| This is a discussion on Using head lights during the day within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Does anybody know if there is a way to use the head lights without having the dash dim or the ... |
| Junior Member Join Date: Sep 2009 Location: Seattle
Friends: 0 | Does anybody know if there is a way to use the head lights without having the dash dim or the Nav system go into night mode? I prefer driving with my lights on all the time, especially on rural two lane roads. Unfortunately, during the day, my dash is too dim then and the nav system goes into night mode. I talked to a Toyota rep who said some states have a law preventing head lights during the day (I suspect that is not true). I believe this is a safety issue, being able to use the head lights during the day. Anybody figured out a way around this limitation? |
| Senior Member Join Date: Apr 2009 Location: Northern, IL
My Car: 2010 Prius Model: III Package: Navigation Thanks: 0
Friends: 0 | never heard about it not being safe to have headlights on during day. That sounds crazy. To answer your question. To the left of the steering wheel should be the intensity control. Just roll it all the way up, and it will over ride the nighttime mode |
| BobPrius Join Date: Jul 2009 Location: Buffalo
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 9
Friends: 1 | Sure thing. Your lights are AUTO OFF just in case you did not know that. On the left lower part of your dash is a roller switch that controls the intensity of the dash lights when the headlamps or parking lamps are lit. Roll it to the very top (Detent positon) in other words full up position. Your dash lights and Nav will be an normal full brightness.... When you turn off the car, the headlamps will go out in 30 seconds as set as a default. |
Friends: 1 | Quote:
| Gotta love the game... Join Date: May 2009 Location: Leiden, The Netherlands
My Car: 2010 Prius Model: I Package: N/A Thanks: 14
In some European countries it is mandatory to have lights on during the day for safety reasons. | |
| Tsar of all the Rushers Join Date: Apr 2009 Location: Greenwood MS USA
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 17
Friends: 3 | The OP is in Seattle WA USA, and the reply is from Buffalo NY USA, it is likely their cars are made to the same Government Standards. Your reply shows you in Leiden, The Netherlands, which may well use different Government Standards. |
Friends: 0 | How is a dashboard light dimmer switch subject to government regulation? |
Friends: 3 | U.S. Department of Transportation / Search Finds 24 references to Dashboard dimmer switch at dot.gov, I am not as good finding Dutch government regulations. So far as I know, our Department Of Transportation does not let any US citizen adjust the height of the headlight beam while driving. (we are allowed High and Low beams, on a stalk, but they are not manually adjustable) Last edited by JimboPalmer; 09-03-2009 at 07:30 PM. |
| The Following User Says Thank You to JimboPalmer For This Useful Post: | anne1965 (09-05-2009) |
| awaaay Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2004 Prius Model: Package: Base Thanks: 47
Friends: 63 | In some countries, like Canada for example, DRLs (daytime running lights) are mandatory. I know from experience they make a big difference to the visibility of motorcycles, and to cars. I can't imagine why anyone would think they're more dangerous. |
| day, head, lights |
| Head Lights | Rmutzabaugh | Gen II Prius Main Forum | 1 | 04-12-2008 12:42 PM |
| Wanted to install new head lights | mrohde | Gen II Prius Modifications | 6 | 10-30-2007 08:13 PM |
| LEDs in the Head lights? | Baalphire | Gen II Prius Main Forum | 8 | 01-20-2007 10:47 PM |
| Head lights/ tail Lights don't work | hikerdave | Gen II Prius Main Forum | 5 | 04-13-2006 08:34 AM |
| HID Head Lights Problem, Please Help!! | kdr008 | Gen II Prius Care, Maintenance and Troubleshooting | 25 | 07-05-2005 10:12 PM |
