Towing my prius behind my RV
Old 10-26-2007, 10:47 PM   #1
Hi All-
We just purchased our 2008 Pirus. We want to tow it behind our RV when we leave CT in November for a year tour of the US. I was told by one salesperson that he asked the tech's and they said it could be towed front wheels up. Has anyone towed their Prius without any issues? and how did you tow ? Dolly, front wheels up?
There seems to be a discprency in the manual about towing albeit they are not talking about behind an RV but by a tow truck.
It says - definitely no sling type towing. Got it!
Then it shows the car being towed by a truck with the front wheels raised in a dolly "wheel lift type truck" like set up (rear wheels down) and simply says "release the parking brake" next to the picture. Seeming to indicate that if the front wheels are off the ground all is well and it can be towed without danger.
On the very next page in a notice it says "never tow this vehicle with any of its wheels in contact with the ground" - Does that mean only to tow on a flat bed?
Furthermore the notice goes on to say to not tow the vehicle with the power switch off as the steering lock mechanism is not strong enough to hold the front wheel straight. I'm not sure I get this one!
Then in the very next bullet of the notice it says - When raising the vehicle, ensure adaquate ground clearance for towing at the opposite end of the raised vehicle. Without adaquate clearance, the vehicle could be damaged by being towed.
Is this just boiler plate toyotaease?
If any one can shed light on whether they have towed one or if and how it can be towed I would be very grateful.
Thanks in advance
wille
slimwille is offline
Old 10-27-2007, 12:11 AM   #2
Human - Animal Hybrid
dogfriend's Avatar
Friends: 15
<div class='quotetop'>QUOTE(Wille @ Oct 26 2007, 07:47 PM) [snapback]530986[/snapback]</div>
Hi All-
Thanks in advance
wille
There is a note that the Prius is not designed to be towed as a Dinghy with all four wheels on the road.
[attachmentid=12222]
However, I have seen a Classic Prius (01-03) towed on a dolly with the front wheels on the dolly. I don't see why you couldn't tow it that way.
dogfriend is offline
Old 10-27-2007, 06:47 AM   #3
<div class='quotetop'>QUOTE(dogfriend @ Oct 27 2007, 12:11 AM) [snapback]531024[/snapback]</div>
Thanks = Wille
Old 10-27-2007, 08:11 AM   #4
An Aussie perspective
patsparks's Avatar
Friends: 36
As long as the front wheels are off the ground and the "ignition" (& park brake) is off no problem. Biggest hastle might be the back bumper will be close to the ground.
patsparks is offline
Old 10-27-2007, 09:19 AM   #5
Artist In Residence
Ichabod's Avatar
Friends: 7
You can buy a car trailer, or a car tow dolly (lifts only the front wheels) to safely tow a Prius. The transmisison is always "in gear" which is why you can't tow with front wheels down. As long as the bumper isn't dragging, you're fine. I think the warning about back clearance is more for tow-truck type towing where the front end is lifted significantly higher.
Ichabod is offline
Old 10-27-2007, 09:34 AM   #6
Fat Member
lefat1's Avatar
leave the prius home, come and get me and we'll tow my harleys and get lost in the smokies..lol..
enjoy ur trip
lefat1 is offline
Old 10-27-2007, 10:30 AM   #7
Well, front wheels on the floor and car pulled means energy generation, you will basically do regenerative braking while towing...
Not a good idea.
Well there is a simple workaround : pack a light dome tent in your prius, a nice inflatable matress (luxury) and you're all set !
loupitou06 is offline
Old 10-27-2007, 01:23 PM   #8
smithBYU85's Avatar
<div class='quotetop'>QUOTE(Wille @ Oct 26 2007, 08:47 PM) [snapback]530986[/snapback]</div>
Hi All-
Thanks in advance
wille
One thing I have never understood (and I may never understand), is why someone will spend boatloads of money on and RV, and now in your case a brand new Prius, and NOT put the car on a full trailoe? Why not buy a cheap car trailer or rent one and get the car completely off of the ground? Then you don't have to worry about towing techniques, wear and tear on the car, ruining the drive train, battery, tires, etc... It seems to me that if you can afford an RV and a new Prius, you can probably afford a car trailer, not a simple tow dolly. Maybe I'm wrong...
Save yourself the trouble and get the car off of the ground.
T. Smith
White 2004 Prius
smithBYU85 is offline
Old 10-27-2007, 02:12 PM   #9
MJ Green
mjms2b's Avatar
<div class='quotetop'>QUOTE(smithBYU @ Oct 27 2007, 10:23 AM) [snapback]531225[/snapback]</div>
Hmmmm-yeah, sorry but I tend to agree, less headache too.
mjms2b is offline
Old 10-27-2007, 02:19 PM   #10
Professor Chaos
morpheusx's Avatar
Towing by dolly is a royal pain, I've done twice while moving and it is impossible to go in reverse.
morpheusx is offline
prius, towing
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/39044-towing-my-prius-behind-my-rv.html
Thread Towing my prius behind my RV | PriusChat Forums | BoardReader This thread Refback 04-05-2012 04:07 PM
Thread Towing my prius behind my RV | PriusChat Forums | Page 2 | BoardReader This thread Refback 03-30-2012 06:39 PM
Towing a Prius This thread Refback 03-10-2012 11:06 AM
Thread Towing my prius behind my RV | PriusChat Forums | BoardReader This thread Refback 02-04-2012 06:14 PM
Two wheel car towing Prius - Google Search This thread Refback 11-08-2010 08:42 PM
I Cant See My Car While I Am Towing It Behind My Rv - Images : Kosmix This thread Refback 08-14-2010 06:23 PM
Towing a Prius This thread Refback 06-11-2010 09:42 AM
Towing a Prius This thread Refback 06-09-2010 05:23 PM
Towing a Prius This thread Refback 06-09-2010 04:27 PM
Towing a Prius This thread Refback 06-09-2010 01:51 PM
Towing a Prius This thread Refback 06-09-2010 12:56 PM
Towing a Prius This thread Refback 06-09-2010 11:35 AM
Towing a Prius This thread Refback 06-09-2010 11:32 AM
Towing With Prius? Hytec Gen II Prius Main Forum 46 04-25-2011 09:58 AM
Towing with the 2004-5 Prius froggdancer Gen II Prius Main Forum 30 10-27-2007 03:31 AM
Towing with a Prius FJRCRAZED Gen II Prius Main Forum 21 10-30-2006 04:37 AM
Towing the Prius behind an RV compwolf Gen II Prius Technical Discussion 10 06-28-2006 03:15 AM
Towing the Prius Eugene J Young Gen II Prius Main Forum 7 08-16-2005 10:44 AM
