| This is a discussion on 2010 Prius Grill Blocking strategy within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Hello all, On the NHW20, we used to block upper grill all year around because the HV inverter/motor coolant radiator ... |
#1 | ||||||||||||||||||||
Friends: 8 | Hello all, On the NHW20, we used to block upper grill all year around because the HV inverter/motor coolant radiator is located at the bottom, therefore it's better to leave open the lower grill, especially during hot summer. On the ZVW30, I confirmed the HV inverter/motor coolant radiator is located at the top. I believe we have to leave open the upper grill on the ZVW30 for better cooling of the inverter coolant during hot summer. edit on Nov 5th: add a copy of table on post#10. following is my personal recommendation.
Ken@Japan Last edited by ken1784; 11-04-2009 at 11:33 PM. | ||||||||||||||||||||
| The Following User Says Thank You to ken1784 For This Useful Post: | spiderman (10-11-2009) |
Friends: 12 | With the 2G I believe over 90% of cooling air came from the bottom. With the 3G, since the upper opening is not much bigger, would not most of the cooling air still come from the bottom? Didn't I see a JDM nose/grill piece that eliminates the top opening? Wayne |
| Senior Member Join Date: Apr 2009 Location: North Andover, MA
My Car: 2009 Prius Model: N/A Package: No Package Thanks: 3
Friends: 9 | Quote:
The majority of air underflow on a vehicle always (unless deflected with a belly pan) flows vertically after clearing the frontal area of the vehicle. This is the entire reason for a belly pan as mods attempt to force air under and past the underbelly rather than air getting trapped in the vehicle after clearing/flowing through the grille.
__________________ ![]() ![]() *76.0 mpg 2nd place Hybrid/Diesel Division at 2009 AMEC Economy Competition in Fonda, NY (104 mile run on 8/23/09) * Best Tank (400+ miles): 66.0 mpg over 402.6 miles from 8/10-21/2009 My Facebook: http://www.facebook.com/photo.php?pi...?id=1268001941 My Twitter: http://twitter.com/bone1124 www.ecomodder.com | |
| | #4 | |||
Friends: 8 | Quote:
We know we see mpg improvement to block the grill during light load in cold weather. I believe the temperature of the inverter coolant is "cooler is better", between ambient temp and 50C(104F) vs 88C(190F) engine coolant temp, therefore I would like to suggest to leave open for the inverter coolant radiator area during hot summer. Quote:
Would you please post a link or picture if you found any? Thank you, Ken@Japan Last edited by ken1784; 05-31-2009 at 09:45 PM. | |||
My Car: 2007 Prius Model: Package: #6 Thanks: 279
Friends: 11 | Quote:
I have never seen anyone on PriusChat address this, but yes, for the electronics "cooler is better" with regard to the lifetime of the semiconductor devices used in the inverter. Solid state diffusion is a time and temperature related phenomenon - higher temps = higher diffusion rates. Since I live in a climate that is quite hot (>100°F or >38°C) for much of the summer, I do not block the grille on my NHW-20 even in winter. I need all of the "cool" time I can get. | |
Friends: 9 | Here's the thread on this site (specifically post #2) that I saw the upper grill block aero kit from Modellista. After looking at it again (I had not viewed it since seeing it a few weeks ago) it is not a full upper grill block but def smaller than on the 2009 and stock 2010 model. Perhaps the aero kit took the new inverter location into account to allow free flow directly on the inverter. http://priuschat.com/forums/2010-toy...aero-kits.html I would be interested to hear/read/see comments from the Prius Team and/or Toyota engineers in regards to changes made to the location of the inverter. Perhaps it was moved to decrease crash casualties of the most integral parts of the hybrid engine. On the other hand, it may have been simply moving the equipment around to accomodate other equipment under the hood. Anyone have a source addressing this? While the "physical modding for mpg" community has just begun to be accepted into the mainstream on this site and others...I highly doubt auto engineers take this into account when designing vehicles. The Prius is already slippery in terms of CD and if the engineers would have had future mods in mind during the design of the vehicle they would have already put in place full belly pans, more aero antenna and rear wiper, etc. Guess they left that up to us "modders." I will note, the 2010 Prius, while having a lower Cd than the 2009 model really has no significant improvement in CdA than the 2009 model due to the larger frontal area on the 2010 model. |
| Canonus Curiosus Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 150
Friends: 18 | Quote:
It looks to me as though the Gen2 upper grill is larger than the Gen3 upper grill, while it looks like the lower grills are about the same. I haven't measured this at it, and I base my statements only on the "look" of things when I had my 2007 side-by-side with my 2010. | |
Friends: 8 | Quote:
I believe it's enough to cool the inverter radiator temp down. Again, my suggestion is not to block the upper grill completely, 100%, during hot summer. Ken@Japan | |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 227
Friends: 23 | I don't have a scangauge, Ken. How much of the lower grille do you suggest blocking during winter? It's currently -4°C. Is the upper grille blocking advisable during winter or should i leave that open year-round because of the location of the inverter radiator? |
| | #10 | |||||||||||||||||||||
Friends: 8 | Quote:
If you're going to attack , it's another story. Anyway, following is my personal recommendation.
Ken@Japan | |||||||||||||||||||||
| The Following 5 Users Say Thank You to ken1784 For This Useful Post: | Bica2go (10-12-2009), Blind Guy (10-22-2009), itsnicetobe (11-03-2009), pkscout (10-13-2009), Spartane (10-13-2009) |
| 2010, blocking, grill, prius, strategy |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/62556-2010-prius-grill-blocking-strategy.html | ||||
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 10-13-2009 11:51 PM | |
| grill blocking | donalmilligan089 | Gen II Prius Modifications | 12 | 11-05-2008 11:35 PM |
| Grill blocking My Prius Taxi's? | lucky1 | Gen II Prius Main Forum | 8 | 10-23-2008 08:37 PM |
| Suffocating my Prius with grill-blocking | Slartibartfast | Gen II Prius Modifications | 11 | 02-21-2008 02:21 PM |
| Blocking the grill | New2Prius2008 | Gen II Prius Main Forum | 28 | 01-07-2008 07:24 AM |
| Benefit of Prius Coolant Thermo Bottle and Grill Blocking | usbseawolf2000 | Knowledge Base Articles Discussion | 11 | 12-13-2007 11:55 AM |
