| This is a discussion on Fog Lights: Install [Retrofit] fog lights on 2010 Prius? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Will someone who's posted on page 1 of this thread please edit their post to include the basic info? "if ... |
| View Poll Results: Fog Lights: Do you want Fog Lights? | |||
| Yes - Would like Fog Lights that are not available with my Prius configuration. | | 270 | 78.95% |
| No - I do not care about Fog Lights. | | 9 | 2.63% |
| No - But I do not like the rubber "blanks" in the front bumper where the fog lights would be. | | 50 | 14.62% |
| N/A - My Prius is configuration V [1229] and comes with fog lights. | | 21 | 6.14% |
| Multiple Choice Poll. Voters: 342. You may not vote on this poll | |||
| | #441 |
| Member Join Date: Sep 2009 Location: Lakewood, CA
My Car: 2010 Prius Model: II Package: Base Thanks: 0
Friends: 0 | Will someone who's posted on page 1 of this thread please edit their post to include the basic info? "if you'd like to add fog lights on a 2010 prius here are your choices X. if you want to go X method, you need to buy these parts from this place..... Y. if you want to go Y method, you need to buy these parts from this place..... Z. if you want to go Z method, you need to buy these parts from this place..... and finally here's how to wire it: on with lights:......... on with parking lights:.......... on via switch:................... " its a lot of work, but maybe someone on here wants it bad enough to do the legwork? |
| | #442 | |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 121
Friends: 2 | Quote:
| | #443 | |
My Car: 2010 Prius Model: N/A Package: N/A Thanks: 34
OBTW - if that post means you really follow through - then it means it fits into the 5% - not 95%... Thank you in advance!!!! | |
| | #444 | |
| Senior Member Join Date: Jul 2009 Location: Worthington, Ohio
My Car: 2010 Prius Model: III Package: Navigation Thanks: 7
Jim | |
| | #445 | |
| Senior Member Join Date: Jun 2009 Location: Houston, Tx
My Car: 2010 Prius Model: III Package: Solar Roof Thanks: 0
Friends: 1 | Quote:
| | #446 |
| Dr Curious Join Date: Aug 2009 Location: Louisiana
My Car: 2010 Prius Model: II Package: No Package Thanks: 142
Friends: 0 | It is indeed installation error. I only removed he grey cover and then put the OEM covers with the fog light. I never touched the turn signals. |
| | #447 |
Friends: 2 | The mod is going pretty well considering. The fog covers and lights installed easily in about 1/2 hour including the light wiring harness. No gaps between the turn signal and the fog covers. They look so much better than the inserts! Spent about 3 more hours getting wires though the firewall. Need to put the dash back together and zip tie everything up. |
| | #448 | |
| Member Join Date: Aug 2009 Location: Seattle, WA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 25
have a gap between the two lights. Also, make sure the turn signal wiring is out of the way - it can end up interfering with the fog light housing and preventing it from completely snapping into the bumper. | |
| | #449 | |
Friends: 1 | Quote:
| | #450 |
Friends: 0 | Is it an absolute must to remove the dash in order to install foglights? |
| 2010 1227, 2010 fog, 2010 iv, fog lights |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/62652-fog-lights-install-retrofit-fog-lights-2010-prius.html | ||||
| Prius Fog Lights - Overview : Kosmix | This thread | Refback | 11-20-2009 12:37 PM | |
| Hits - morSpeed Performance Products | This thread | Refback | 08-16-2009 11:32 AM | |
| 2010 Prius, RDS? DRL? Fog lights? | KlumzyDriver | Gen III 2010 Prius Main Forum | 37 | 10-01-2009 02:02 PM |
| i want to install fog lights on 2008 prius | jdjord2 | Newbie Forum | 14 | 06-04-2009 01:59 PM |
| 2010 Prius Rear Badge Lights Up ? | MarkPressey | Gen III 2010 Prius Main Forum | 5 | 01-01-2009 03:38 AM |
| HID LIGHTS can you install later | takefoto | Gen II Prius Technical Discussion | 6 | 03-30-2008 07:06 PM |
| Prius Always-on lights, fog lights and rear hatch openers | bogeybob513 | Gen II Prius Main Forum | 8 | 10-23-2006 05:13 PM |
