| This is a discussion on 2006 navigation- override within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have found the instructions for trying to override the navi and can't get it to work. I have tried ... |
Friends: 0 | I have found the instructions for trying to override the navi and can't get it to work. I have tried so many times when I got in my buddy's '05 I was able to do it from memory. Anyone have a similar experience in an '06 or know the solution? Thanks in advance- Drew |
| Cool Chick with a Black Prius Join Date: Aug 2005 Location: Los Alamitos, Orange County, CA
Friends: 2 | Quote:
| Senior Member Join Date: Nov 2005 Location: Los Angeles, CA
Friends: 0 | The '06 has been out for more than 3 months. Are the Prius wizards having a hard time with this? Does a solution even exist? |
Friends: 2 | Quote:
| Senior Member Join Date: Mar 2005 Location: Pittsburgh, PA
Friends: 0 | Still no solution yet??? This is making me a bit antsy, as I really LOVE using that override in my 05. I will be severely BUMMED if I lose this ability when my new 06 gets here... :-( |
Friends: 0 | <div class='quotetop'>QUOTE(airpolgas @ Mar 20 2006, 02:08 PM) [snapback]227442[/snapback]</div> Quote:
My Car: 2004 Prius Model: Package: #9 Thanks: 101
Friends: 41 | I'm going to copy/paste my reply to a similar question recently posted at PriusOnline. This is a minimally invasive way to access both NAV and BT on-the-go by installing a pair of switches. It's how us "old timers" did it for almost 2 years before the software override was discovered on the '04/'05. Ok, here's what you need to know if you're feeling adventurous. I'll just say that this hasn't been tried yet in the '06 to my knowledge, but it's certainly doable. First, read through this thread completely: http://priuschat.com/index.php?showtopic=456 The easiest solutions that will cause the fewest problems for you are the following: Install a pair of small rocker switches attached to the 2 purple wires shown in this picture: ![]() then you can turn off the speed sensor wires at will then reactivate them at will. It's not difficult, all you need to do is cut the 2 purple wires, tap them connect the switches (I'd cut a couple small holes in the vent cover below the vent and leave plenty of extra wire so the dealer doesn't pull it off and tear everything up. A couple small black switches will be pretty inconspicuous and will be easy to reach by you or the passenger. Drilling, tapping and all you should be able to do this in 30 minutes.
| Navigation Override for 2008 Prius | Gareth | Gen II Prius Main Forum | 16 | 01-20-2009 12:47 AM |
| Override Navigation system | Lyn24 | Gen II Prius Audio and Electronics | 7 | 01-28-2007 06:19 PM |
| Navigation Override for 2002 Prius | Wilson Y | Gen II Prius Audio and Electronics | 0 | 12-27-2006 03:26 PM |
| Navigation System Override on 2006 | vic334 | Gen II Prius Audio and Electronics | 5 | 07-13-2006 12:48 PM |
| Navigation Override | JeffSchlichter | Gen II Prius Main Forum | 1 | 12-05-2005 12:39 AM |
