This is a discussion on 2010 Tire Pressures for Yokohama 15" within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; What pressure is everyone recommending??? Haven't checked it yet..... Thanks!...
Old 06-11-2009, 09:41 PM   #1
barbaram
barbaram's Avatar
Question 2010 Tire Pressures for Yokohama 15"
Thanks!
barbaram is online now
Old 06-11-2009, 11:09 PM   #2
FireEngineer
Friends: 13
Default Re: 2010 Tire Pressures for Yokohama 15"
Same as the old Integrity's, as high as your bottom can stand. But that's just me.
Wayne
FireEngineer is offline
Old 06-11-2009, 11:19 PM   #3
msirach
msirach's Avatar
I recommend at least sidewall pressure. I left the dealership and stopped at the gas station across the street and took them to 51 front and 50 rear and drove to Virginia. I was surprised to find the pressure from the dealership at 39 rear and 41 front. No problems and it handled well. On our return trip, I drove through rain for about 150 miles including one torrential downpour that had the interstate traffic slowed to 35 mph.
QUOTE=barbaram;873171]What pressure is everyone recommending???
Thanks![/QUOTE]
msirach is offline
Thanked by:
barbaram (06-12-2009)
Old 06-12-2009, 10:14 AM   #4
barbaram
barbaram's Avatar
so you are happy so far ? I haven't had any poor driving conditions yet and I have been spoiled by the hydroedges.....
Old 06-12-2009, 11:17 AM   #5
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
MAX Sidewall on the Yokos is 44psi. I'm running 40/38. I reset Trip A and Trip B at last fillup. I reset Trip B again after bumping tire pressures 75-100 miles into the tank. Trip B reads about 1-1.5mpg higher than Trip A. At the initial inflation, I saw 60+mpg, but then my commute set in.
HTMLSpinnr is offline
Thanked by 2 Users:
barbaram (06-12-2009), RichardUSA (06-25-2009)
Old 06-12-2009, 12:58 PM   #6
alfon
Package: Navigation
2010 Prius III with Navi:
I inflated my Yoko's to max sidewall pressure on all 4 tires, 44 PSI, when we purchased the car on 05/17/09.
No problem with handling, MPG is averaging over 51 MPG for 3,000 miles, based on gas pumped and miles driven.
Alfon
alfon is offline
Thanked by:
Old 06-17-2009, 12:39 AM   #7
barbaram
barbaram's Avatar
I'm a bit confused.
It finally stopped raining here today so I had a chance to check the tires.
MY tires say "40 PSI max" the door label says 35/35!!!!!
they were not properly inflated in any way!
it's been cool here so i went 38/36.
where are you finding 44 pSI??
thanks!
Old 06-17-2009, 09:43 PM   #8
PriusCrazy
Blizzard Pearl for Me
Originally Posted by barbaram View Post
I'm a bit confused.
thanks!
Hmmm... My door label says 35 front/33 rear and the Max Load on the tire says 44 psi for the Yokohama Avid S33. Have you double-checked your numbers?
PriusCrazy is offline
Old 06-17-2009, 10:26 PM   #9
msirach
msirach's Avatar
Mine say 44psi also.
msirach is offline
Old 06-19-2009, 12:50 AM   #10
HTMLSpinnr
HTMLSpinnr's Avatar
Friends: 18
40 PSI max is for seating the bead to the rim. 44psi is the max cold pressure.
Thanked by:
barbaram (06-23-2009)
2010 tire pressure
Tire Pressures jetlaw Gen II Prius Technical Discussion 23 06-12-2008 07:21 PM
Tire sizes, pressures and snow lowbone Gen II Prius Main Forum 0 08-01-2007 06:32 PM
Higher tire pressures korndorb Gen II Prius Care, Maintenance and Troubleshooting 26 02-15-2007 02:42 AM
tire pressures grasshopper Gen II Prius Main Forum 5 01-09-2006 08:00 PM
Tire Pressures Stan Wilson Gen II Prius Main Forum 11 03-07-2004 10:22 AM
