Releasing Cruise Control with Brake
| | #51 | |
| Senior Member Join Date: Nov 2009 Location: Austin, TX, USA
My Car: 2010 Prius Model: II Package: No Package Thanks: 780
Friends: 6 | I noticed the heavier pedal as well. I thought it was just another feature of the prius like the joy stick shifter that requires an extra button for park. No big deal on the cruise, I just got used to disengaging with the stalk and tapping my brakes so drivers behind me could see I was slowing. But it is a bigger deal if my brake lights don't go on with the brakes. Do you know if the fix is the same as on the Gen II. I'm going to check with my dealer tomorrow to see if he can adjust my brake lights. Quote:
| | #52 |
| Junior Member Join Date: Nov 2009 Location: Little Rock, AR
My Car: 2010 Prius Model: II Package: No Package Thanks: 0
Friends: 0 | Update: I brought my 2010 Prius II to a second dealer and they said the same thing as the first dealer. After keeping my car for a few hours, they told me that it was working exactly as designed and that there was nothing they could do to adjust the travel in the brake pedal with reference to releasing the cruise control. I told them that it could become a safety issue especially while driving up a steep hill with the cruise control set. The car actually fights to speed up while depressing the brake pedal until it either abruptly slams on the brakes -- throwing everyone forward in the process -- or you release the brake pedal completely without the CC disengaging, resulting in unintended acceleration. They just repeated that nothing could be done to adjust the pedal or switch. I am expecting a return call from Toyota on Tuesday, 1-19-10, regarding this issue. I will keep pressing them until I receive a satisfactory response. I will keep posting any updates to this forum as I receive them. -Troy |
| | #53 | |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 208
Friends: 1 | Quote:
I think the fact it is hard to get to may be the reason so many service departments are telling us that "it looks fine to us" or worse yet "there is no way to adjust it". | |
| | #54 |
| Senior Member Join Date: Aug 2009 Location: Cobourg, On, Canada
My Car: 2010 Prius Model: N/A Package: Premium w/ Solar Cells (Canada) Thanks: 8
Friends: 1 | Every car is different, so I wish people would learn how drive their cars I drive 3 different makes, they are all different It just every operating system is different, but basic does the same thing It just like a design build job of a building, no two group of engineers will come up with the same design, but they started out with the same requirements LEARN YOUR CAR |
| Thanked by: | DaveShepherd (02-17-2010) |
| | #55 |
| Junior Member Join Date: Feb 2010 Location: Castle Rock, CO
Friends: 0 | OK, based on another thread on this forum, I found it incredibly easy to adjust the sensor, but I'm curious why Toyota would have it so ridiculously insensitive to brake pedal input. Anyway, if you have two working hands, a phillips screwdriver and a flashlight, you can do the adjustment all by yourself. Really, or pay me $100 and a plane ticket and I'll do it for you. Anyway, the procedure is: you remove the dash panel that has the tire pressure adjustment switch (2 phillips screws and a push release (plus the release for the wires for the switch)). Then you look under there at the brake pedal. Toward the rear of the car you'll see a green switch body going into a brown holder on some other metal brake holder thingy. Push the brake down and toggle with the white solenoid to verify this is what you want to adjust. Once you've verified this, it's as easy as rotating the green thingy counterclockwise a quarter turn, moving it out a smidgen, and then rotating it clockwise to get the setting you want. Verify by sitting in the drivers seat and hitting the brake pedal to make sure where you want the brakes to light up at. Take a test drive, verify the cruise shuts off when desired and then button it all up and be on your merry way. Too easy. Cheers! Bryce |
| Thanked by 7 Users: | austingreen (02-28-2010), bwilson4web (02-28-2010), jayvee (03-11-2010), jferris33 (08-02-2010), odaigle (03-02-2010), tumbleweed (03-01-2010), xs650 (07-31-2010) |
| | #56 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 783
Friends: 31 | Quote:
Bob Wilson | |
| | #57 |
| I like Prius Join Date: Apr 2008 Location: NorCal
My Car: 2011 Prius Model: Three Package: No Package Thanks: 741
Friends: 10 | Probably covered by someone else, but I pull the stalk towards me to cancel, take over the gas pedal, then maybe turn off the CC. |
| | #58 | |
Friends: 1 | Quote:
Mine was adjusted for about 1.2 cm of pedal travel before it activated; after the adjustment it is about .5 cm. Now I can release the CC with the brake pedal before the brakes are applied and cars behind me will see brake lights as soon as I push the pedal down. Much better.
__________________ Tom | |
| | #59 | |
| Senior Member Join Date: May 2009 Location: Ark
My Car: 2010 Prius Model: II Package: N/A Thanks: 200
Taking off the dash panel and rotating a green thingy. That's so cool. That's so Old School. That's so . . . So . . . So ANALOG! | |
| brake, control, cruise, releasing |
| Installing cruise control in base model. Wrong brake switch? | Frayadjacent | Gen II Prius Modifications | 8 | 08-13-2009 06:44 PM |
| Optimum Cruise Speed with Cruise Control engaged | ronhowell | Gen II Prius Technical Discussion | 22 | 06-21-2009 08:17 AM |
| hi, i am new here.. need some help for cruise control | chillabolic | Gen II Prius Technical Discussion | 10 | 03-27-2008 09:49 AM |
| is my cruise control right? | hoop | Gen II Prius Main Forum | 19 | 10-18-2007 04:08 PM |
| Cruise Control Outta Control? | Skarka | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 07-04-2005 11:00 PM |
