This is a discussion on VERY cool parking assist mod within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by texsome WHERE can you order this? actually i want one for my highlander not my prius ebay ...
LinkBack (1) Thread Tools
Old 09-28-2009, 03:58 PM   #11
rrolff
Prius Surgeon
rrolff's Avatar
Default Re: VERY cool parking assist mod
ebay search pip and gps. Find the device, and scroll down. You'll see it in the bottom of the listing. Remember, you need to match your paint. Ask the seller a question, and I'm sure they'll work something out...
rrolff is offline
Old 09-29-2009, 10:16 PM   #12
benh57
Package: Navigation
I see a number of parking sensors, but I don't see this particular one (which integrates with Prius nav?) on ebay anywhere.
benh57 is offline
Old 09-29-2009, 11:39 PM   #13
rrolff
Prius Surgeon
rrolff's Avatar
This is a weird part - for which I could not find in the Internet world. Do an Ebay search for PIP GPS Toyota, and look at the bottom of the description - there you will find the part. You would need to contact that Ebay seller (autodvdgps) - but they have poor communications.
rrolff is offline
Old 09-30-2009, 01:35 PM   #14
rrolff
Prius Surgeon
rrolff's Avatar
Installed the bumper sensors last night. The whole task took some time, but I’m happy with the outcome. Following the bumper removal doc was straight forward – though there were a few clips under the car that weren’t mentioned in the doc (not sure if I was blurry eyed – and didn’t really need to remove them – but I believe there were like 4 clips not mentioned). I would invest in the nylon pry tool (I made a pry tool with a grinder, and a cheap wire stripper). The bumper pops off, then you place it safe – then there is a Styrofoam backing on the metal. You need to cut out space for the sensors (measuring twice, cutting once). I made a much larger hole in the Styrofoam – and it turned out fine.
At this point, drill the holes (420mm spacing), plug in the sensors, tie wrap the wires, and run them into the car. I did this on the driver side because I had power and the video signal there.
The video signal from the camera plugs into this sensor box, and the sensor goes to the head unit (nav). Running wires up front (to the nav) is easy – pull the plastic trim at the doors, and you have a nice easy place for the cable to run forward.
Unfortunately, I still do not know where the reverse signal is up front (to my head unit), so while I have this monstrosity installed, I can’t see it in action yet…….
It looks very nice - the smudges on the last picture are from the take residue and dirt from my hands... I hate that sticky stuff...
VERY cool parking assist mod-img_0294-1-.jpg   VERY cool parking assist mod-img_0295-1-.jpg   VERY cool parking assist mod-img_0296-1-.jpg   VERY cool parking assist mod-img_0298-1-.jpg   VERY cool parking assist mod-img_0299-1-.jpg
VERY cool parking assist mod-img_0300-1-.jpg   VERY cool parking assist mod-img_0301-1-.jpg   VERY cool parking assist mod-img_0302-1-.jpg   VERY cool parking assist mod-img_0303-1-.jpg   VERY cool parking assist mod-img_0304-1-.jpg
VERY cool parking assist mod-img_0305-1-.jpg   VERY cool parking assist mod-img_0307-1-.jpg   VERY cool parking assist mod-img_0309-1-.jpg   VERY cool parking assist mod-img_0310-1-.jpg
rrolff is offline
Old 09-30-2009, 03:48 PM   #15
jayvee
Package: Navigation
The REV signal to the head unit is a PINK wire, Pin 5 of L42, a gray connector (drawing below) that goes into the back of the NAV. I have no idea what type of signal this is (12V, etc) but hopefully your install documentation knows what level it is.....
You could also put a voltmeter on it - I suspect it might simply be 12V when Reverse is engaged. But no guarantees....I'd verify that if it were me...
Please post a photo of the screen when you get it working!
jayvee is offline
The Following User Says Thank You to jayvee For This Useful Post:
rrolff (09-30-2009)
Old 10-01-2009, 12:33 PM   #16
rrolff
Prius Surgeon
rrolff's Avatar
Arrg... Mine has no 5 pin connector - anyone else with a reverse clue?
rrolff is offline
Old 10-01-2009, 01:24 PM   #17
Flying White Dutchman
Friends: 9
do you have a picture from the touchscreen showing the superimposed picture?
Old 10-01-2009, 01:58 PM   #18
jayvee
Package: Navigation
Try looking one more time - you HAVE to have this on your NAV head unit. It provides a Parking brake input (pin 1), the ECU-IGN 12V power (2), the wheel speed sensor signal (3), and the Reverse signal (5) that you need.
It is a gray 5-pin connector, with only 4 wires coming out of it (at least I couldn't find a wire in the schematics that was going to pin 4), in this order:
Red (1) - Black (2) - Violet (3) - empty (4) - Pink (5).
According to the schematics, this HAS to be there. (We are talking about a factory NAV unit, correct?)
jayvee is offline
Old 10-01-2009, 02:11 PM   #19
rrolff
Prius Surgeon
rrolff's Avatar
No - this is aftermarket - and I guess that wire harness is not on a stock Prius.
I ended up wiring to the reverse lights for the time being... It works - will post pics at some point...
rrolff is offline
Old 10-01-2009, 02:49 PM   #20
jayvee
Package: Navigation
Correct - that harness is only present with factory NAV. Sorry, incorrect assumption on my part...
So who installed your aftermarket? If you have a reverse backup camera functionality, they must have tapped into some kind of reverse line? Can't they tell you which line in the aftermarket NAV it is?
Or did you do it yourself? If so, can you post the installation instructions? That might help figure it out.
jayvee is offline
assist, cool, mod, parking
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/69601-very-cool-parking-assist-mod.html
Mi Toyota Prius - Pdf de la instalacion de los sensores traseros TPA (Prius 3G) - Tuning Prius 3G This thread Refback 10-04-2009 11:48 AM
Parking Assist Mike_ Gen III 2010 Prius Main Forum 3 07-11-2009 03:19 AM
Intelligent Parking Assist (IPA) jamesrom Gen II Prius Audio and Electronics 13 06-28-2009 08:03 AM
Parking Assist coming to US.... Psi296 Gen II Prius Main Forum 8 04-05-2006 03:16 AM
Parking assist mssmith95 Gen II Prius Main Forum 3 04-04-2006 02:01 AM
Parking assist boa8 Gen II Prius Audio and Electronics 2 03-09-2004 01:17 PM
