| This is a discussion on 2010 Prius - battery specs within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; I'm currently working on the new Info-Sheet and User-Guide for the 2010 Prius. Filling out the generation matrix comparing the ... |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 9
Friends: 12 | I'm currently working on the new Info-Sheet and User-Guide for the 2010 Prius. Filling out the generation matrix comparing the Original, Classic, and Iconic models has left 3 unanswered questions:
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Quote:
Tom | |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 215
Friends: 18 | Repackaging may affect overall weight, but the energy/voltage has not changed. |
Friends: 12 | ^ With what these guys said John. But when I go to the Chicago event I'll recheck with the Toyota people. Wayne |
Friends: 59 | The battery pack info with the enclosure is still not known. The number of cells are the same so it should be 201.6 V. Cell level energy and weight are available on the PEVE page. Plastic Case Prismatic Module | Panasonic EV Energy Co., Ltd. |
Friends: 44 | Quote:
2009: 28 hp Toyota Prius - 2009 Performance & Specifications 2010: 36 hp, per the 2009 NAIAS Media Information DVD jacket that we received in Detroit. I had assumed that they are getting more power out of the battery by further reducing internal resistance. Last edited by Patrick Wong; 02-09-2009 at 08:43 AM. | |
Friends: 18 | They may have increased the overall output current of the battery pack. I'd be worried about longevity as a result though if the module itself isn't changed. |
Friends: 8 | Quote:
Anyway, Panasonic EV Energy supplies a Metal Case Module too since 2005 for Highlander/RX400h. It is 9.6V module, but site says 6cell 7.2V module is possible. Metal Case Prismatic Module | Panasonic EV Energy Co., Ltd. The basic specifications are same as plastic one, but I believe the metal one is stronger in heat stress than plastic. Camry Hybrid has 244.8V pack, which means it uses 34 7.2V modules. I believe TCH uses metal module since it introduced after THH/RX400h. Also, didn't we hear from Chief Engineer the cooling function on the 2010 Prius battery pack was improved? I believe the new battery pack will be more powerful and reliable than the current even the basic specification numbers are same. Ken@Japan | |
Friends: 20 | Quote:
Bob Wilson | |
Friends: 18 | Given where I live, I still worry. I'm glad my '04's made it to 110,000 miles on the original pack w/ light (judicious) usage of EV. I'm not as worried about making to 100,000 warranty, but the "lifetime" padding may have gotten much shorter, and I worry that we could realistically see 120,000-150,000 HV battery pack replacements as a norm. I'd hate to think Toyota built that into the long-term income strategy of the car. |
| 2010, battery, prius, specs |
| Aux battery specs NHW11 post-TSB | ChapmanF | Gen II Prius Technical Discussion | 3 | 02-05-2009 05:55 PM |
| Want 12 Volt Battery Specs. | Walker1 | Gen II Prius Technical Discussion | 29 | 02-03-2009 12:47 AM |
| 2010 Toyota Prius Photos and release specs posted | HTMLSpinnr | Gen III 2010 Prius Main Forum | 64 | 01-17-2009 05:50 PM |
| Traction battery specs and usage | aeronaut | Gen II Prius Technical Discussion | 1 | 07-02-2007 05:07 PM |
| Tech specs for HV battery? | mspencer | Gen II Prius Main Forum | 15 | 03-11-2005 08:39 PM |
