Sorry if this is stupid...but what is grill block?
Old 10-23-2007, 03:01 AM   #1
sea-horsea's Avatar
what is it and what is it for? something to do with cold weather i assume...thanks
sea-horsea is offline
Old 10-23-2007, 03:12 AM   #2
skandale's Avatar
It's quite simple, actually.
Some people used foam insulation normally used to wrap around tiny water pipes, and push this into their grill to block air from rushing through the grill and thus cooling off the engine.
This is because the cold winter air cools down the engine much more than the engine needs to run comfortably, and in effect, the engine needs to run more to keep it's heat and be able to keep the cabin temperature at desired levels.
This has been done for ages in colder climates (like here in Norway). Many people use pieces of carboard or such to block for instance half the radiator to make the engine run a little warmer. The engine gets warm a lot quicker and retains it's heat for longer times. As the Prius shuts off the engine as often as i can, this is a bigger issue for the Prius than most other cars.
-Stein
skandale is offline
Old 10-23-2007, 03:17 AM   #3
sea-horsea's Avatar
<div class='quotetop'>QUOTE(skanDALE @ Oct 23 2007, 02:12 AM) [snapback]529186[/snapback]</div>
-Stein
.....so the grill is refering to ...the front of the bumper where the air goes in? ....how do you "block" it then....hmmm i kinda see the picture now..but its still blurry....thanks :P
Old 10-23-2007, 03:21 AM   #4
skandale's Avatar
This thread has some nice pictures showing this:
http://priuschat.com/My-attempt-at-grill-b...ing-t39790.html
skandale is offline
Old 10-23-2007, 12:58 PM   #5
Green Hokie's Avatar
Package: S Touring
<div class='quotetop'>QUOTE(skanDALE @ Oct 23 2007, 03:21 AM) [snapback]529190[/snapback]</div>
Wow! Those are some really nice photos! :P
Green Hokie is offline
Old 10-24-2007, 03:12 AM   #6
skandale's Avatar
<div class='quotetop'>QUOTE(Green Hokie @ Oct 23 2007, 06:58 PM) [snapback]529335[/snapback]</div>
I only link to the best!
skandale is offline
Blocking the grill New2Prius2008 Gen II Prius Main Forum 31 01-21-2012 09:12 PM
Prius Grill italyfilez Gen II Prius Care, Maintenance and Troubleshooting 13 10-25-2008 06:09 PM
Update to Grill Blocking Please morpheusx Gen II Prius Modifications 17 09-19-2007 11:37 PM
When to remove lower grill block? moredes15 Gen II Prius Modifications 16 03-31-2007 11:07 AM
Last day with Grill blocker efusco Gen II Prius Modifications 13 03-17-2007 07:31 PM
