| This is a discussion on removing front door 6x9 speakers within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Good thread. Probably will become a sticky someday. How much area does the sound deadening material cover? And is that ... |
| | #11 |
| Just another Onionhead Join Date: Mar 2007 Location: Texas
My Car: 2007 Prius Model: Package: #3 Thanks: 5
Friends: 0 | Good thread. Probably will become a sticky someday. How much area does the sound deadening material cover? And is that white sheet some sort of heat or sound insulation? The G2 doesn't have that. BTW, those speakers look terrible... |
| | #12 |
| Dr Curious Join Date: Aug 2009 Location: Louisiana
My Car: 2010 Prius Model: II Package: No Package Thanks: 134
Friends: 0 | Looking forward to seeing your 6x9 MDF rings! |
| | #13 | |
| Going insane! Join Date: Jun 2009 Location: Bedford, OH
My Car: 2010 Prius Model: II Package: N/A Thanks: 3
![]() Pic below of wiring harness attached ![]() Pic of the access hole that the mirror wiring goes thru with plastic panel removed. ![]() Fair warning, the door gasket that all the wiring comes thru makes a bend that will be damn near impossible to fish additional wiring through without removing all the current wiring. I was unable to get a new set of speaker wire through it because of the sharp bend. If someone knows a fix to this let me know, cuz I'm stumped. Last edited by WaterbedWarrior; 08-14-2009 at 10:00 AM. | |
| | #14 |
Friends: 0 | So a quick update. My jigsaw is broken, friend is lending me his this weekend, so will have to wait on the MDF rings. So I decided to run my wires. Ran 3 sets of RCa cables, only planning on running two sets at the moment, but the 3rd is ran incase I want to install and additional amplifier later to run the rear door speakers. Easier to get the cables to the head unit now. I ran new speaker cables from the rear amp up to the doors to power the 6x9's but as stated in the previous post can't get the cables through the door gasket/wiring enclosure. So will tie on to the old wires before they enter the gasket area. Also installed sound deadening in the passenger door, doesn't sound like tin now when you tap it. The brackets off the stock head unit will tie directly onto my Pioneer head unit, just need to go get some screws to attach it with. Taking the stock head unit to a guy I know who does stereo installation for a living, as I'm clueless as to what all the back connections are for. Hoping it will take a standard Toyota wiring adapter kit. With a little luck, I may have the 6x9's and head unit install completed this weekend except for making a custom faceplate to fill the gap left by the stock radio. Last edited by WaterbedWarrior; 08-14-2009 at 10:13 AM. |
| | #15 | |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 119
Friends: 2 | Quote:
Peter | |
| | #16 | |
| | #17 | |
Friends: 2 | Quote:
Peter | |
| | #18 | |
A line level converter takes speaker level inputs and converts them to RCA inputs. So, (I think), behind the radio there will be (at least) six pairs of speaker wires (one pair for each speaker) that exit the radio (they go from radio to speaker.) You would end up running the wires from the radio to the line level converter, instead of the speaker, and that would give you some RCA inputs that you can run to your amplifier. | |
| The Following User Says Thank You to radioprius1 For This Useful Post: | spiderman (08-15-2009) |
| | #19 |
| Senior Member Join Date: Apr 2007 Location: Los Angeles
My Car: 2010 Prius Model: II Package: No Package Thanks: 9
Friends: 0 | Really curious about the sqwuakers...don't know of a 2.5" drop in replacement, but it'd be nice to just put a decent tweeter up there...usually tweeters pointed at the glass give a nice diffused sound field. Can you tell if the wiring goes from the door to the sqwuaker, or is the sqwuaker fed directly from the head unit? The former seems more likely...thanks for taking the time to document all this... While we're at it, where are you mounting you amps? Under seats? That seems like a good space...the storage compartment is so useful whereas the under seat area is sort of wasted space... |
| | #20 | |
. (Edit: Amps fit nicely under the front seats, looks like I'll be rerouting some wires/cables today. Thanks for the great input Mike)It looks like the front squawkers separate from the wiring prior to the wires entering the doors. I'll have to test further to determine this to be true. I'm thinking it should be as simple as disconnecting the door speaker and playing music to see if the squaker still plays. Should be several more updates this weekend. Last edited by WaterbedWarrior; 08-15-2009 at 07:55 AM. | |
| 6x9, door, front, removing, speakers |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/67089-removing-front-door-6x9-speakers.html | ||||
| Klappergeräusche | This thread | Refback | 10-07-2009 04:13 AM | |
| New speakers in Front Door panel - '06 | steveduer1 | Gen II Prius Audio and Electronics | 9 | 07-05-2007 12:27 PM |
| unlock the door without removing the sks from your pocket | Mary Snyder | Gen II Prius Main Forum | 21 | 06-07-2007 06:45 PM |
| Scion TC speakers in front door? | goodsam | Gen II Prius Audio and Electronics | 2 | 02-25-2006 08:18 PM |
| Nervous about removing door panels/wiring | IndyDoug | Gen II Prius Audio and Electronics | 4 | 10-28-2005 03:59 AM |
| Removing Door Panel | XravenX | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 05-23-2005 11:53 AM |
