This is a discussion on Noise during hard braking? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I have noticed a somewhat strange sound upon moderate to hard braking, such as coming to a stop coming down ...
Old 10-09-2009, 01:08 PM   #1
jayvee
Package: Navigation
Default Noise during hard braking?
I have noticed a somewhat strange sound upon moderate to hard braking, such as coming to a stop coming down a steep hill, or on more sudden stops. The only way I can describe it is the sound of thick rubber on metal - kind of a very short, low pitched "groan" or "grunt".
It happens just before the vehicle comes to a complete stop. For this reason, I suspect that it might be the regenerative braking disengaging right before the vehicle fully stops.
Is anyone else experiencing this type of noise? I have no history with previous gen Priuses, so I'm not sure if this is normal for the regen brakes.
Thanks!
jayvee is offline
Old 10-09-2009, 01:16 PM   #2
djasonw
Default Re: Noise during hard braking?
I think what you may be hearing is precisely what you described. It is more pronounced in the pre 2010 models. When you are slowing down normally and then get to say 10mph or so there seems to be a sensation of secondary braking power. The noise you may hear is the transition from regenerative to the actual standard brakes kicking in. Please correct me if I'm wrong.
djasonw is online now
Old 10-09-2009, 01:33 PM   #3
jayvee
Package: Navigation
Thanks for the reply - It doesn't occur when I'm moving that fast (although I think I know the sensation you describe) - it's only in the last foot or two before the vehicle is completely stopped. I'm going less than 1 mph at that point.
jayvee is offline
Old 10-09-2009, 01:34 PM   #4
Bobsprius
BobPrius
Model: V
Package: Adv. Technology
Jayvee,
I believe the sound your hearing is what you have described. There are a lot of "New" sounds you will eventually aclimate to in time, once you have heard them. But the sound that you describe sounds to be the Regen Braking taking place before Friction Brakes are in full swing. It's doesn't sound abnormal to me. You can learn a lot as well by watching your monitor and seeing your in regen with the recharge in the monitor...
Bobsprius is offline
Old 10-09-2009, 01:46 PM   #5
jayvee
Package: Navigation
Thanks Bob,
See my last post - it isn't when the regen brakes engage (at speeds >5 mph or so, as you describe) - it seems to be when they are releasing, a fraction of a second before the vehicle has come to a complete stop. (Think of the sound of a metal bumper car glancing off a rubber bumper on the track. Sorry, trying to find a way to describe this sound...) That's the sound, short and low-pitched, and right before the vehicle stops. It really sounds a bit concerning - but it may be totally normal sound when the regen brakes disengage during hard braking....
jayvee is offline
Old 10-09-2009, 01:49 PM   #6
Bobsprius
BobPrius
Model: V
Originally Posted by jayvee View Post
Thanks Bob,
Sounds like your trying to describe a "groan" of the brakes, or RUBBING sound...Hmmmmm I have not noticed it my 2010, but then again, I have not experienced the backup brake issues. Do you think it is something with the Discs and needing adjustment??? I believe I understand now what your hearing I will have to listen to mine as well. Do you notice this with windows open and between cars/buildings to hear the resounding noise, or do you actually hear it in your car???? Do you feel you are applying the brakes hard or more moderate in the last seconds? I wondered since I will try it with my car on the way to work this afternoon and see if I can reproduce. I will also try in the lot tonight and let you know...
Old 10-09-2009, 02:31 PM   #7
jayvee
Package: Navigation
It's not a "rubbing" or "groaning" sound - it's a short burst (0.1 second or so) - and almost a rubbery "clunk" sound (man, this is hard to describe... maybe I will try to post an audio file of the sound.....hmmm...) And yes, it really only is present at the very end of moderate to hard braking. Windows closed, I hear it IN the car. Sounds like it's coming from the engine compartment or the brakes.
I honestly don't think it has anything to do with the discs. It's not a metallic scraping or rubbing sound. It actually sounds a bit like loose/damaged engine mounts used to sound in older cars. But I don't think that's what this is - I'm sure the engine mounts are nothing like they used to be. Like i said, this might just be what the regen brakes do at the end of hard braking.
Anybody else hear anything like this?
jayvee is offline
Old 10-09-2009, 03:05 PM   #8
Thanks Bob,
<snip>
This is what Bobsprius is saying. You may want to reread his posts.
Old 10-09-2009, 07:40 PM   #9
jayvee
Package: Navigation
Well, I thought I did read his posts carefully. They said this:
My sound takes place long after the friction brakes are fully applied. The vehicle is at almost a dead stop. And:
It is neither groaning or rubbing. It's a short burst of sound. Can you tell me what you are suggesting I'm missing in Bob's response (which I very much appreciate, by the way!)
Thanks!
jayvee is offline
Old 10-17-2009, 03:56 AM   #10
maxjlone
My Car: Other Hybrid
Package: Touring Package (Canada)
I have 9,200 miles on my 300C Heritage and while at the Dealer (my Dealers name has changed, still selling DCX) getting my free oil change I told the Service guy I had a grind/clunk noise when brakeing, got the 23 point inspection, they found nothing, no charge.
maxjlone is offline
braking, hard, noise
Disturbing body twist while braking hard NeoPrius Gen II Prius Main Forum 4 09-03-2008 11:31 AM
noise when braking, even when engine is off TonyD50 Gen II Prius Care, Maintenance and Troubleshooting 8 08-11-2008 07:49 PM
Strange noise when braking?? Bikeman Gen II Prius Care, Maintenance and Troubleshooting 11 04-16-2008 09:48 PM
Whirring noise while braking?? BethlehemPrius Gen II Prius Care, Maintenance and Troubleshooting 4 07-12-2007 11:05 PM
Wa Wa Noise / Hard Steering Noise Fibb222 Gen II Prius Care, Maintenance and Troubleshooting 4 03-14-2007 05:49 PM
