This is a discussion on Need help removing rear seat.. within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Anyone know how to remove the rear seat bottom cushion? I am working on sound deadening and only have the ...
Old 09-27-2009, 11:43 PM   #1
banshee08
Model: II
Default Need help removing rear seat..
Anyone know how to remove the rear seat bottom cushion? I am working on sound deadening and only have the floor and rear seat left and was wondering how the heck to get the rear seat off.
Anyone install leather covers that has taken removed the rear seat cushion??
Thanks in advance,
Chan
banshee08 is offline
Old 09-28-2009, 07:59 AM   #2
radioprius1
Dr Curious
Model: II
Default Re: Need help removing rear seat..
Hi Chan,
Just push your front seats forward to get a lot of room in the back, then reach on the bottom of the rear seat and pull upward with a lot of force. The seat will come off. It's just held in by a couple of clips.
radioprius1 is online now
The Following User Says Thank You to radioprius1 For This Useful Post:
banshee08 (09-28-2009)
Old 09-28-2009, 12:21 PM   #3
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
That's just like the Gen II's rear seat bottom. Good to know.
Boo is offline
Old 09-28-2009, 12:38 PM   #4
banshee08
Model: II
Will give this a try next weekend. I need to let my back rest for a week before attempting that again. Wow, I remember sound deadening a much easier job when I was younger.
Thanks again,
Chan
Old 09-28-2009, 01:03 PM   #5
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
If it's just like the Gen II, in the front there's a hook on the left and a hook on the right which you unhook by lifting the seat up from the center with your left arm on the left and your right arm on the right of the center hump.
Once you lift the front up you should be able to see another hook or hooks in the back.
Here are the Gen II Seat Assembly Instructions. Page 15 illustrates and describes how to remove the rear seat cushion:
Click the image to open in full size. SE%20-%20Seat.pdf
Best regards, Tom
07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads.
Boo is offline
Old 10-03-2009, 08:39 PM   #6
rrolff
Prius Surgeon
rrolff's Avatar
This is a great doc, as I have my Katzkins, and my hog clipper......
Can anyone confirm this also applies to the 2010 model (for seats)??????
rrolff is offline
rear, removing, seat
Removing back seat from 2010 III Prius Rymor Gen III 2010 Prius Accessories and Modifications 2 10-03-2009 06:42 PM
Removing rear seat on 2009 novice Gen II Prius Main Forum 7 07-23-2009 04:49 PM
Improved MPG by removing seat zenMachine Gen II Prius Fuel Economy 37 05-28-2008 04:49 PM
Removing the bottom of the back seat? blind Gen II Prius Main Forum 3 11-13-2007 12:16 PM
Removing rear seat cushions kente777 Gen II Prius Main Forum 3 01-10-2006 07:35 PM
