This is a discussion on mudguards/flaps affecting mpg? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi Has anyone experienced this? I put mudguards on my prius and watched my MPG drop by 3-4. I used ...
Old 07-16-2009, 06:47 PM   #1
arvind
ape
arvind's Avatar
Default mud guards killing MPG?
Hi
Has anyone experienced this? I put mudguards on my prius and watched my MPG drop by 3-4. I used to average about 47-48 in my car and after installing them, I average 42-44. I had my car service at Toyota Magnussens in Palo ALto and noticed the drop off afterwards. Is this normal or out of the ordinary. Im tempted to take them off but I believe they glued them as well so it might be messy.
Any ideas on this one?
THanks
arvind is offline
Old 07-16-2009, 06:49 PM   #2
arvind
ape
arvind's Avatar
Default mudguards/flaps affecting mpg?
Hi
THanks
arvind is offline
Old 07-16-2009, 06:56 PM   #3
yardman 49
yardman 49's Avatar
Default Re: mudguards/flaps affecting mpg?
Did you check your tire pressures? Maybe they did you a "favor" and reset them back to OEM specs??
yardman 49 is offline
Old 07-16-2009, 07:00 PM   #4
ksstathead
Default Re: mud guards killing MPG?
What if anything besides the flaps was done in this service?
If fluids or alignment, that could cause problems, for example.
You figure it will make your cd worse, and I suppose this difference could result, although it seems like a lot. If they REDUCED drag, toyota would have put them on to begin with.
Suggest you do a coast down in N to a stop on a specific flat stretch. Then if you do get them removed (I'd guess they can heat the glue free), repeat in the same conditions. If you don't get measurably further, then something else was in play.
Real question is how to rule out other factors before removing. Ideas, anyone?
Buying Prius soon!
Mods already owned:
EV Button (yes, the button, not the car yet)
ScanGuage II 3.15 w/ X-Guage (works with current vehicles)
ksstathead is offline
Old 07-16-2009, 07:02 PM   #5
ksstathead
There you go yard, with the obvious easy answer...
Old 07-16-2009, 07:02 PM   #6
yardman 49
yardman 49's Avatar
I wonder if the dealership did you a "favor" and returned your tires to "factory" pressure specifications??
Old 07-16-2009, 07:22 PM   #7
LRKingII
LRKingII's Avatar
Package: Navigation
This would be my bet if you had them pumped up higher the factory specs
LRKingII is offline
Old 07-16-2009, 07:24 PM   #8
LRKingII
LRKingII's Avatar
Package: Navigation
Originally Posted by arvind View Post
Hi
THanks
Why are you posting this in 2 different threads?
LRKingII is offline
The Following User Says Thank You to LRKingII For This Useful Post:
orionll (07-16-2009)
Old 07-16-2009, 08:51 PM   #9
arvind
ape
arvind's Avatar
wasnt sure what section it should be in. sorry
arvind is offline
Old 07-16-2009, 08:52 PM   #10
arvind
ape
arvind's Avatar
i thought the same and I reinflated my tires back to 52 in front like before. still no dice....
arvind is offline
affecting, guards, killing, mpg, mud, mudguards or flaps
Factors affecting MPG KentD8888 Gen II Prius Fuel Economy 77 09-08-2009 11:05 AM
Experience with upgraded stereo affecting mileage? nola_Prius Gen III 2010 Prius Main Forum 13 07-14-2009 09:40 PM
Factors affecting HV battery longevity hybridtwins Generation 1 Prius Discussion 2 06-14-2009 10:28 AM
Emergency Brake Affecting Mileage moshe1436 Gen II Prius Fuel Economy 5 09-18-2007 10:58 AM
EMERGING AUTOMOTIVE TECHNOLOGIES AFFECTING YOU Areometer Prius and Hybrid News 1 03-22-2007 05:31 PM
