg. Could there be a difference in ethanol blended gas? Any input is appreciated. |
Friends: 23 | If the display says that you went from 53.1 to 53.9 then there's a very good chance you improved your mileage by 0.8 mpg. Search the forums for "guess gauge" "gauge" "bladder" and so on. You will see that there are many posts on the topic. You can fight it all you want but the end result is that you can not treat the Prius gas tank the same as other cars. Refuel and forget about it. |
| Canonus Curiosus Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 150
Friends: 18 | Welcome to one of the great anomalies of the Prius. Also, you get an award for asking perhaps the most common question posed by the new owner. The short answer is that you'll see this because of the rubber bladder than lines the gas tank. The bladder will change sizes and you will not get the same amount into the tank each time. The MFD (the multifunction display -- the screen) provides a much better indication of your actual mileage. Here are some threads to read to get fuller explanations:Hope this helps!
__________________ Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles. Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09) Lifetime City Mileage: . . . . . . . 57.7 MPG Lifetime Highway Mileage: . . .56.8 MPG Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG |
| Old Bald Guy Join Date: Aug 2008 Location: Ft. Worth, TX
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 1 | Quote:
Over the past 40 + years, I have learned that no 2 pumps shut off automatically the same. The cut off is controlled by an air pressure sensor in the nozzle ... and even with the same nozzle ... the cut off can change during the day as temperature changes. I ALWAYS set the nozzle at its slowest speed ... slow gives me a more reliable fill than fast ... which can trigger the cut off sensor too soon. I never worry about miles per tank ... there is no such measure ... for 4 decades I have measured miles per gallon ... which is a standard of measure that NEVER changes. One thing I have observed with my Prius ... because it is capable of high mileage numbers, is that mpg seems to be very much tied to temperature ... and in turn, the temperature of the battery pack. When my car sets out in the sun on a 100+ degree day ... and gets really hot ... my mileage drops to about 45 mpg. On a cool run, after being garaged overnight at 75 degrees, my mileage is more like 55 mpg. I have read as high as 58 mpg driving to work at the Dallas/Ft Worth international airport ... driving in the Dallas metro ... on such cooler days. My lifetime mileage is just above 50 mpg ... over 8000 miles ... which includes Dallas metro in town and 70-80 mph trips on the interstate. | |
Friends: 0 | Thanks for the input guys. I'll check out the links provided, but it just didn't make sense to me as I too try to figure out milage by dividing the miles and the gallons, and this one didn't come close. Thanks again. Edit: It came to me out of the blue. I understand now with the properties of the bladder coming into play. Last edited by nfschlaack; 09-04-2008 at 07:53 PM. |
| Senior Member Join Date: Sep 2007 Location: Charlotte, NC
My Car: 2006 Prius Model: Package: #7 Thanks: 10
Friends: 0 | I hate to burst all the my fellow Prius owner's bubble out there but this phenomenon isn't exclusive to the Prius and the "fuel bladder". That is unless my 1999 Corolla LE and 2002 Corolla CE also contained "bladders". I drive a ton for business and have done so since 1996. My 2006 Prius has over 126,000 miles already and both the Corolla's had over 100,000 when I got rid of them. Many of these drives are two and from the same customer on the same roads here in the south. As a result I have had the oppurtunity to make almost the same exact trip, minus minor "pit stops" for bathroom/food/etc..., on more than one occasion in all 3 vehicles on consecutive tanks of gas. I too have noticed the "1 high MPG" then "1 low MPG" tank on all three vehicles. To be high/low I would consider a difference of greater than 6 MPG. The first response will be well you filled up at different gas stations with different pumps. Nope, wrong. Not always but again more than once on all 3 vehicles on more than one occasion I filled up at the EXACT same station often with the EXACT same pump, cars are creatures of habit, LOL. It drove me NUTS!!!!! Finally I decided to stop trying to figure it out, which as an engineer admits defeat, LOL. Honestly though I have spoken with dealerships, other engineers, NASCAR engine builders, etc... no one has a "good" answer for it. They have given the obvious "road conditions", "head winds", "tail winds", "driving habits", "drafting" (yeah that one came from certain team member here in Mooresville), "gas differences", "air filter", "dirty EFI", "tire pressure", etc... Yeah yeah yeah all those things could have a small affect on MPG but not the large difference I was seeing. And obviously not consistently from 1 tank to the next as it was and very repeatable. So, I gave up and would recommend you do the same for sanities sake and just love that fact that your Prius gets such good gas mileage It is almost as if the cars had a "reserve", for those of you that ride off road motorcycles. And the car was like "Ok, let's screw with him and use the reserve tank this trip but not the next." See the depths to which I have contemplated this issue, it annoys me. On that note I must end this before the men in the white coats come. Just my rambling $0.02. |
Friends: 10 | Quote:
The Prius fuel bladder just adds one more large variable into the mix. The problem isn't unique to the Prius, just exaggerated. Tom | |
My Car: 2005 Prius Model: Package: #4 Thanks: 6
Friends: 4 | Quote:
Rob | |
| Senior Member Join Date: May 2008 Location: Philadelphia
My Car: 2010 Prius Model: IV Package: No Package Thanks: 3
Friends: 0 | So far my tanks have been (off the top of my head, should be close to accurate): 52.7 51.0 48.5 53.0 First tank was from the dealer. Next two tanks from Hess. Current tank (still on the rise) from BP or Shell. I forget. All I know is I didn't see any ethanol signs.ß |
| consecutive, mpg's, swing, tanks |
| Tryin' to swing a Prius for my momma in Pburgh... | katieoh | Newbie Forum | 21 | 06-12-2008 08:33 PM |
| Our fuel tanks in Australia | fgray30 | International Owners | 18 | 08-01-2006 10:42 PM |
| Bad case of mood swing & unplanned spending | Speedracer | Gen II Prius Modifications | 61 | 08-09-2005 02:44 PM |
| 500 + Miles Per Tank - 4 tanks in a row | Rick Grahn | Gen II Prius Fuel Economy | 31 | 05-25-2005 11:38 AM |
