| This is a discussion on 2010 Road Noise within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by gtarr Can you share with us what products you purchased and how you installed the Sound Insulation ... |
2010 Road Noise
| | #11 | |
| Senior Member Join Date: Feb 2007 Location: Modesto, California
My Car: 2010 Prius Model: IV Package: Premium w/ Solar Cells - CA Thanks: 86
I used RAAMmat and had component speakers replacing the front door speakers installed. Then sealed up the door with Dynamat. Deadening the sound cavity in the doors with these products improve the sound of the audio plus cut down on the road noise. Good luck, Lee | |
| | #12 |
| Prius owner Join Date: Jun 2004 Location: Washington DC area
My Car: 2006 Prius Model: Package: #9 Thanks: 0
Friends: 0 | At the Washington DC Prius connection event if I understood correctly there was significant effort at lowering noise levels on the 2010 model including: 1) noise dampening on the front wheel wells. 2) aerodynamic improvements under the car causing noise reduction 3) larger engine causing lower rpm at hiway speeds (and less noise) Separately, many Prius owners report lower noise by changing the tires to a few of the Michelin types. Eric |
| | #13 | |
| Junior Member Join Date: Jan 2009 Location: Silicon Valley
My Car: Prius On Order Model: Package: #6 Thanks: 0
Friends: 0 | DO you know what MIchelins' users tried that reduced noise and do we know if they had to sacrifice fuel economy ? Quote:
| | #14 | |
Friends: 10 | Quote:
Many PC members use Nokian WRg2 tires and report no loss of mileage. Tom | |
| | #15 |
| Junior Member Join Date: Feb 2009 Location: Bay Area, CA
Friends: 0 | I would be interested as well... |
| | #16 |
Friends: 1 | YEA! PLEASE Toyota Prius team: Go to the TireRack All Season survey pages and don't put anything on the 2010 that has less that Excellent reviews for all categories. I could give you a pass to Good on the ice and snow on cars sold where it does not snow, but I notice that most of the tires that don't score 'Excellent' on those are also only 'Good' for hydroplaning and wet traction. Stop giving car reviewers cause to downgrade the car simply because they ride on cheap rubber. And, save your buyers some money by putting decent tires on the cars to start with so they don't have to: Suffer with lousy tires until they wear out or Buy decent tires to replace the OEMs (anyone want some 2004 Integrity tires, only 8K miles on them!!)
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. |
| | #17 |
My Car: 2008 Prius Model: Package: T3 Thanks: 7
Friends: 0 | The UK car gets Bridgestone Turanza ER30s as the OEM tyre. They seem pretty good. TireRack review only rates treadwear as 'good', though, and they are a summer-only tyre. No doubt this is why the braking distance is poorly rated by magazines - the OE tyres just don't grip. |
| | #18 |
| Junior Member Join Date: Jun 2009 Location: Charlotte,NC
My Car: 2010 Prius Model: II Package: N/A Thanks: 0
Friends: 0 | I find the interior noise of the 2010 Prius to be quite high. With the car off there is good base from the speakers(replaced the OEMs). When the engine is running there is allot of low frequency noise that masks the base region which pretty much wipes out the base. At highway speeds the road noise makes things worse. Allot of noise comes from the dash board, probably through the fire wall and from the wheel wells. Road noise also comes through the floor. No where near as quiet as my old Buick. This makes it difficult to get good sound from the stereo. The Prius needs much better sound proofing. I love the MPG but the interior noise is disappointing. I will have to work on that. Also, the engine roars on acceleration. I used to think this was typical for 4 cylinder cars. Apparently, it still is. Toyota needs to do better in this area. |
| | #19 |
| Member Join Date: Aug 2009 Location: Minneapolis
My Car: 2010 Prius Model: V Package: Navigation Thanks: 15
Friends: 0 | I find the interior noise of the 2010 Prius to be quite low. |
| | #20 |
| Don't Wait Until Tomorrow Join Date: Sep 2005 Location: South Florida
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 0 | Amazing how my Gen III V is sooo quiet at low speeds and sooo loud at highway speeds. Cheap (Bridgestone) tires and poor (any?) cabin sound insulation. |
| 2010, noise, road |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/57451-2010-road-noise.html | ||||
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 11-01-2009 08:48 AM | |
| Love my Prius but not the road noise | carolmac | Newbie Forum | 7 | 09-14-2007 08:31 PM |
| GM Aims For 1,000 Chevrolet Volts On Road Before 2010 | Volty | Prius and Hybrid News | 61 | 08-01-2007 03:20 PM |
| road noise / radio | rigormortis | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 04-02-2007 05:28 AM |
| Recommendations for reducing road noise? | eugenelin | Gen II Prius Main Forum | 15 | 04-19-2006 12:20 PM |
| Road Noise | pdamski | Gen II Prius Main Forum | 5 | 09-11-2004 11:33 PM |
