| This is a discussion on Another Strut Tower Brace Option within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by CBarr31 .....Anyway, for those keeping score this is the 3rd BT Tower Strut Brace that I have ... |
| | #1 | |
| Prius Absolutum Dominium Join Date: Sep 2005 Location: Long Island, NY
My Car: 2004 Prius Model: Package: Base Thanks: 29
Friends: 10 | Quote:
This was my solution and with no "clearance" problems. I used a Corolla aftermarket brace. I made my Strut towers installation almost 6 months prior Brian's BT tech, offering his innovative product for sale. ![]() - - - - - - - - - - - - - - - - - - - - - - - ![]() - - - - - - - - - - - - - - - - - - - - - - - Last edited by mrbigh; 04-05-2009 at 09:38 AM. | |
| The Following User Says Thank You to mrbigh For This Useful Post: | Frayadjacent (04-06-2009) |
| Senior Member Join Date: Mar 2009 Location: Owego, NY
My Car: 2006 Prius Model: II Package: #5 Thanks: 5
Friends: 1 | Quote: |
| Senior Member Join Date: Sep 2007 Location: Charlotte, NC
My Car: 2006 Prius Model: Package: #7 Thanks: 10
Friends: 0 | Mrbigh, It looks like that is a Megan Racing Front Upper Strut Tower Brace #MR-SB-TC001 for Corolla Model years 03-08 ... is that correct? If so that brace can be purchased for about $70 plus shipping at a few different websites it looks like. Another added bonus is that it can be ordered in blue, red, black or silver. Of course that is somewhat meaningless since as it was pointed out earlier it will be completely hidden. Did you have to make any modifications to the brace/car or did you just install it "right out of the box" as is? If that was the case this might be the way for me to go. Thanks for all the help. Chris |
Friends: 1 | Quote:
Thanks, | |
Friends: 0 | Boppo, There is a GREAT "How to" at the beginning of the post from Gadgetdad (Lee) on how to install the BT Tower Strut Brace. Thanks Again Lee!!!! The procedure would be the same for this brace. Boo also converted these instructions to a Microsoft Word format and posted it in Post #32 (for me) which you can download and print. Thanks to you too Boo!!!! PriusChat ROCKS!!!! Thanks again, Chris |
Friends: 1 | Quote:
Friends: 1 | Quote: Thanks | |
Friends: 12 | Quote: Wayne | |
| Junior Member Join Date: Dec 2008 Location: new york
My Car: 2001 Prius Model: Package: Base Thanks: 0
Friends: 0 | Hi, It is such a nice stuff and I really like it. Thank you so much for sharing. Stella |
"This post was transfered from another thread as general information." First let me tell you that I Installed this brace almost 3 years ago, so some details I do not have but I''m rolling the information I can remember. The bar was purchased through an eBay dealer for about 55.00 and in deed, there were some color selections on the finish, I choose blue. Today days may be other options but my selection was a "Flat T6 Al Brace, more rigid and less vibration that a cylindrical tube. CBarr31 is right, that's the merchandise information. The 2 tower brackets: These are the most important pieces and everything plays with physical clearance with the cowl, I had install these inverted, with the adjusting bolt facing down , and shimmed the brackets with SS washers in the towers bolts, the brackets do not have to be flat on the bubble, mine are installed with an inclination toward the engine, like an slightly slant. These brackets should be securely fasten with the original strut tower bolts, take a look at the pictures for guidance. Then you install and fasten the connecting rod, making sure that you do not push of pull the strut towers out of their original alignment. Re-install the cowl, the wipers assembly, the wiring harness, the plastic grill and then the wiper arms. Having all materials on hand ( the proper size washers), will not take you more than 1 hour from start to finish.
__________________ PHEV conversion (rolling since Dec '06) | |
| brace, option, strut, tower |
| 2010 strut tower brace? | smbrm | Gen II Prius Modifications | 3 | 03-05-2009 10:30 PM |
| My BT Tech Strut Tower Brace is on the car now. | NoMoShocks | Gen II Prius Modifications | 11 | 04-28-2008 05:13 PM |
| BT Tech Strut Tower Brace Pre-Order | BT Tech | Gen II Prius Modifications | 71 | 03-12-2008 12:11 PM |
| BT Tech Front Tower Strut Brace | BT Tech | Gen II Prius Modifications | 26 | 12-14-2007 03:19 AM |
| STRUT TOWER BRACE | pri | Gen II Prius Modifications | 1 | 05-02-2007 07:53 PM |
