This is a discussion on Prius Marathon Run within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; dead band acceleration is when there is no energy flow to or from the battery. I think that if it ...
Prius Marathon Run
LinkBack (6) Thread Tools
Old 08-09-2005, 03:29 PM   #111
Ray Moore
Ray Moore's Avatar
dead band acceleration is when there is no energy flow to or from the battery. I think that if it is teetering on the edge and going back and forth between to and from the battery then you are doing great. very little flow to and from the battery is almost as good as none.
Ray Moore is offline
Old 08-09-2005, 03:32 PM   #112
krousdb
krousdb's Avatar
Model: I
I have learned a lot as a result of participating in the marathon.
The first thing that we could all agree on is that there seems to be no correct way to accellerate. The Prius is very forgiving as long as you keep acceleraton within the 15 - 50 MPG range. Maybe the range is even wider but we did not try anything outside. Rick used 15-20 for his 115 MPG shift, I used 25-35 for my 115 MPG shift and Wayne used 40-50 for his 120MPG shift. The extra 5 MPG was more likely due to gliding down to much lower speeds than Rick or myself.
What I found best for my style was not deadband at all. It was what I call "accelerate with charge". I found that during the night the headlights made it difficult to maintain the HV battery charge so I had to revert to "accelerate with charge", pink arrows from ICE to wheels, green arrows from MG to battery, no orange arrows at all. This kept the battery level steady. I continued this technique on my second shift in the daytime and found that I had an abundance of charge (no headlights) and I could actually use stealth to help me over small hills instead of using the ICE. This is how I went from 105MPG to 112 MPG. So much for my deadband habit.
Another habit that I broke was to glide partially up a hill and then switch to ICE power to pulse the rest of the way up the hill. I switched to DWL (drive with load) in which I switched to ICE power as I approached the hill, held the gas pedal steady at 50-60MPG while I slowly bled off the speed, targeting 32MPH at the peak of the hill.
Combining those two changes, on my last shift, I was over 117 MPG before I decided it was time to end this marathon. Unfortunately I made that decision about 3 miles too early.
Dan
Over 6500 miles of PHEV to date.
krousdb is offline
The Following User Says Thank You to krousdb For This Useful Post:
wfolta (07-07-2009)
Old 08-09-2005, 04:17 PM   #113
dreichla
Default Re: Prius Marathon Run
[quote]
California Vehicle Code Section 21710:
But we can drive barefoot, right?
BTW....how can they see what gear I'm in?
Gee, I hope so!
I've started turning OFF my headlights during the day and have also noticed a slight change efficiency, although I see people pulling out in front of me more.
dreichla is offline
Old 08-09-2005, 04:19 PM   #114
Ray Moore
Ray Moore's Avatar
Dan- I agree with everything you just said from my experience. The problem is that we have to compromise to keep other drivers happy so accelerate with charge is usually too slow.
I would really like to see you achieve 128 MPG so we can claim one mile per ounce of gas. This latest effort got one miler per 1.17 ounces of gas.
Old 08-09-2005, 04:24 PM   #115
krousdb
krousdb's Avatar
Model: I
Next stop, one mile per tablespoon!
krousdb is offline
Old 08-09-2005, 04:30 PM   #116
ltu1542hvy
For whatever it's worth, theres a blurb about you guys over at autoblog
http://www.autoblog.com/entry/1234000147053641/
- Bill
ltu1542hvy is offline
Old 08-10-2005, 02:33 AM   #117
ehurtley
That would be a bit extreme, as that would be 256 miles per gallon.
On a side note, I just registered (I've been over at PriusOnline for a while, and have read PriusChat for a while, but just registered,) and have to say one thing:
I went to college with the commander of the Space Shuttle (Eileen Collins,) and know her as an 'acquaintance'; yet I was more enrapt by this feat of eco-friendliness by total strangers than by the status of the shuttle landing!
ehurtley is offline
Old 08-10-2005, 02:37 AM   #118
vincent1449p
My Car: 2003 Prius
[quote]Final numbers: 1397 miles! 109.328 MPG! 12.78 gallons!</span>
That is awesome!!!
I 've also been following and I thought it might be easier to keep track with a spreadsheet. Please note that this is for reference only and I apologise if there were errors.
The effect of OAT and the no. of stops & slows on fuel economy can be clearly shown. However, I can't seem to corelate the percent ICE on against FE.
Vincent
vincent1449p is offline
Old 08-10-2005, 07:12 AM   #119
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
Hi Vincent,
Thank you for the nice spreadsheet.
I don't understand what is the exact problem, but I'm going to try to solve...
There is an ICE-ON distance counter internally on SuperMID, but the distance is not displayed because of lack of display space.
For example, from the first Dan's data...
Fuel used: 4.501 L
ICE-ON FE: 12.41 km/L
ICE-ON distance: 4.501 X 12.41 = 55.86 km (hidden ICE-ON distance)
then
Percent ICE-ON: 55.86 / 200.38 = 0.279 or 27.9%
Is this calc clear for you?
Ken@Japan
ken1784 is offline
Old 08-10-2005, 10:12 AM   #120
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
Vincent, your spreadsheet is just as I was trying to develop, except you have kept in some of the seconday info I had skipped. Yours is better.
Do you approve if I post it on other Prius groups with credit to you?
DAS
tochatihu is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/10132-prius-marathon-run.html
Toyota Owners Club - Toyota Forum > Keep It Clean&#33; This thread Refback 05-21-2009 06:27 PM
Keep It Clean&#33; - Toyota Owners Club - Toyota Forum This thread Refback 05-08-2009 03:02 AM
Keep It Clean&#33; - Toyota Owners Club - Toyota Forum This thread Refback 05-07-2009 07:53 PM
Brtax Car Seats, Car Seats 20 To 35 Lbs, Britex Baby Car Seats - Enduromotorcycles This thread Refback 03-09-2009 08:27 AM
Prius links This thread Refback 06-14-2008 07:02 PM
Prius links This thread Refback 02-10-2008 03:14 PM
Will a Britax Marathon Car Seat fit? cgilmer Gen II Prius Main Forum 11 07-06-2009 03:55 PM
Honda Insight Marathon efusco Gen II Prius Fuel Economy 17 06-03-2008 03:46 PM
Marathon Mod Day: PriusXM, Fog Lights and EV baxsie Gen II Prius Modifications 6 12-18-2005 11:55 PM
