12 volt battery dead - 2010 Prius
| Junior Member Join Date: Nov 2009 Location: kc
Friends: 0 | 2010 12v battery dead after about a week of being parked. Can the 2010 be charged via a regular 12v battery charger like a conventional auto? Any tips on jump starting other than what's in the manual? |
| wretched Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 951
Friends: 24 | Yes, it is a conventional 12v battery, just smaller. I can't believe it died in just a week. I would at the least mention it to the dealership. Was it outside? What was the environment like? Did you leave anything on (lights ,etc)? |
My Car: 2012 Prius Plug-in Model: Plug-in Base Package: Base Thanks: 652
Friends: 6 | IT can be catastrophic to reverse the polarity when jump starting, I assume the same for charging so be careful. Observe polarity. Do a complete search on the subject on Priuschat, BEFORE starting! |
| My other car is a boat Join Date: Mar 2006 Location: Northern Michigan
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 1,354
Friends: 19 | Quote:
Tom | |
Friends: 0 | Thanks Spiderman. as far as I can tell I left no lights or anything else on (is this dead battery thing a Pruis soft spot?). It is garaged, parked in central Florida (a bit cool lately but no great shakes). We live in a golf cart community and can get to most errands via cart. It was a real shock when we got in to go to church this morning and -- nothing. Tripple A came out and started it with no problem. Took it for a ride and will have my fingers crossed for tomorrow. Any idea if I can use a regular battery charger to to keep it topped off when I'm not using it? So far this is the first problem I've had with it and really enjoy it. |
Friends: 0 | Thanks Tom, TrippleA came out and got her going. Thanks for the response. |
Friends: 0 | |
Friends: 6 | Thankyou for the Thankyou! There is a long history covering various problems, procedures and causes with the 12VDC battery. It is vital that new members SEARCH in Priuschat first and read all the previous posts. All 3 (4) generations are basically the same in regards to the 12V system. With this knowledge one is better armed to discuss the peculiarities of Prius with a tech writer, mechanic or salesman. One lady with the assistance of a tow truck service totally ruined her inverter (a reverse polarity situ) and after weeks of struggle NEVER got satisfaction from her Toyota dealership and ended up selling the Prius at a additonal loss. Last edited by andyprius; 02-01-2010 at 11:48 AM. |
| Senior Member Join Date: Dec 2009 Location: Laguna
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 0
Friends: 0 | I left my car in the garage for over a week and had no problems with the battery. Maybe I was lucky. |
Friends: 19 | You can keep the battery topped off with a "battery minder" type of device for AGM batteries. A normal battery charger or trickle battery charger will tend to overcharge and damage the battery if left on for extended times. As for whether this is a "soft spot" for the Prius, the 12V battery is small, so it will discharge more quickly than a traditional large starting battery. That said, you should be able to leave your Prius parked for several weeks without any trouble. There are two situations where the 12V battery will have chronic problems: 1) A dead or dieing battery. If you make a habit of leaving lights on or the car door open, your 12V battery will have a short life. 2) Short trips. The Prius uses a constant voltage charging system for the 12V battery. It is effective, but not very fast. If you only drive your Prius for very short trips, the charger will not fully recharge the 12V battery. In this case you should consider a battery minder, or perhaps make a few longer drives. Tom Tom
| 2010, battery, dead, prius, volt |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-care-maintenance-troubleshooting/75497-12-volt-battery-dead-2010-prius.html | ||||
| 12 volt battery dead - 2010 Prius - PriusChat Forums | This thread | Refback | 11-17-2011 02:10 PM | |
| 2010 II 12 Volt Battery Dead After 17 Days of Parking | indianapens@msn.com | Gen III 2010+ Prius Care, Maintenance and Troubleshooting | 134 | 03-09-2012 10:50 AM |
| How to start a Prius after long term storage (HV battery dead, replaced dead Aux battery). | edli | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 06-25-2010 10:45 AM |
| 12 volt battery dead | BobA | Gen II Prius Care, Maintenance and Troubleshooting | 19 | 01-06-2010 06:51 PM |
| How to open doors or just the hood when 12 volt battery is dead | gdangelo | Gen II Prius Main Forum | 27 | 08-24-2007 06:04 AM |
| Dead 12 volt battery after 1 week | TiogaJenny | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 09-30-2006 12:10 AM |
