| This is a discussion on Battery Not Full ?? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Got about 1100 miles so far batt. indicator has never been full all bars on, just today moved up a ... |
Battery Not Full ??
| Junior Member Join Date: Sep 2009 Location: medford ma.
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 0 | Got about 1100 miles so far batt. indicator has never been full all bars on, just today moved up a total of one higher but still one or two bars to be full ,is it braking in, cycling etc. book says all bars should top out???....... I love this car......... |
| Tsar of all the Rushers Join Date: Apr 2009 Location: Greenwood MS USA
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 17
Friends: 3 | My Prius normally leaves room for more regen, but rarely I will do a ton of braking after a 50 mile cruse and get it to go green. But mostly you always want room to do more regen, so you hope it never tops out. |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 21
Friends: 9 | Unlike my 2006 where I could often fill the battery to the top, I only did this once in my 2010. It doesn't matter though... I can definitely stay in battery electric only much longer in my 2010 so it not 'filling up' to the top on the display really means nothing... |
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 22
Friends: 0 | On my 2010, I have seen it fill on up all bars only when using regenerative braking while descending hills of at least several hundred vertical feet. When the road flattens out, it is fairly aggressive about burning off the top two bars to make some room for the next descent. Driven normally, it should never fill up on the flats because this would preclude any regenerative braking on mountain descents, which some of us drive frequently. But you might be able to trick it into filling up more with a series of regen stops from high speeds. I see no point in even trying. |
| Senior Member Join Date: Dec 2006 Location: Pennsylvania USA
Friends: 0 | If it's anything lke the '07, the onboard computers will keep the battery state of charge between 40 to 80%. normally, 80% will ot show full bars. Likely there's no problem. |
Friends: 0 | As lenjack says, the Prius tries to avoid ever having the battery full or empty. And in fact, the icon on the MFD only represents part of the battery, since it will never go below 40% or over 80% of the battery's actual capacity. It maintains these limits to extend the battery life, and is the reason your battery will outlast the life of the car. (Unfortunately, this only applies to the big traction battery. The little twelve-volt lead-acid battery will probably have to be replaced once every four years or thereabouts, the same as the 12-v battery on any other car.)
__________________ Daniel Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph. Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power. Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius. "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck |
| The Following User Says Thank You to daniel For This Useful Post: | LoveMyPriusIII (10-10-2009) |
Friends: 8 | As everybody wrote, Prius is trying to keep the charge level to the target SOC (state of charge). So, it does not want to be full. Ken@Japan |
| Senior Member Join Date: May 2009 Location: Springfield Missouri
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 197
Friends: 2 | Quote: Our V, which is typically driven short duration commutes (seldom more than 7-9 miles round trip), my wife informs me stays at or near the Top Bar almost continuously. Live in a flat area, with normal driving speeds around 30-50 MPH (but probably only average around 20-25). Anything to be concerned with? David (aka Blind Guy) | |
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Quote:
Tom | |
Tom | |
| The Following User Says Thank You to qbee42 For This Useful Post: | Blind Guy (10-10-2009) |
| battery, full |
| Braking. What happens after the battery is full? | rposton | Gen II Prius Main Forum | 14 | 10-15-2009 10:51 PM |
| My battery still stays too full | echocanyon | Gen II Prius Technical Discussion | 15 | 05-23-2008 03:06 PM |
| Never witnessed full battery ('08) | amnon | Gen II Prius Main Forum | 26 | 12-13-2007 12:28 AM |
| Charging HV Battery to MFD full SOC | Presto | Gen II Prius Main Forum | 10 | 08-29-2006 11:02 AM |
| Is Full Green Battery Bad? | shocker | Gen II Prius Main Forum | 12 | 10-08-2004 04:34 PM |
