| This is a discussion on 2502 Miles 299MPG in a Prius II PHEV! within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Yes a PHEV does work and it works very well despite what fleets or car reviewers say! I just filled ... |
#1 |
My Car: 2006 Prius Model: Package: #7 Thanks: 2
Friends: 22 | Yes a PHEV does work and it works very well despite what fleets or car reviewers say! I just filled up today with 2501.7 Miles and 299.43MPG on one tank of gas and I still had gas left over for 500+ more miles. This tank started on March 28th 2009 and ended today July 14th 2009. It ended because I'm heading up to Hybridfest and I wanted to start with a fresh tank. This tank was mostly my commute to work and back. About a month ago I moved into a new house which my commute distance did not change much but I gained much better low speed near level roads. With these new conditions I believe I can achieve 4k even 5k miles now on one tank of gas. My new routine is as follows. I start out on 35mph roads in EV mode. I take a back road which is 25mph to the highway. Once I get on the on ramp I exit out of EV mode to let the engine warm up though S1. By the time I get through S1 I enter into the city and go into EV mode all the way to work. On my way home I do the opposite. I EV all the way to the highway. Once I enter the 55mph zone I go through S1 and by the time I get off the exit to the 35mph roads I can get into EV mode. Then its EV all the way home. According to my ScanGauge this totals out to about 400-500MPG per trip. So here is the data you have been waiting for. Distance: 2501.7 miles Calculated MPG: 299.43MPG Gallons gas used: 8.355 @ $2.599 Watt hours used: 439556.7 @ 8 cents per kWh Watt hours per mile: 175.7 Total tank cost: $56.88 Cents per mile: 2.3 Here are some pictures. Mileage ![]() MFD reading ![]() 27% gas remaining. ![]() ScanGauge reporting not very accurate. ![]() Since I had to reset my CAN-View here is the last 323 miles. The CV tops out at 255MPG so I set it over to L/100km to get a better reading. The CV is worse than the SG reading. There is so little fuel used its hard to get accurate numbers.
Friends: 12 | Jay, congrats, you have the needs a PHEV is best suited for. When you get to hybridfest I'll buy you a bottle of Sta-Bil. Wayne |
| Senior Member Join Date: May 2008
Friends: 2 | Wow! |
Friends: 22 | |
Friends: 23 | Jay, roomie, I'll buy you some Smirnoff on the rocks if you promise to not make fun of me when I order flavored Smirnoff on the rocks. I prefer Stoli Raz but will make concessions for company. And CONGRATS on the steller tank. I did some quick math of my own and here's what I got: 2502 miles at 60mpg = 41.7 gallons. At $2.75, that's $114.675. You spent $56.88 in gas and electricity, saving $57.80 and 33.35 gallons of gas. |
| The Following User Says Thank You to TonyPSchaefer For This Useful Post: | gkremyr (09-07-2009) |
Friends: 22 | Quote:
Dont make fun of me either because I like the flavored stuff too. | |
| Priusite Join Date: Jul 2009 Location: Miami, Florida
My Car: 2010 Prius Model: III Package: No Package Thanks: 140
Friends: 4 | Awsome results! Which PHEV conversion did you install? How far do you go on each stretch? I.e 35mph for x miles, 25 for y miles, and 55 for z? I have a 150 mile round trip commute each day to and from work and that's about 90% or more of my driving. Do you think I could benefit from one of these conversions? How well would the Return On Investment work out? Thanks for the thread! |
| Senior Member Join Date: Sep 2005 Location: Seattle area, WA
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 26
Friends: 3 | I'm guessing he's still using the kit at REVIEW: Hymotion Battery Plug-In Prius. |
| Retired and Lovin' It Join Date: Sep 2008 Location: Colorado & Arizona
My Car: 2009 Prius Model: N/A Package: #6 Touring Thanks: 2
Friends: 3 | Quote:
Also, does the Prius recharge the Hymotion battery like it does the reguar traction battery? Or does the Hymotion only recharge when it's plugged-in? | |
| Senior Member Join Date: Jun 2008
My Car: 2004 Prius Model: Package: #9 Thanks: 103
Friends: 4 | I have no doubt that this stellar result takes both a good route and a determined driver. Kudos ! |
| 2502, 299mpg, miles, phev, prius |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/65307-2502-miles-299mpg-in-prius-ii-plug-in-hybrid-electric-vehicle.html | ||||
| 299MPG over 2502 Miles in a Prius II PHEV! | This thread | Refback | 09-14-2009 03:59 AM | |
| 299MPG over 2502 Miles in a Prius II PHEV! | This thread | Refback | 08-12-2009 07:56 PM | |
| 299MPG over 2502 Miles in a Prius II PHEV! | This thread | Refback | 08-12-2009 04:15 PM | |
| Tryin' to find a car using the CARS program: where'd all the fun cars go? - Page 2 - MY350Z.COM Forums | This thread | Refback | 08-05-2009 06:07 AM | |
| 2502 Miles 299MPG in a Prius II PHEV! - PriusChat Forums | This thread | Refback | 07-14-2009 10:09 PM | |
| Prius PHEV conversion now $4,995 | clett | Prius and Hybrid News | 31 | 11-16-2009 02:30 PM |
| How much is a PHEV with 16,000 miles worth? | kiettyyyy | Generation 1 Prius Discussion | 0 | 05-28-2009 04:58 AM |
| Two PHEV Prius in Portland | Bill Merchant | Prius PHEV Plug-In Modifications | 2 | 11-24-2008 03:21 AM |
| Prius - PHEV | sasonion | Gen II Prius Technical Discussion | 0 | 06-25-2008 10:42 AM |
| PHEV Prius | iLLa Prius | Gen II Prius Technical Discussion | 7 | 05-30-2008 06:15 PM |
