This is a discussion on 60,00 mile service. New water pump? suspicious. Under extended warranty? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Took Prius in for 60,000 mile servicing. Was told that the necessary and the recommended servicing would be over 400 ...
LinkBack (1) Thread Tools
Old 11-18-2008, 11:26 AM   1 links from elsewhere to this Post. Click to view. #1
harper42
harper42's Avatar
Default 60,00 mile service. New water pump? suspicious. Under extended warranty?
Took Prius in for 60,000 mile servicing. Was told that the necessary and the recommended servicing would be over 400 dollars. I asked them to do only the necessary - oil change, tire rotation. They discovered seepage around the water pump. I need new water pump. Cost 400 dollars. And it just happens that my standard guarantee only covers 5 years or 50,000 miles. Just sounds suspicious, since I declined 400 dollars of work. What do you think?
Also, I did buy an extended warranty. Should that cover my water pump work? I looked at warranty but could find nothing.... maybe I read it thru too quickly. Maybe one of you experts would know. You're always so good to help.
Thanks. Sharon
harper42 is offline
Old 11-18-2008, 11:28 AM   #2
richard schumacher
Destination: Eschaton
richard schumacher's Avatar
Default Re: 60,00 mile service. New water pump? suspicious. Under extended warranty?
Get a 2nd opinion at another Toyota dealer. But water pumps *do* fail, sometimes. Whether your extended warranty covers this depends on that warranty.
richard schumacher is offline
Old 11-18-2008, 04:10 PM   #3
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 46
Hi Sharon,
Suggest that you ask to be shown the water pump seepage. If it is leaking you should be able to see a reddish or pinkish powder residue where the leak is occurring.
If you have the Toyota extended warranty then this repair should be covered.
Patrick Wong is offline
Old 11-18-2008, 04:33 PM   #4
Ct. Ken V
Hi, Sharon,
If your extended warranty happens to NOT be the official Toyota Financial Services one (in other words a 3rd party one that may have a lot of loopholes so that it won't cover the water pump), your factory warranty for the drive train is 5 yrs/60,000 miles (not the 50,000 you stated), so it should be evident (if the dealer isn't lying to you) that the seepage/leaking started before the 60,000 miles, so it should be covered under the factory warranty. However, the thing I'm not sure about here is if the water pump is considered part of the engine to them (I think it is).
Ken (in Bolton,Ct)
Ct. Ken V is offline
Old 11-19-2008, 08:40 AM   #5
harper42
harper42's Avatar
Originally Posted by Ct. Ken V View Post
Hi, Sharon,
Ken (in Bolton,Ct)
TRouble is, I was a little late, like 60,300 getting it in; so if they wanted to be technical about it, it probably would have expired anyway. But I do have the extended warranty, bought from the dealer at the time of purchase, so I hope it is covered. Is seepage around the water pump a typical thing? Is the only repair total replacement of the pump? Not just gaskets or seals or something like that?
harper42 is offline
Old 11-19-2008, 09:54 AM   #6
spitinuri
spitinuri's Avatar
At this age of the vehicle. If you have to take the water pump off it is better to replace.
spitinuri is offline
Old 11-19-2008, 10:13 AM   #7
hobbit
hobbit's Avatar
A little weep around the shaft seal of the mechanical, engine-driven
water pump is *not* a problem. It can happen under higher pressure
when things get hot, and will fling a very thin line of pinkish
crust up onto the hood liner. But if you're not actually losing
coolant at any visible rate, it's not a problem as the volume
is very low and occurrence infrequent.
My car's been doing it every since I got it.
Backing off belt tension a little bit may also help.
_H*
hobbit is offline
Old 11-19-2008, 10:17 AM   #8
Patrick Wong
DIY Enthusiast
Friends: 46
Originally Posted by hobbit View Post
A little weep around the shaft seal of the mechanical, engine-driven water pump is *not* a problem. It can happen under higher pressure when things get hot, and will fling a very thin line of pinkish crust up onto the hood liner. But if you're not actually losing
coolant at any visible rate, it's not a problem as the volume is very low and occurrence infrequent.
I disagree with Hobbit on this point. If the leak is sufficient to fling coolant on the hood, then the pump should be replaced.
In the case of the OP who apparently has extended warranty coverage, there should be no question about replacing the water pump now.
Old 11-20-2008, 08:53 AM   #9
jelloslug
It buffed right out!
jelloslug's Avatar
The water pump is only about $50 from Toyota and I replaced the damaged one on my salvage car in about an hour.
jelloslug is offline
extended, mile, pump, service, suspicious, warranty, water
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/55742-60-00-mile-service-new-water-pump-suspicious-under-extended-warranty.html
55742 60 00 Mile Service New Water Pump Suspicious Under Extended Warranty Rapidshare Search Engine - Meta search engine - search DVD, MP3, ISO, music, video, games This thread Refback 05-16-2009 11:49 AM
Discounted Toyota Prius Extended Warranty /Service TonyPSchaefer Knowledge Base Articles Discussion 3 07-16-2008 06:01 PM
Monitor died with 140 miles left on my 75,000 mile extended warranty seeh2o Gen II Prius Care, Maintenance and Troubleshooting 2 02-15-2008 01:53 AM
Canceling extended warranty and prepaid service? dr_skoobie Gen II Prius Care, Maintenance and Troubleshooting 13 06-08-2007 12:11 PM
Extended Service/Maintenance Warranty desmondlee Gen II Prius Care, Maintenance and Troubleshooting 7 04-23-2007 01:10 AM
Extended Warranty Service Alicia Gen II Prius Main Forum 4 10-18-2005 04:06 PM
