| This is a discussion on GEN III Engine Block Heater Installation within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; I helped Wayne research doing block heaters on the Gen III back at Hybridfest, and we got a bunch of ... |
| | #31 |
Friends: 0 | I helped Wayne research doing block heaters on the Gen III back at Hybridfest, and we got a bunch of pictures of our exploratory process. I've written it up, available here, and referencing my gen-2 instructions and that other long-running "want to install a block heater yourself?" thread. . I deliberately did *not* include anything about routing the power cord for the heater. That's something that DIYers can figure out their own preferred path on! At the end it shows what can happen when those cheezy molded plugs get a little too much abuse. . _H* Last edited by hobbit; 09-01-2009 at 09:41 AM. |
| The Following User Says Thank You to hobbit For This Useful Post: | Jim05 (09-02-2009) |
| | #32 | |
Friends: 12 | Quote:
Good writeup as usual Those molded plugs will fail due to all the flexing they experience. Not only from plugging in and unplugging, but also from flapping around in the breeze driving down the highway I've never gotten more than 3 winters out of a heater plug before it failed. Don't just chop off right at the plug, as I can almost guarantee the stranded wire inside has failed as well, due to the repeated flexing. Chop at least 2 inches further up the plug Like you, I much prefer "real" plugs. I like these http://www.passandseymour.com/pdf/H07.pdf They have the plastic inserts to hold small, flat cordsets. For making "real" extension cords, the inserts can be thrown away. Actually, for heavy duty cordsets, I prefer this plug http://www.passandseymour.com/pdf/H05.pdf This way, the cord goes straight down and there is little strain on the cord
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion | |
| | #33 |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 119
Friends: 2 | Just curious, what is the lifespan on these heaters? Peter |
| | #34 |
Friends: 12 | Most blockheaters, I've managed to get 4-6 years before they burned out. That is, not a dead short, but just open. Keep in mind I live in a pretty harsh winter climate, it can get to -40, so folks tend to leave their block heaters plugged in 24x7 once cold weather hits |
| The Following User Says Thank You to jayman For This Useful Post: | spiderman (09-01-2009) |
| | #35 | |
| Member Join Date: Aug 2009 Location: Seattle, WA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 25
| | #36 | |
Wayne | |
| The Following User Says Thank You to FireEngineer For This Useful Post: | Dark_matter_doesn't (09-19-2009) |
| | #37 |
Friends: 12 | OK everyone in the Chicagoland area and anyone else who wants to make the drive, here is the Chicago event Chicagoland engine block heater install event. Wayne |
| block, engine, gen, heater, iii, installation |
| Engine block heater? | swich2mac | Gen III 2010 Prius Main Forum | 10 | 06-19-2009 11:41 AM |
| 2002 Prius Engine Block Heater Installation | JasMayor | Gen II Prius Modifications | 2 | 11-20-2008 08:24 AM |
| Chicago Prius Group Engine Block Heater Installation | dc4549 | IL - Chicago, Illinois | 0 | 10-22-2007 01:15 PM |
| Heater Block Installation Idea | gpb5200 | Gen II Prius Modifications | 1 | 03-12-2007 04:50 PM |
| Yet another block heater installation thread | Beryl Octet | Gen II Prius Modifications | 0 | 12-30-2006 11:42 PM |
