This is a discussion on Aftermarket / Portable GPS in Non-Nav Prius within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; I thought I would share my "install" of a Garmin Nuvi 265WT in my 2010 Model III. Overall I am ...
Old 07-08-2009, 06:30 PM   #1
telefrog
Default Aftermarket / Portable GPS in Non-Nav Prius
Overall I am fairly happy with the results. It is obviously not nicely integrated like the factory version, but the location keeps it from being too obtrusive.
I ran the power cable (and integrated FM traffic antenna) through the dash by pulling off the left vent and feeding the cable up. There is enough space near the tiny triangle-shaped window to feed the cable through without destroying or significantly bending the trim. The cable plugs into the cigarette outlet under the buttress... but eventually I'd like to hard wire it somewhere to free up the outlet.
As a side note, I decided on the 265 WT because of the free lifetime traffic. I have several routes to and from work, and like to pick the fastest based on current traffic conditions.
Aftermarket / Portable GPS in Non-Nav Prius-photo.jpg
telefrog is offline
The Following 5 Users Say Thank You to telefrog For This Useful Post:
bwilson4web (08-19-2009), CAR4TWO (09-07-2009), DeanFL (07-08-2009), Edward Walsh (09-07-2009), Pizza_Daddy (08-02-2009)
Old 07-08-2009, 06:41 PM   #2
DeanFL
2010PriusWannabe-Now an owner!
DeanFL's Avatar
Model: V
Default Re: Aftermarket / Portable GPS in Non-Nav Prius
Great install job!
I assume you remove it when not needed / parked. How much was the unit? 4.3" screen?
I'm going to install a backup camera system with a 3.5" monitor. Plan to put the monitor in the lower console - angled up a bit just under where the seat heater switches are on the V. Decent view for the occasional backup. Like your location for a new GPS. Thanks!
Oh - do you have misty gray interior? Seems as if your top dash panel is lighter than the dark gray of my bisque.
DeanFL is offline
Old 07-08-2009, 06:51 PM   #3
telefrog
Originally Posted by DeanFL View Post
Great install job!
I found it for $200 at Circuit City... and it looks like Amazon has it for around $220. Yes, it is the 4.3" widescreen, but I have to admit I miss the center screen I had in my Gen II. I just couldn't bear shelling out a couple thousand more for the nav.
So far, I've kept it in the car at all times... garaged at home, and in a secure area at work. It is easy enough to remove, just unplug and unsnap from the window mount. Next time I am in a "rough" neighborhood it's probably a good idea to remove it.
I have blizzard pearl paint... and I am pretty sure I have the dark grey trim with that. Maybe it's the garage lighting?
telefrog is offline
The Following User Says Thank You to telefrog For This Useful Post:
DeanFL (07-08-2009)
Old 07-08-2009, 06:58 PM   #4
Tech_Guy
Tech_Guy's Avatar
Nice installation. How well does it work in that location? Did you need to install an external antenna? Looks like that location blocks the internal antenna from having a clear view of the sky.
Keith
Tech_Guy is offline
Old 07-08-2009, 07:07 PM   #5
telefrog
Keith
It seems to work fine. No external antenna needed. Most of the time it is synched as soon as I turn the car on. Occasionally it takes longer when I leave the garage (10-20 seconds), but when parked outside it always instantly connects. Accuracy seems to be right on par with my old Gen II factory nav.
telefrog is offline
Tech_Guy (07-08-2009)
Old 07-08-2009, 07:21 PM   #6
ceric
ceric's Avatar
Garmin 265WT is available for $180 on Amazon/EBay with free shipping.
Watch dealsea.com regularly. Sometimes, 265WT can go as low as $130.
http://www.dealsea.com/exec/search/?q=265wt&x=0&y=0 (from Dell)
The real-time traffic (used to own a Navigon with it) has at least 15-20 minutes delay.
The delay could get you trapped (too late) or give you false alarms (accident cleared already, for example).
Besides, as expected, it only shows traffic on highways and expressways.
I personally don't find it so useful. A simpler 205WT/225WT w/o real-time traffic for $130 or less would be my choice if I am getting one today.
Your mounting location is interesting to me.
According to CA vehicle codes, one can mount stuff at the lower two corners (within 7") area of a windshield. Where you mount the Garmin is not the windshield, but a side window (or part of it). CA codes do not allow anything attached to side windows (w/ some exceptions).
You may want to check OH vehicle codes.
2005' Tideland Prius (Dec, 2004)
Mods Done:
body-side moldings, wood dash kit, rear bumper applique, ultrasound backup sensors, backup camera, signal mirrors,
BT stiffening plate, 205/60R15 tires, leather-trim interior, all-weather mats, shark-fin antenna
ceric is offline
Old 07-16-2009, 10:36 AM   #7
RickFlashman
I have my TomTom One (3rd Gen) installed in the same place! Works awsome and is hidden enough I never take it down. Really nice installation point.
RickFlashman is offline
The Following User Says Thank You to RickFlashman For This Useful Post:
Tech_Guy (07-16-2009)
Old 07-26-2009, 10:47 PM   #8
SoTex
Model: II
Actually, per most states' department of transportation, any glass in front of the side view mirrors is considered windshield even if separated by a sail panel. Here in TX, you aren't suppose to get that glass tinted as it is considered part of the windshield. Weird, but true.
SoTex is offline
Old 07-26-2009, 10:48 PM   #9
SoTex
Model: II
I mounted mine using a Garmin dash mount kit and adhered it to the dash just above the left vent. Similar in location to this one but a little closer to the driver.
SoTex is offline
Old 07-27-2009, 10:05 AM   #10
jm1515
Model: V
Excellent job, TFrog...........
That's exactly where my Zumo is going..........
jm1515 is offline
aftermarket, gps, nuvi
Using a portable Garmin-type GPS in 2010 Prius? web1b Gen III 2010 Prius Audio and Electronics 26 11-16-2009 06:27 PM
Do you use the Prius Nav or an Aftermarket GPS? tom1l21 Gen II Prius Audio and Electronics 16 04-24-2009 11:32 PM
prius portable solar panel djphill Gen II Prius Modifications 14 12-08-2008 02:13 PM
Jump You: Jumping a Non-Prius with a Portable Starter a priori Gen II Prius Main Forum 32 07-27-2008 05:32 AM
portable xm radios okay/good for a prius? knownasmichael Gen II Prius Audio and Electronics 17 02-25-2008 05:41 AM
