| This is a discussion on 2010 Torque is 104 vs 2009's Torque is 295? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I saw review said that 2009 Prius has 2 electric motors that can generate an huge 295 in torque. 2010 ... |
| Senior Member Join Date: Aug 2009 Location: Irvine
My Car: 2010 Prius Model: II Package: No Package Thanks: 25
Friends: 0 | I saw review said that 2009 Prius has 2 electric motors that can generate an huge 295 in torque. 2010 is only spec'ed at 104? What's story? |
My Car: 2006 Prius Model: Package: #7 Thanks: 367
Friends: 14 | With the 2010 MG2 is geared. The new MG2 spins at a higher speed, allowing for more torque and power at the wheels, while having less torque itself. Tom |
Friends: 0 | |
Friends: 14 | MG2 is Motor-Generator 2, which is the main electric motor in a Prius. MG1 is a smaller motor/generator which is used principally to spin the engine (ICE), or keep the engine from spinning. When you look at the total torque for a Prius, you are mostly looking at MG2 and the ICE. It gets a bit more complicated when you look at the details, since a portion of the ICE's power is always sent through MG2, but on the surface you can think of MG2 and the ICE each pushing the car forward. As for gearing and torque, gearing can amplify torque while reducing speed, or the other way around. A small, very fast engine can produce the same power as a slow, large engine. If a lot of torque is needed, the small fast engine will need to be geared down, which is like driving in a lower gear. That's what is happening with the new 2010: MG2 is smaller and faster. Overall it is more powerful, but it gets its power through speed and not torque. The gearing converts this speed to useful torque. The long and the short of it is that the 2010 has a more powerful electric motor. Tom
My Car: 2004 Prius Model: Package: #9 Thanks: 102
Friends: 41 | MG=Motor Generator MG2 is the main drive motor and main regenerative motor in one. MG1 is connected to the ICE and acts as the 'starter' for the ICE and the generator to feed energy to the battery. |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 370
Friends: 26 | We thought it was a typo too but it turns out because of the larger 1.8 litre, it doesn't need to put out as much torque so the MG2 could be made smaller and lighter. |
My Car: 2010 Prius Model: N/A Package: G Thanks: 37
Friends: 11 | As Tom posted, the 2010 MG2 is now geared. The absolute torque comparison means nothing. Following is a copy of my post. ----- Gen2:295lb-ft(MG2 torque) X 4.113(final gear ratio) = 1213lb-ft(torque at wheels) Gen3:153lb-ft(MG2 torque) X 2.636(reduction gear ratio) X 3.267(final gear ratio) = 1318lb-ft(torque at wheels) Ken@Japan |
Friends: 14 | Quote:
![]() Tom | |
| Thanked by: | OZ132 (09-01-2009) |
| Senior Member Join Date: Nov 2008 Location: Hendersonville
My Car: 2009 Prius Model: Package: #5 Touring Thanks: 145
Friends: 2 | Quote:
This is a simple mechanical concept. This is a simple mechanical concept. This is a simple mechanical concept. | |
My Car: 2006 Prius Model: Package: #3 Thanks: 211
Friends: 63 | Gen2: 295 lbs-ft (no SRU) Gen3: 403 lbs-ft with SRU SRU - Speed Reduction Unit |
| 104, 2009, 2010, 295, torque |
| MG Torque Vs. ICE Torque? | OZ132 | Gen III 2010 Prius Technical Discussion | 7 | 09-01-2009 10:05 AM |
| Spoiler Torque? | GasSaver1 | Gen II Prius Technical Discussion | 6 | 08-09-2009 10:22 PM |
| Torque???? | Locust43 | Gen II Prius Technical Discussion | 11 | 11-03-2006 01:06 AM |
| Torque Specfications? | Salsa Red | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 02-12-2006 09:44 PM |
| Prius Torque | habel | Gen II Prius Main Forum | 18 | 11-27-2005 12:19 PM |
