| This is a discussion on ENGINE LIGHT ON: P0453 evaporation emission control system pressure sensor high input within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 2005 Toyota Prius got the engine light on and checked it with the OBD II got the following: p0453 : ... |
| Member Join Date: Aug 2009 Location: NY 11020
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 13
Friends: 1 | 2005 Toyota Prius got the engine light on and checked it with the OBD II got the following: p0453 : evaporation emission control system pressure sensor high input what is my next move.. dealer or regular mechanic? try to save a student some loan money... History: got the car as is and the dealer gave me this sensor ( like a bent black plastic) and said he took that off from the top of the gas tank to test it on another car to see if it works and he claimed that the sensor worked and once installed it should take car eof my problem so I gave it to my body shop guy and he said he did put it in on top of the gas tank. i went home and reset the engine light and was happy for 3 miles till the light came back with the same error. possibilities: 1. the sensor was not good 2. the body shop didnt know how to install it 3. the problem is not the sensor at all 4. there is another part involved plus the sensor so please help me out here.. and please keep me away from the dealers unless i really have too. |
| Senior Member Join Date: Sep 2006
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 16
Friends: 2 | [quote=doctorman;975955]2005 Toyota Prius got the engine light on and checked it with the OBD II got the following: p0453 : evaporation emission control system pressure sensor high input what is my next move.. dealer or regular mechanic? try to save a student some loan money... History: got the car as is and the dealer gave me this sensor ( like a bent black plastic) and said he took that off from the top of the gas tank to test it on another car to see if it works and he claimed that the sensor worked and once installed it should take car eof my problem so I gave it to my body shop guy and he said he did put it in on top of the gas tank. i went home and reset the engine light and was happy for 3 miles till the light came back with the same error. ------------2. the body shop didnt know how to install it-------------- I like number 2, 4's not bad, good choices in all. , though with the pressure high....not sure how a wrong installation could give you this. To bad the dealer didn't reinstall , that's strange. Could you go back to that dealer for a quick check of the installation? I haven't personally worked with this part of the car. A link with pic's of fuel system http://www.autoshop101.com/forms/Hybrid13.pdf I would try to see if the parts that were reinstalled are secure/well attached , beyond that....well you did save money on the initial purchase. Like you said in the other thread, it is complicated, I would save time and go to someone who's experienced with this model. ------ the P0453 problem is because the stupid body shop lost my Vapor pressure sensor and never installed it so there was just a loose cable instead.--------------- And number 2 was it! Last edited by northwichita; 10-13-2009 at 07:08 PM. Reason: update on answer |
| control, emission, engine, evaporation, high, input, light, p0453, pressure, sensor, system |
| Tire pressure sensor light now stays on with change to new tires: how do you reset this? | local_host | Gen II Prius Main Forum | 18 | 10-06-2009 09:30 PM |
| Oxygen sensor and check engine light | walkinghat | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 03-30-2007 01:56 PM |
| Fuel Tank Replacement for Evaporation Leak / Check Engine Light | heiche | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 03-20-2007 12:03 PM |
| Automatic Light Control System | bfortner | Gen II Prius Main Forum | 28 | 01-25-2006 01:16 PM |
| Automatic light control system on 2006 | MPacifico | Gen II Prius Main Forum | 4 | 01-05-2006 07:34 PM |
