Eibach Springs and KYB Struts REVIEW
Old 05-16-2011, 09:37 PM   #1
F8L
Protecting Habitat & AG Lands
F8L's Avatar
My Car: 2012 Prius
Model: Three
Friends: 75
Default Eibach Springs and KYB Struts REVIEW
*edit* Updated
After 134,000 miles I decided it was a good time to replace my stock struts. They were not leaking yet but I could feel the car starting to bounce a bit over bumps and freeway stability was getting worse. Since I was going to have to take the springs off as well I figured I'd install a set of lowering springs at the same time. The factory springs were starting to sag and I kinda liked the look.
I decided to go with Eibach because I've had them on nearly all of my cars over the last 2 decades and they have always given me the look and performance I wanted.
Car: 2005 Prius
Springs: Eibach Pro-Kit
Cost: $209 at TireRack.com
Struts: KYB G2
Cost: Rear $73/ea | Front $54/ea
We've seen plenty of install pics so I'll just give a summary of my experience.
Comfort:
The ride is a bit more bouncy and definitely stiffer than with my high mileage factory springs and struts but not unpleasant. I'm sure the 17" tires at 51psi make it a bit more bouncy than it would be with lower tire pressure. At this time I would not recommend this kit for someone who wants a cushy old Cadillac type of ride but with the OEM 15" wheels and Yokohama dB Super E-Spec tires (185/65/15) the ride is less bumpy and overall much smoother even at 44/42psi. Drop the pressure a bit and the ride will get a bit more cushy for those folks who like that sort of thing. The handling is a bit compromised by the narrow width of the tire and the larger more flexible sidewall but the body roll is still very much reduced and I think I may just stick with the 15" wheels due to the MPG savings and the smooth ride.
Handling:
The car feels like dare I say a sports car? The handling difference is night and day. I can sling the car through fast corners with ease. The new Michelin MXM4 tires grip like crazy. I've pushed the car pretty hard and I would say it easily corners better than my 2000 Trans Am did with the same springs but wider tires. Body roll is basically gone and the car feels much more stable on the freeway. I guess I would summarize the driving experience as flat. There is no more excessive brake dive or front end lift upon acceleration. Body sway is gone completely. I know it will sound inaccurate but it sort of reminds me of how my Corvette handled during normal everyday driving. It's the perfect upgrade for someone who wants the Prius to feel a bit umm less Priusy.
Appearance:
Eibach claims an average lowering of the car t 1.4" Front and 1.0" Rear. I measured the car before and after lowering but I did not drive it enough to get the springs to settle so my measurements could change. If they do I will edit the thread for accuracy. I started off with a front measurement of 25.75" Front (ground to wheel well top) and just under 25.75" in the rear. After lowering the front is at 24.8" approx. and the rear is at 24.75". I think the rear is lower because it had time to settle, especially while the front was jacked up. The car looks great lowered and was well worth the money even if there were no handling benefits!
Front Before
Front After
Rear Before
Rear After
Whole car before lowering lowering
Whole car after lowering
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Yokohama AVID Ascend tires | Scangauge II | HIDs 5000K
2005 Prius - SOLD: 900w Kenwood eXcelon (Stealth Install), ARC Audio, Diamond Audio stereo system | 17x 7" Centerline RPM Wheels | Michelin Primacy MXM4 tires | Yokohama dB Super E-Spec | Eibach Pro-Kit | KYB G2 Struts | Progress Technology Rear Sway Bar | Corolla Front Sway Bar | WeatherTech floorliners | BT Stiffening Plate| ScanGaugeII | 35w HID Blazer Fog Lights | Morimoto Mini H1 Projector HID Headlights | For LRR Tire Info | Tire Test Results
For Prius and green-tech transportation information check out the www.WhatDrives.us weekly podcast!
F8L is offline
Thanked by 6 Users:
bugly64 (10-30-2011), caffeinekid (08-07-2011), HI MPG (05-17-2011), macmaster05 (05-17-2011), Patrick Wong (05-17-2011), usbseawolf2000 (05-17-2011)
Old 05-17-2011, 01:11 AM   #2
His name is Sora
PhazonPhobe's Avatar
Friends: 5
Default Re: Eibach Springs and KYB Struts REVIEW
Wow. Very nice.
Not sure if I'd go for the whole "bouncy and stiffer" thing. Part of the reason I got the Prius was for the ride. If I want to drive a sports car, I will. That's what my TT Z is for.
But overall, very nice.
PhazonPhobe is offline
Old 05-17-2011, 01:28 AM   #3
[QUOTE=F8L;
[B]Comfort:[/B]
Dear F8L
I already have my 17 wheels installed and very happy with it. I had the tpms transferred to the 17s. Max tire pressure on my tires is 50psi. The tireman told me that he will just place 40psi because the sensors only allow 40psi.
Is this true? Or can I increase my tire pressure to 46 or 48 without the sensor sending an error code?
By the way, what's your mileage loss on the 17s?
Thanks!
CruZindon is offline
Old 05-17-2011, 01:39 AM   #4
Senor Member
macmaster05's Avatar
Package: #5 Touring
Friends: 32
Came out awesome. Couple notes;
-Your last picture isn't level (which makes the front look higher)
- If you lower your tire pressures your car will look even lower
- I'm interested to see if your front continues to settle.
- Your car looks so "right" now. The before picture is humorous to look at.
As for Cruz's question I'm not sure why everyone is obsessed with mileage loss with 17s. The data is useless without knowing the rim weight and tire weight/type.
macmaster05 is offline
Old 05-17-2011, 02:04 AM   #5
direstraits71's Avatar
I don't think there is any error code from the TPS for higher than the set pressure point, only a dash light when the pressure is about 20 to 25% lower than that set point. I run my tires at 39/41 and have the set point high enough that I get a low pressure light around 36-37psi. I think I set the TPS around 50 psi to get this. So I get a very early warning about low pressure. I've had no problems with this setup except if the temperature is extra cold I sometimes see the light until the tires warm up slightly.
I sure wish the system would display real tire pressure instead of just a single fail light. I don't think its available via Scanguage either.
direstraits71 is offline
Old 05-17-2011, 02:20 AM   #6
HI MPG's Avatar
Your Prius is looking really good F8L! Dare I say it looks even better with the drop... Haha.
HI MPG is offline
Old 05-17-2011, 03:52 AM   #7
F8L
F8L's Avatar
My Car: 2012 Prius
Model: Three
Friends: 75
Originally Posted by PhazonPhobe View Post
Wow. Very nice.
I wouldn't call it a very bouncy ride but it is more sensitive to bumps in the road. I only notice this at low speeds. At higher speeds the car feels more controlled when hitting bumps. Like I said earlier, this could be due to my rock hard tires too. I bet my 15s would feel cushy
Dear F8L
Thanks!
direstraits summed up the tire sensor question. My 2005 doesn't have the sensors so I don't have to deal with them.
I lose about 6mpg with my 17s but I attribute most of that loss to my poor choice in tire. I bought them back in 2006. There were virtually no LRR tires available back then so I bought a performance tire. Thankfully my wheels are very light (1 lb more than stock 15s) so when I purchase new tires I should gains most of my mpg back.
Thanks bru! I'll get more pics later. The car looks a little funky in the shop but outside it looked great. Just a bad camera angle. After my drive home the front looked lower but since I added a heavy load in the rear (after the pics were taken) the rear was mashed so the front still seemed higher.
Thanks! I'm kinda old school with my mods in that I like stuff clean and minimal. I don't like attaching a bunch of junk to the car. We've all seen cars that look like a parts catalog was thrown at them. lol
TheFront wheels well gap is now less than 2 finger width wide. It's definitely low.
F8L is offline
Old 05-17-2011, 03:55 AM   #8
To all, Thanks for the information!
Old 05-17-2011, 04:06 AM   #9
F8L
F8L's Avatar
My Car: 2012 Prius
Model: Three
Friends: 75
No problem. That's what this forum is for. To help everyone make their Prius experience the best it can be. Now hurry up and finish your mods and post pics.
F8L is offline
Old 05-17-2011, 04:44 AM   #10
Fleet Captain
Nice install. I'm personally waiting for my struts to give out before buying the new ones. For our 2005s the rears are probably the same, but your new fronts should be sportier than the old ones.
Do you remember how much the whole install cost? I think I paid around 350$ for install and 181$ for the springs
flareak is offline
eibach, kyb, review, springs, struts
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/94006-eibach-springs-kyb-struts-review.html
Thread WTB Eibach or Tanabe springs | PriusChat Forums | BoardReader This thread Refback 04-30-2012 05:25 PM
Thread Eibach Springs and KYB Struts REVIEW | PriusChat Forums | BoardReader This thread Refback 04-07-2012 09:25 AM
Looking at a new car that gets 40mpg - TDIClub Forums This thread Refback 11-12-2011 01:55 PM
Mini Bixenons in my New Beetle! - TDIClub Forums This thread Refback 11-06-2011 12:27 PM
Edmunds Fuel Sipper Smackdown - TDi rates high - TDIClub Forums This thread Refback 10-15-2011 11:31 PM
Diesel wagon an ultimate road-tripper - autonet.ca - Page 2 - TDIClub Forums This thread Refback 10-07-2011 03:52 PM
2012 EPA Estimates - TDIClub Forums This thread Refback 10-01-2011 11:00 PM
Aftermarket wheels effects on MPG??? - TDIClub Forums This thread Refback 10-01-2011 07:32 PM
Aftermarket wheels effects on MPG??? - Page 2 - TDIClub Forums This thread Refback 09-17-2011 01:55 AM
Prius vs TDI - Page 10 - TDIClub Forums This thread Refback 08-18-2011 09:19 PM
My 2011 black TDI - Page 2 - TDIClub Forums This thread Refback 08-16-2011 08:36 PM
Prius vs TDI - Page 4 - TDIClub Forums This thread Refback 08-09-2011 01:35 PM
Prius vs TDI - Page 4 - TDIClub Forums This thread Refback 08-09-2011 01:21 PM
Jetti TDI Wagon or Asian car? - Page 3 - TDIClub Forums This thread Refback 07-24-2011 07:28 PM
Eibach Springs and KYB Struts REVIEW - PriusChat Forums This thread Refback 05-16-2011 11:48 PM
Eibach lowering springs installed indyV Gen III 2010+ Prius Accessories and Modifications 11 05-08-2011 08:15 PM
considering Eibach Pro Springs - but, what to consider? pjam Gen III 2010+ Prius Accessories and Modifications 8 05-03-2011 08:37 PM
WTB Eibach or Tanabe springs grey15 Private Sales 3 03-28-2011 08:56 AM
Interest in Eibach Springs... MPGWHOR Gen III 2010+ Prius Accessories and Modifications 23 03-01-2011 09:32 PM
Eibach Lowering Springs & 40% Llumar Tint. *Pics* Supreme Gen II Prius Modifications 30 07-27-2010 10:29 PM
