Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010+ Prius Main Forum
Summary of problems reported on Prius 2010
Old 12-09-2009, 06:01 PM   #181
Green Architect
Analogkid1958's Avatar
Default Re: Summary of problems reported on Prius 2010
Cold feet, hot head? Uneven heat distribution...
Love the A/C in the car, but the heat leaves me with cold feet and a burning up head!
In "Auto" setting at any temp or A/C and recirc setting, the default air direction is down to the footwells. But some air is also directed to the side face vents. The upper part of the cabin seems to stay much warmer than the footwells.
I've tried all kinds of combinations of settings, but it seems that the "Auto" setting should be the most equal.
Maybe I'm too used to US cars' climate control systems... :-)
Comments welcome!
Mark Darrall, AIA, LEED AP BD+C
Yorktown, Indiana
2010 Prius III, Barcelona Red
"Red Barchetta"
Analogkid1958 is offline
Old 12-09-2009, 06:05 PM   #182
Green Architect
Civic, thank you!
ISSUE: ABS not what I expected?
I got Red into the snow for the first time yesterday and got to experience both traction control and ABS response (I've had experience with Honda and Chrysler ABS, never TCS). Traction control was about what I thought it would be but the ABS seemed to be pretty lame. I didn't experience the shuddering pulsing as in our Honda and Dodge, but instead slow pulses every couple seconds. I slid through a couple stops until I figured out how to compensate.
What's everyone else experiencing?
Thanks!
Last edited by Analogkid1958; 12-09-2009 at 06:09 PM. Reason: Hit send too soon. Sorry!
Old 12-09-2009, 06:59 PM   #183
The world needs more prius
Package: Base (Canada)
Interesting observations (this one + ABS in snow). If you can create new threads and have someone confirm your observations (see post #2 in this thread), please give me the reference to your threads here and I will add the problems to the list.
CivicQc is offline
Thanked by:
Analogkid1958 (12-29-2009)
Old 12-21-2009, 09:17 PM   #184
Originally Posted by garygid View Post
THE BACKUP BUG - DANGEROUS UNEXPECTED ACCELERATION
(Not just the annoyance of Abrupt Braking)
Just yesterday, my Prius-III backed up with sudden unintended acceleration, with my foot only on the brake pedal. No, the accelerator pedal was not "stuck" or being touched in any way. The parking spot was level.
I recognized what was happening because it happened once before, just over 2 months ago, just a few days after I got the car, when I was backing out of an inclined driveway. Perhaps insignificant, but both times, I had a passenger in the passenger seat.
I suspect that some unusual element of the timing of turning the car ON, and shifting into Reverse, and possibly the internal state of the computer and the hybrid power system combine to produce this "abrupt" reverse acceleration as I am gently easing off my foot pressure on the brake pedal. Others describe this as an annoying "Abrupt Braking", and the abrupt braking effect does occur, but only in response to the much more DANGEROUS "unexpected, unintended" reverse power (acceleration), to stop the car motion. No matter how gently the brake is eased further ON to stop, the stop is "abrupt", not smooth.
Yes, in this case pressing the brake gently, just a little, stops the car, but with a big "Jerk" (the Abrupt Braking effect). Then, shifting into Neutral and then to Reverse again "resets" the software so that further backing is the normally expected gentle movement of the car.
However, the unexpected "jump" backward (due to the unexpected power and acceleration) might have caused an accident, crashing my car into anything behind it. This is DANGEROUS.
And, after the crash, who would believe me when I said, "The Prius-Backup-Bug did it, not Me!"?
Sincerely trying to help Toyota have a better Prius,
Gary,
Prius-III + Nav, made July 2009 in factory "5"
I actually had something similar happen to me a couple times. It occurs randomly, but when it does, it feels like I have no control over the Prius when backing out. Before I thought it was just the way I was braking, but when I tried releasing the brake very slowly, the same thing happened. I felt a jerking motion every time I stopped because I was scared I would just roll onto the street and hit something. If anyone else knows anything, please let me know.
950platinum is offline
Thanked by:
CivicQc (12-29-2009)
Old 12-24-2009, 06:31 PM   #185
Default fuel flow indicator shows zero - engine still running - Prius 2010
Purchased my third Prius (2010) in August 2009. Since early November (we're two hours north of Toronto) I've been observing what appears to be a bug in one of the two Prius hybrid system computers. Generally when it is below 0 Celsius, or the car has not fully warmed up, I observe the fuel flow indicator (which I'm always working to keep at its lowest) to fall to zero (disappear). However, the engine continues to run. If I maintain power below mid-point on power bar display, the fuel flow can stay at zero - until engine actually stops - or until I push pedal to move power bar above mid-point, at which time fuel flow indication resumes. Has anyone else seen this, or is this a problem specific to my own 2010 Prius (Canada - base model).
mlaurenc is offline
Old 12-29-2009, 03:56 PM   #186
Green Architect
Thanks again, Civic - where should I put these new threads?
Old 12-29-2009, 04:09 PM   #187
Green Architect
Civic, thank you!
Thanks!
UPDATE: I had the dealer check the ABS and they reported all is well. Since we have packed snow and ice (and water on top of packed snow and ice) right now, I took Red to a nearby parking lot and exercised both the traction control and ABS.
I'm more comfortable with them now. The ABS definitely FEELS different than in our Dodge, but seems to be working, as I can steer while coming to a stop.
I guess that comes with being on the uphill side of the learning curve with such a different vehicle!
Thanked by:
Old 12-29-2009, 04:13 PM   #188
Green Architect
Comments welcome!
UPDATE: Closing the face vents, or at least directing them toward the window (or over my my shoulder) seems to help. Closing the vents directs a TINY bit more air to the footwells, though it could still be better.
This may be generic to Toyotas, as I borrowed a Yaris this morning while Red was being looked at and it was very similar.
Thanked by:
Old 12-29-2009, 04:26 PM   #189
Done as suggested.
New thread posted.
Mike
mlaurenc is offline
Thanked by:
Old 12-29-2009, 05:10 PM   #190
Orf
Orf's Avatar
Package: I-Tech
Last night I was in a car queue to get a ticket to board a ferry and as the cars were moving slowly I selected "Park" each time I stopped. After doing this about 6-8 times when I selected "Drive" nothing happened, the car stayed in park.
I tried several times and even selected all other setting to no avail.
I solved the problem by turn the power off with the power switch and powering on again.
I will make further tests today to see if I can reproduce the fault.
Orf is offline
2010, prius, problems, reported, summary
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/67272-summary-problems-reported-prius-2010-a.html
Toyota Prius : toujours numéro 1 au Japon | le blog auto This thread Refback 04-10-2012 05:17 AM
Toyota Prius : toujours numéro 1 au Japon | le blog auto This thread Refback 04-09-2012 04:02 PM
Toyota Prius : toujours numéro 1 au Japon | le blog auto This thread Refback 04-09-2012 03:23 PM
???????????? Prius ???????????????????????????????? This thread Refback 01-11-2012 07:44 AM
???????????? Prius ???????????????????????????????? This thread Refback 08-02-2011 07:15 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 01:11 PM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 01:03 PM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 12:49 PM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 12:31 PM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 12:24 PM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 08:31 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 08:23 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 06:32 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 06:25 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 06:16 AM
???????????? Prius ???????????????????????????????? This thread Refback 07-25-2011 05:45 AM
davidfl941's Bookmarks on Delicious This thread Refback 04-26-2011 12:11 PM
Prius Problems | Life123 This thread Refback 04-01-2011 12:31 AM
Moteur de recherche : Web, Photos, Videos, Voyages, Encyclopédie This thread Refback 01-08-2011 11:10 AM
Forum Quattroruote This thread Refback 01-07-2011 09:19 AM
davidfl941's Bookmarks on Delicious This thread Refback 12-28-2010 01:42 PM
Moteur de recherche : Web, Photos, Videos, Voyages, Encyclop This thread Refback 09-17-2010 08:33 AM
Prius' woes not limited to brakes - GM Inside News Forum This thread Refback 09-02-2010 05:48 PM
davidfl941's Bookmarks on Delicious This thread Refback 07-14-2010 06:38 PM
Gen III 2010 Prius Main Forum - PriusChat Forums This thread Refback 06-08-2010 11:30 PM
Summary of problems reported on Prius 2010 - Page 22 - PriusChat - www.hadooban.com This thread Refback 05-31-2010 12:28 AM
Mi Toyota Prius - Lista de pegas que se han reportado en el 3G/USA - Prius 3G - 2009/2010 This thread Refback 05-24-2010 07:45 AM
Prius to TDI summary from Bob, and thanks Bob Allen Gen II Prius Main Forum 9 07-01-2011 11:59 PM
My 2010 Prius Causing Me Back Problems! Steve Cebu Gen III 2010+ Prius Main Forum 110 10-21-2010 06:02 PM
Prius Owner Summary (new document) john1701a Gen II Prius Main Forum 13 10-23-2008 04:47 PM
PRIUS+ Technical Summary updated and available felixkramer Gen II Prius Main Forum 1 05-19-2004 09:16 AM
Summary - Sunnyvale Toyota Prius Workshop II vintagebob Gen II Prius Main Forum 7 05-14-2004 03:28 PM
