This is a discussion on Help with debadging within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The 2008 have holes under the side "Hybrid" badges as well. I was able to stick it right back on. ...
Help with debadging
LinkBack (5) Thread Tools
Old 04-04-2008, 12:58 PM   #11
rep308
Default Re: Help with debadging
The 2008 have holes under the side "Hybrid" badges as well. I was able to stick it right back on. I think the badges look tacky and they are a pain to wax around.
I used a hair drier, goo gone and wood shim as the putty knife to wedge it off. It took less than 5 minutes
rep308 is offline
Old 04-04-2008, 01:25 PM   #12
Doc Willie
Shuttlecraft Commander
Doc Willie's Avatar
Friends: 11
I removed the side ones from my '07. I am still learning the best way to fill and paint the TWO holes on each side.
Why remove them? They did not look right and are not Starfleet issue.
Doc Willie is offline
Old 04-04-2008, 01:32 PM   #13
prius729
prius729's Avatar
Depending on the size of the holes, I'm guessing it can't be that big, get some green vinyl stickers and cover up the holes.
prius729 is offline
Old 04-04-2008, 02:37 PM   #14
tkil
It would be spiffy if you could use the holes to install turn indicators...
tkil is offline
Old 04-04-2008, 05:45 PM   #15
Doc Willie
Doc Willie's Avatar
Friends: 11
Would have worked if I had removed the badges BEFORE I had the stripes put on.
Old 04-04-2008, 06:12 PM   #16
Steamboatsig
Steamboatsig's Avatar
Why remove badges?
I removed my badges and instantly gained 10 mpg. Plus, my Prius gained 15 hp, easy!
It must have something to do with the aerodynamics/weight ratio frequency thing.
Steamboatsig is offline
Old 04-04-2008, 09:01 PM   #17
statultra
uber-Senior Member
statultra's Avatar
what i would do, is put some fiberglass where the hole is and use glazing filler, if its a small hole, if its kinda big you would have to slap on some filler, i would get some lightweight filler as it will help.
statultra is offline
Old 04-04-2008, 09:53 PM   #18
Doc Willie
Doc Willie's Avatar
Friends: 11
I got the filler part. It's getting the courage to grind enough away, including the surrounding (gasp) paint job to be able to prime and paint and have it all come out smooth. This is why one usually has professionals do this stuff.
Old 04-04-2008, 11:21 PM   #19
Hybrid Effects
Hybrid Effects's Avatar
Just get what they call small plastic nails or small hole plugs that is your best option.
Hybrid Effects is offline
Old 04-04-2008, 11:48 PM   #20
Ct. Ken V
Hi, all,
In photos of the European or Japanese island Priuses, don't they have side marker lights at that location? That may be what the holes were originally intended for [with any Hybrid/HSD emblem simply re-located within a few inches (if THEY even use them)].
Maybe Toyota decided to stop making 2 kinds of fenders for the production lines [those without holes for the USA/Canada market & those with holes for the rest of the world (if they need them for the lights?)], but as far as replacement crash parts for our '04's & '05's in North America (& anywhere else?), they would still have to provide fenders without holes until 2014.
I've heard that the ultra high tinsel strength steel used in the Prius requires body shops with special weld'g equipment, so if Toyota only provides the fenders with holes as crash parts then they would have to have plugs made of the same material of the right size for those specially equiped body shops to weld in place to mimic a stock hole-less fender for the North American '04 & '05 models.
As an alternative the body shops could just order a pair of Hybrid/HSD emblems to cover the hole(s) on the fender(s), but the insurance companies probably wouldn't want to pay for 2 of the approx $30 emblems to be added to a car they weren't stock on. Yet if the hole-less fenders become unavailable in the future, I think the emblem addition will be a cheaper solution for the insurance than paying the shop to obtain/cut a plug, prep the metal for weld'g, do the weld'g, grind the weld bead flush, & then prime it (a lot of extra work before the color coat).
Of course whether weld'g is necessary instead of plastic body filler (Bondo), would depend on the size of the hole (which nobody has measured & reported yet). I know some of you don't approve of the emblems but I think I would rather have the factory hole covered by an emblem than have a welded plug maybe blister underneath the paint (as I had happen to a welded fender on another car years ago) or a plastic Bondo plug break loose & fall out due to road vibration.
Back to you who already have the holes & want to remove your emblems, see if that parts/accessory site that has the Japanese only parts has the side marker lights that I think I remember seeing. If you're good with electrical wiring you can tie into the regular light'g wiring & set them up as simple side markers or make them into side signals by tying into the signal light cicuits. Just some thoughts, crazy as they may be.
Ken (in Bolton,Ct)
Ct. Ken V is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/33829-help-debadging.html
Prius debadging attempt This thread Refback 11-24-2008 04:56 PM
Hood logo This thread Refback 09-18-2008 04:19 PM
Prius debadging attempt This thread Refback 06-14-2008 07:08 PM
Hood logo This thread Refback 05-25-2008 01:49 AM
Prius debadging attempt This thread Refback 04-20-2008 04:38 PM
'Debadging' a 2006 milhouse Gen II Prius Modifications 9 09-18-2007 05:55 AM
