2001 Prius battery problem...replace cells?
Friends: 0 | Hi, I have heard that it is possible to replace the individual cells in the hybrid battery. Is this true? If so, if anyone knows of a place in the central florida area that can test the cells and replace them, I would be forever in your debt : P Other than the Toyota dealer in Gainesville. They are trying to charge $3000 for a whole new battery! I heard they can be replaced for around $100 a cell. Thanks!!! |
My Car: 2010 Prius Model: N/A Package: G Thanks: 51
Friends: 16 | <div class='quotetop'>QUOTE(lutung @ Jul 27 2007, 10:38 AM) [snapback]485867[/snapback]</div> Quote:
Regarding to my experience about NiMH and NiCd battery, they are connected in series and should have matched characteristics, such as manufacturing lot, ages, internal resistance and so on. http://www.tjcells.co.uk/prod.htm Ken@Japan | |
| Member Join Date: May 2007 Location: Akron, Ohio
My Car: 2001 Prius Model: I Package: Base Thanks: 1
Friends: 0 | [quote=ken1784 @ Jul 27 2007, 10:39 AM) [snapback]486092[/snapback]</div> Quote:
Hi, I am in the same boat you are with my 2001 Prius. I have 1 or 2 bad modules as they are called. The cells you mentioned are what are inside the module. [6 x 1.2]] 7.2 volt module. I am searching now to find a way to buy a main battery used, salvaged cheap and remove modules or buy new modules approximately $60 ea. and try to recondition it myself. DO NOT ATTEMPT THIS IF YOU ARE NOT EXPERIENCED WORKING WITH DC AND AC VOLTAGES. Joe | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 783
Friends: 31 | Hi, <div class='quotetop'>QUOTE(lutung @ Jul 26 2007, 08:38 PM) [snapback]485867[/snapback]</div> Quote:
BTW, I saw an Ebay vendor with a battery pack for shipping for about $1.4k earlier this week, which might be another alternative. Of course you'd have a hard time getting the local Toyota dealer to install it. I snagged a battery from a salvage but I plan to do my 'electrical engineering' tricks and make sure the cells are in good shape. Nothing gets changed until I test them all but then, this is my fun and not a business. Just something I like to do. Bob Wilson | |
My Car: 2001 Prius Model: Package: N/A Thanks: 81
Friends: 1 | Obviously, sooner or later someone is going to combine cells from different HV batteries and post the results. Unfortunately, too much will be made out of the success or failure forthcoming. A couple of notes: Submarine battery experience (and there is a lot of that) show that individual cells wear out at different rates due to location in the pack (the edge cells are cooler than the middle cells). At low SOC, the higher performing cells in the pack start "charging" the lower performing cells all the time. To prevent problems, these cells are jumpered out individually till it is time to replace the entire pack. The HV batteries in the Prius are very long lasting, but they do wear out at some point, and one of the mechanisms will be increasing differences in the cell capacities. So I forsee the following: 1) Someone combines cells and is absolutely dogged by SOC variations and constant TOD failures or, 2) Someone gets lucky and has a combination that works (at least till they post). Submarines do replace individual cells, but after matching for similar ages in other cells. So this can be done with the right equipment and knowledge. (i.e. It is better than recycling if only a few cells are very bad). Otherwise just randomly combining cells is assured of having quite a few problems. |
| Junior Member Join Date: Aug 2009 Location: Durham, NC
My Car: 2001 Prius Model: N/A Package: No Package Thanks: 1
Friends: 0 | Dealer just told us our 2001 had one bad cell and wants $3000 for new battery. Wish there was a cheaper option. |
| Senior Member Join Date: Dec 2008 Location: Kingston Ontario
My Car: 2009 Prius Model: N/A Package: C Thanks: 172
Friends: 1 | eBay |
| Junior Member Join Date: Sep 2009 Location: toronto
My Car: 2001 Prius Model: N/A Package: No Package Thanks: 0
Friends: 0 | I have just replaced the whole pack for my 2001 Prius, cost me $4400 after tax and labour, owch! My old battery had one malfunctioning cell I have the whole pack with me and willing to sell it unit by unit, if you know someone who needs a cell let me know, Thanks, |
Friends: 16 | Quote:
The USD price is $2,299 without labor. Toyota Vehicles : Toyota Announces Price Reduction On Prius Hybrid Batteries / Toyota Ken@Japan | |
| Junior Member Join Date: Nov 2009 Location: S.E. Wisconsin
Friends: 0 | Could you contact me about the battery cells you have? thanks |
| 2001, battery, cells, prius, problemreplace |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/35524-2001-prius-battery-problem-replace-cells.html | ||||
| toyota prius battery rebuilt - Google Search | This thread | Refback | 08-30-2010 01:25 PM | |
| rebuild prius battery - Google Search | This thread | Refback | 08-25-2010 04:28 PM | |
| Prius 2001 battery fire | tochatihu | Gen II Prius Main Forum | 22 | 05-19-2009 08:30 PM |
| 2001 prius battery fan questions | statultra | Gen II Prius Technical Discussion | 5 | 08-08-2007 10:59 PM |
| Problem with 2001 prius says not to drive | BowerR64 | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 03-26-2006 07:27 PM |
| Battery efficiency is improving faster than fuel cells | prius04 | Prius, Hybrid, EV and Alt-Fuel News | 26 | 05-17-2005 10:18 AM |
| Accelerator pedal problem 2001 prius | av_in_bc | Gen II Prius Main Forum | 3 | 12-20-2004 02:37 PM |
