This is a discussion on Weird buzzing and soft whine when parked within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Here's a weird one that I searched for in the forums but could find nothing on. I parked the car, ...
Old 10-14-2009, 03:56 PM   #1
asj2009
Default Weird buzzing and soft whine when parked
I parked the car, switched it off, and remained inside with the key, reading a book.
After awhile I noticed a buzzing sound (kinda like a faroff lawnmower), followed by a soft whine. This repeats itself maybe every 30 sec to 1 minute. I went outside and the sound can be heard if you place your ear next to the vents near the front windshield (although from outside you can't seem to hear the small whine following).
Has anyone else noticed this? What is it? The battery?
asj2009 is offline
Old 10-14-2009, 04:26 PM   #2
asj2009
Default Re: Weird buzzing and soft whine when parked
I checked on the car again after 30 minutes leaving it alone, and this time no sounds as far as I can see. I'll do more tests. For example, leave the car alone until no sounds heard, then come back and stand close with the key.
asj2009 is offline
Old 10-14-2009, 04:32 PM   #3
mr_zorg
mr_zorg's Avatar
It is normal for the car to make some sounds for a while after powering off. Various cooling fans, etc., are hard at work even after you stop. Plus, I noticed your package says you have the solar roof option (which I don't have), so it could be that kicking in and doing its job.
mr_zorg is offline
The Following User Says Thank You to mr_zorg For This Useful Post:
asj2009 (10-14-2009)
Old 10-14-2009, 04:34 PM   #4
morpheusx
Professor Chaos
morpheusx's Avatar
You are likely hearing the brake actuator
morpheusx is offline
The Following User Says Thank You to morpheusx For This Useful Post:
Old 10-14-2009, 09:35 PM   #5
rachaelseven
rachaelseven's Avatar
She's just purring with contentment, enjoying you sitting in her lap
rachaelseven is offline
Old 10-14-2009, 09:39 PM   #6
pinzvidz
I'd say it's your interior fan (solar cooling) doing it's little thing. We've noticed it on the one we had in stock, if left sitting in the yard and unlocked, the fan will go through a cycle. Open the door and sit in the car. You'll hear it start off with a light electrical buzz, followed by sound of interior fan motor, then cuts out. Repeats cycle every 30 seconds or so.
Next time you are in the same scenario, and you hear it, try pressing off your solar switch. It should stop immediately.
pinzvidz is offline
The Following User Says Thank You to pinzvidz For This Useful Post:
Old 10-14-2009, 09:50 PM   #7
Benggolf
Benggolf's Avatar
LMAO! That's a good one.
By the way asj2009, do you have the solar panel on your Prius? The sound you are hearing could be the fan which brings in cooler outside air, ventilating the cabin close to the ambient outside temperature (OAT).
Benggolf is offline
The Following User Says Thank You to Benggolf For This Useful Post:
Old 10-14-2009, 11:04 PM   #8
asj2009
Have to test...it might be this:
Automotive Advice - Auto Repair Questions and Answers: Toyota Prius Hybrid Brake Noise 2004-07
asj2009 is offline
Old 10-14-2009, 11:05 PM   #9
asj2009
Oh man
asj2009 is offline
Old 10-14-2009, 11:07 PM   #10
asj2009
About the solar...yes, I have the solar roof package...might be that, i'll have to test tomorrow...but it was fairly cold outside so i'm not sure that would be triggered...i'll test anyways.
Anyone know where that fan is actually physically located?
asj2009 is offline
buzzing, parked, soft, weird, whine
Inverter or MG whine? 2009Prius Gen II Prius Technical Discussion 3 07-24-2009 08:44 PM
Whine jimnjo Gen II Prius Care, Maintenance and Troubleshooting 5 05-05-2009 02:13 PM
Why does suspension get soft? dgw Gen II Prius Main Forum 4 07-15-2006 10:51 AM
Brake Whine bweston Gen II Prius Main Forum 22 02-13-2006 06:08 PM
soft reset? Tadashi Gen II Prius Care, Maintenance and Troubleshooting 4 05-25-2005 06:37 PM
