| This is a discussion on 2010 brake system within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Hi, Part of problem diagnosis is to understanding the system so we can map symptoms to potential failure modes. The ... |
2010 brake system
| View Poll Results: Details on braking anomoly | |||
| Happens in the beginning of braking | | 13 | 19.40% |
| Happens after braking for a bit | | 53 | 79.10% |
| Had a load in back of Prius | | 1 | 1.49% |
| No significant load in Prius | | 47 | 70.15% |
| Multiple Choice Poll. Voters: 67. You may not vote on this poll | |||
| | #1 | |||||||||||||||||||||||||||||||||||||||||||||
My Car: 2010 Prius Model: III Package: #1 Thanks: 561
Friends: 27 | Hi, Part of problem diagnosis is to understanding the system so we can map symptoms to potential failure modes. The poll associated with this posting is to ask about subtle items that may or may not have any bearing on the brake anomolies. These are just hypothetical mappings but an important step. One of the best source are Toyota's New Car Features:
OVERVIEW The Prius brake system is an integrated system that balances regenerative braking, hydraulic braking, traction control, antilock skid control, and balance into a simple to operate system: ![]() Now one of the symptoms reported is an extended 'loss of braking force.' Considering the curve above, it is likely this is a hydraulic system release. Given the time-scale, this chart suggests the effect occurs in an early braking condition versus a longer, braking interval when regenerative braking force might be a higher percentage. It is a fairly sophisticated system that also adjust braking force based upon the vehicle loading: ![]() So one question is whether or not the vehicles experiencing the braking symptoms may have or not had a load in the rear. SIGNIFICANT ELEMENTS
http://hiwaay.net/~bzwilson/prius/Prius_bump_010.jpgYou can help by posting photos or Google Street view or Google map addresses of the places this happens. The key to diagnosis will be finding a way to replicate the problem at will. Then we can do things like:
Bob Wilson Last edited by bwilson4web; 01-30-2010 at 03:24 AM. | |||||||||||||||||||||||||||||||||||||||||||||
| Senior Member Join Date: Aug 2009 Location: USA
My Car: 2010 Prius Model: N/A Package: N/A Thanks: 18
Friends: 0 | REALLY appreciative that so much energy is going into researching this. FYI, Each time I've had brake loss/pause, there has been zero load in the rear of the car.. One street near me that would cause brake loss almost every time was caused from what I think was a bulge in the road from a tree root while stopping at a stop sign. Shouldn't be too hard to recreate if we can think of a way to create a similar bump in the road. I've since adjusted my driving habits to avoid this but I'll see if I can get the prius toexperience brake loss at that spot later this week and will take some pictures if i can along with speed, brake force, etc.. |
| Senior Member Join Date: Aug 2009 Location: Cobourg, On, Canada
My Car: 2010 Prius Model: N/A Package: Premium w/ Solar Cells (Canada) Thanks: 6
Friends: 0 | the only time I have feel anything funny braking is when I have cruise on, it feels like the car is not stopping And it could be is I am not pressing hard enough on the pedal to dis engage the cruise, as soon as I press harder it starts to brake It think it just a matter of knowing the car better |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 284
Friends: 2 | Interesting... I have never had the breaking issue (that I know of) but then I have never had a payload either... I wonder if that has something to do with it. |
| Member Join Date: May 2009 Location: South Florida
My Car: 2010 Prius Model: V Package: Navigation Thanks: 10
Friends: 0 | Mine happens at a speed bump as I turn into my cul de sac. I just make sure I'm going very slowly, so that I don't have this occur. |
| Prius Pusher Join Date: Mar 2006 Location: Northern Michigan
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 566
Friends: 14 | Keep in mind that there isn't just one braking issue. Among the possibilities are: 1) Sticky brakes in reverse. 2) Soft pedal pressure. 3) Regenerative braking to friction braking transition. 4) ABS. Some issues may be a combination of the above. Compounding and confusing the various issues keeps these threads lively. Tom |
Friends: 27 | Hi, I'm really interested in the slow-speed, stopping anomalies as these are often close to other objects (aka., bumpers, walls, curbs, walkways.) Also, understand I'm using the "New Car Features," NM1291U, and the "2010 Maintenance Manual," EM1291U, as my source materials. I'm not a Toyota trained technician and my reading and interpretation is likely to have unintended errors. But this is my best understanding ... today ... and I appreciate corrective posts so we can all advance our knowledge and understanding. BACKGROUND A non-error code, braking anomaly has been reported by some 2010 Prius Chat members:
Modest braking that passes over a manhole cover, railroad crossing, patched surface, or pothole that leads to a longer period of reduced braking.Survey From Maintenance Manual System architecture: ![]() These are bits that suggest interesting aspects that may apply to our braking system: "Do not remove or install electronically controlled brake system parts such as the steering angle sensor, yaw rate and acceleration sensor or brake pedal stroke sensor except when required, as they cannot be adjusted correctly after removal or installation." (BC-1)I'm still reading the brake section, over 300 pages. But I wanted to start the conversation. More details to follow. Bob Wilson |
| Thanked by: | RAP (02-06-2010) |
Friends: 27 | Hi, Quote:
Bob Wilson | |
| Senior Member Join Date: Apr 2009 Location: Southeast Michigan
My Car: 2010 Prius Model: III Package: No Package Thanks: 139
Friends: 0 | Bob, I checked both at the beginning and after a bit as when I made my repeated attempts to recreate it a couple weeks ago, it didn't seem to matter, but this is a gut feel response to the question as I was not looking to answer that specific question. I also checked no load but that is my normal operation of the car. |
| Member Join Date: Apr 2009 Location: Georgetown Md
My Car: 2010 Prius Model: II Package: Base Thanks: 3
Friends: 0 | I am disappointed in the Prius 2010 ABS. Although the car does stay straight while stopping in slick snow, the ABS only seems to pulse twice a second. My previous car(Benz) seemed to pulse eight times per second- like going over a series of warning speed bumps. At least i can use front wheel drive to power-steer(the Benz was rear wheel drive). Should i add weight to the rear of my Prius? How much weight? We used to put #80 of salt in the front 'trunk' of our Corvairs- balanced the cars well. |
| Thanked by: | Analogkid1958 (02-05-2010) |
| 2010, brake, system |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/75438-2010-brake-system.html | ||||
| 【みんカラ】 プリウスと3G iPhone について調べてみた |ぼやき三毛猫|ブログ|ぼやき三毛猫 - 車・自動車SNS(ブログ・パーツ・整備・燃費) | This thread | Refback | 07-03-2010 10:09 PM | |
| 2010 Prius Brake Failure Complaints Rising | ~C4Chaos | Gen III 2010 Prius Main Forum | 3 | 12-25-2009 09:27 PM |
| Red Triangle, check engine, yellow brake system light | miniracer | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 12-05-2009 07:08 PM |
| Explanation of Brake System | Optimus | Generation 1 Prius Discussion | 7 | 11-02-2009 08:34 AM |
| Parking brake in the 2010 Prius | rsgillmd | Gen III 2010 Prius Main Forum | 22 | 06-24-2009 09:42 PM |
| Brake System, ROTORS | mrbigh | Gen II Prius Modifications | 16 | 11-13-2006 11:18 PM |
