Poll: Are Prius brakes a problem?
| View Poll Results: Experience with Prius braking | |||
| 2010 Prius - have one and no brake issue (one answer) | | 57 | 33.33% |
| 2010 Prius - about once per month (first answer) | | 23 | 13.45% |
| 2010 Prius - about once per week | | 12 | 7.02% |
| 2010 Prius - about once per day or trip | | 5 | 2.92% |
| 2010 Prius - scary, safety issue (second answer) | | 18 | 10.53% |
| 2010 Prius - can live with it | | 24 | 14.04% |
| 2010 Prius - no big deal, not a risk | | 29 | 16.96% |
| 2004-09 Prius - have one and no brake issue (one answer) | | 24 | 14.04% |
| 2004-09 Prius - about once per month (first answer) | | 9 | 5.26% |
| 2004-09 Prius - about once per week | | 2 | 1.17% |
| 2004-09 Prius - about once per day or trip | | 3 | 1.75% |
| 2004-09 Prius - scary, safety issue (second answer) | | 0 | 0% |
| 2004-09 Prius - can live with it | | 6 | 3.51% |
| 2004-09 Prius - no big deal, not a risk | | 24 | 14.04% |
| Multiple Choice Poll. Voters: 171. You may not vote on this poll | |||
| | #101 |
My Car: 2010 Prius Model: III Package: #1 Thanks: 783
Friends: 31 | |
| | #102 | |
Friends: 31 | Quote:
I've never felt the regen transition with out 2010 (ZVW30) Prius. As for the braking anomaly, I've found one pot hole that has a momentary, very fleeting, effect that I can detect but not quantify. In fact, if it weren't for the braking threads, I wouldn't have even noticed it. I continue to try and replicate the symptoms. Without some way for everyone to be able to replicate the problem, it remains an 'intermittent' problem. These are maddening to address because the engineering team (even NHTSA) can't apply normal engineering practices to diagnose it. "Shouting" is not a symptom ... it takes rubber on road. So far, all of the reports are beyond my day-trip comfort zone. So far, I've not been able to find a road rough enough with the right pattern to replicate anything but a momentary, fleeting impression. I'm not doubting the reports of others but reporting I can't replicate it, yet. Bob Wilson | |
| | #103 | |
| Senior Member Join Date: Jun 2004 Location: Frankfort, Illinois
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 6
I agree with everything you said above (except the part about a G2 Prius not having a lapse of regenerative breaking under 5 MPH - my wife and I both have felt this on occaision in our 2005 when we had it) as I've only had one experience in our new 2010 that I think is even close to what others are saying and for me it was a non-event. I'm going to keep trying to get the car to do this when I drive it (usually on weekends). Mike | |
| | #104 | |
| Junior Member Join Date: Sep 2009 Location: Massachusetts
My Car: 2010 Prius Model: II Package: Base Thanks: 0
I was able to regain braking control by releasing the brake entirely and then slamming back down on the brakes again, but it was quite startling, and I'm just glad that I figured it out in time to miss sliding out into the intersection! ![]() Take care, --Sherri, otherwise happy 2010 Prius owner | |
| | #105 | |
Friends: 31 | Hi Sherri, Nice first post: Quote:
![]() We've got over 20 and counting locations and images. If you want to add one or more that would be good with me. Thanks, Bob Wilson | |
| | #106 |
| Senior Member Join Date: Sep 2009 Location: Toronto, Canada
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 19
Friends: 0 | Its happen to me 3 times only over the 5 months that I owned the car. 1 of them was quite scary on the highway. To reproduce the problem, you have to travel at a constant speed not too slow and the brake have to be applied slightly and continuely (Slowly slowing down). There must be another car closely in front of you in order get the out of control feel. When you go over the potholes your car will lost the brake for a split second and you will feel like you dat forward and going to hit the car in front. |
| | #107 |
| Member Join Date: Apr 2009 Location: Sanford NC
My Car: 2008 Prius Model: Package: #4 Thanks: 26
Friends: 1 | I will say after working in the auto repair industry for over 30 years that new technology is always un-nerving for consumers and technicians. When ABS brakes were first introduced in the US, we had a constant stream of customers, who did not trust their dealer when they were told the brake pedal was supposed to push back at them and they shouldn't be able to lock up the brakes. We spent many hours of our time re-educating our customer to trust the technology. Since the late 70s, ABS feel has changed very little from one make to the next, even though the methods have varried greatly. When I first began studying the Gen3 Prius, I was immediately impressed that someone was finally trying to do away with all the noise and pedal pulsing associated with an ABS system, but I also thought, "here we go again" on re-educating our customers. We have talked to many since the news media and our government has taken aim at Toyota and not one has failed to stop their car as expected. I think the sensation of feeling like the car is not doing anything creates an immediate sense of panic, but is probably not causing the vehicle to stop any slower than it could normally. With the old system, the solenoids would immediately give you feedback in the pedal that something was happening before the brake pads were engaged, but we have lost that feedback with the new design. I think this is a good thing, but it will certainly take some getting used to. I am also concerned greatly with the level of attacks being leveled at Toyota given the scale of their failures and their quick response. Are we trying to "level the playing field" a little? GM had a big problem with brakes on their front wheel drive cars starting in 1980 that would cause the rear to lock up and send the car into a skid. This continued to be a problem for at least 10 years, even though there had been many accidents and deaths associated with the failures. During that time, the media and the government were pretty quiet about it. I guess we lived in a different world then, but it is food for thought. This is just my opinion and I am not trying to dismiss or disrespect anyone over this issue. |
| Thanked by: | qbee42 (02-05-2010) |
| | #108 |
| Junior Member Join Date: Feb 2010 Location: Sheffield, UK
My Car: 2010 Prius Model: III Package: N/A Thanks: 0
Friends: 0 | Has anyone tried replicating this scenario but not changing the pedal position when it happens. Both times that it's happened to me instaict takes over and I hit the pedal hard. It would be interesting to see what happens if the driver didn't do this, would the brakes still reapply??? |
| | #109 | |
| My other car is a boat Join Date: Mar 2006 Location: Northern Michigan
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 1,354
Friends: 19 | Quote:
There are some bad apples; people and companies that try to cheat. They deserve to get smacked. However, for the rest, we need a little more tolerance and a whole lot less hysteria. Tom
__________________ Black 2006 package #7 Northern Michigan Last edited by HTMLSpinnr; 02-05-2010 at 09:09 AM. Reason: language | |
| Thanked by 3 Users: |
| | #110 | |
Yep, I realized after posting and then reading the entire thread that I'd jumped the gun a bit (as well as bringing back a mostly dead thread...sorry about that, all). What a first impression to make! Thanks for being understanding despite my newbieness. I will have to see if the pothole/bump is still there; this happened months ago, and I really just chalked it up at the time to "interesting albeit spooky Prius quirk" and have just been watchful since then. It was only yesterday when I started reading about the investigation that I said "Oh wow, that sounds exactly like what happened to me!" and decided to go to PriusChat to see if others had seen it too. I didn't realize that it was such a polarizing topic! Trust me, I'm not a Toyota or a Prius hater. I love my 2010! Makes our summer drive to North Carolina from snowy New England more fun again. I do wish that this investigation didn't hit at the same time as their other massive recalls, Toyota is going through a very hard time right now. Take care, --Sherri | |
| brakes, poll, prius, problem |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/74199-poll-prius-brakes-problem.html | ||||
| Open Site Explorer | This thread | Refback | 09-16-2011 12:22 PM | |
| prius brake problem | This thread | Refback | 07-22-2010 12:19 PM | |
| Prius Brakes Problem ~ Latest News On Toyota Having Problem With Brakes | This thread | Refback | 07-19-2010 05:47 PM | |
| 2010 Prius Recall | Fixing Cars | This thread | Refback | 05-19-2010 01:06 AM | |
| Problem with rear brakes...No pressure when bleeding | chickscleo | Gen II Prius Technical Discussion | 25 | 08-02-2010 08:16 PM |
| Brakes - 2008 16K miles Need New front Brakes!!!! | pnw | Newbie Forum | 19 | 02-16-2010 10:42 PM |
| Refueling problem poll for all Prius owners | qbee42 | Gen II Prius Care, Maintenance and Troubleshooting | 47 | 10-22-2008 07:41 AM |
| What do you think about starting this ancillary poll to the extended warranty poll ? | sas0611 | Gen II Prius Main Forum | 2 | 07-25-2008 10:21 PM |
| Regenerative brakes versus friction (regular) brakes | impreza | Gen II Prius Main Forum | 31 | 04-16-2004 09:18 AM |
