knob costs $700 to replace?
Old 01-23-2008, 11:05 AM   #1
Default knob costs $700 to replace?
Jimbok suggested I visit you guys re a problem I have with my shift knob.
With my 04 Prius, I could shift to D or R then let go and the knob would move back to its starting position. I just drove the car and the knob now stays where it is when I shift, rather than moving back to its original position. Liberty Toyota said the problem is due to an internal failure and will cost almost $700 to replace, including labor. It's a sealed unit and can't be disassembled. The car could stop working if I don't replace the sealed unit.
infael is offline
Old 01-23-2008, 11:23 AM   #2
etyler88
etyler88's Avatar
Default Re: knob costs $700 to replace?
Two words. Salvage yard. Save a ton of money and get the part from a salvage yard and have a nondealer repair shop do the work.
etyler88 is offline
Old 01-23-2008, 11:26 AM   #3
awaaay
hyo silver's Avatar
Friends: 89
I'd be tempted to try a shot of lubricant to see if that helps.
hyo silver is online now
Old 01-23-2008, 12:07 PM   #4
I'm not a car guy so...
1) Would a salvage yard actually have that sealed unit? How would I explain what I'm looking for?
2) hyo silver: I assume you mean lube the sealed unit? Liberty did say the knob was making popping sounds. Where can I find instructions for getting to the sealed unit?
Many thanks guys!
infael
infael is offline
Old 01-23-2008, 12:18 PM   #5
Here's one offered on e-bay:
eBay Motors: TOYOTA PRIUS SHIFTER SHIFT SYSTEM OEM HYBRID SILVER (item 190177371957 end time Feb-21-08 14:52:06 PST)
nmrickie is offline
Old 01-23-2008, 12:22 PM   #6
One owner, low mileage
JimboK's Avatar
Friends: 6
Acknowledging I'm nothing close to a Prius tech, I told Infael that I found it hard to believe that, if the only problem was the shift lever assembly, it would cost $700 to replace. Since Prius shifting is a "by-wire" function, my assumption based on the symptoms is that the assembly itself, easily accessed by removing dash panels and presumably a simple mechanical device, would be a rather straightforward and not-too-expensive replacement. Of course I've been wrong before.
I'm interested in hearing what Galaxee's DH and others who work on the car have to say.
Jim
Click here for car details.
JimboK is offline
Old 01-23-2008, 12:23 PM   #7
Friends: 47
Should be very much a plug-and-play item. There are dash disassebly instructions all over the internet and this site for the Prius...take out the old, install the new, and pocket the $580 you save.
efusco is offline
Old 01-23-2008, 12:31 PM   #8
awaaay
hyo silver's Avatar
Friends: 89
I was thinking if it was only sticking a bit, then a quick shot of lube might help free it up. But if it's already making 'popping noises', it's too late for that.
Old 01-23-2008, 12:34 PM   #9
Guy in WNY's Avatar
THERE IS ONE HERE FOR $89.00!!!
Home > eBay Stores > XVIPERS1 > TOYOTA PRIUS PARTS
Darn caps lock!
Sorry about the bold and weird formatting; I cut and pasted over from that web site.
Guy in WNY
Guy in WNY is offline
Old 01-23-2008, 12:37 PM   #10
etyler88
etyler88's Avatar
This place should be helpful, good personel service.
04 and newer Prius Parts Cars
etyler88 is offline
