| This is a discussion on Problem developed - Triangle! within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; Originally Posted by bwilson4web Where did you get it and how much? Thanks, Bob Wilson I bought it on ebay ... |
| | #11 |
| Junior Member Join Date: Jul 2009 Location: Reading, PA
My Car: 2002 Prius Model: I Package: Base Thanks: 0
Friends: 0 | |
| | #12 |
Friends: 0 | Patrick Wong wrote " I'm wondering what you did to get your car running. Did you replace the traction battery?" I did not replace the traction battery. There is a function on the Toyota Diagnostic tool that allows main battery recharging, but I did not use it due to unfamiliarity. I did it by using the diagnostic tool. I had it plugged in while watching the HV ECU parameters. This allowed the car to idle and charge the battery. I also turned on the A/C to max so the engine would stay running. It worked. Last edited by SpeedyG40; 09-06-2009 at 10:05 AM. |
| | #13 |
Friends: 0 | [QUOTE=mrmose;949939]I replaced the origional 12 volt in my 2001 this past weekend. When I reconnected, I got the following: Red triangle of death, check engine light one bar on gas level (it was fiull) rectangle on MFS with car sign and ! This just happened to my wife's 2002 Prius (90Kmi) (I have a 2002 too-145Kmi). The car was in the body shop for a wife vs. pole incident (small tap). The guy disconnected the battery to work on the damage, then upon reconnecting the car did the same as you described. Now, here is where the fun comes in. The body man called the dealer and the dealer and they said it has to come in and be checked...etc. "nothing else can be done" (not very helpful). The body man just cycled the key and the car fixed itself except for a check engine light. I found Codes P3191 & P3101 which I have gotten a few times on both cars. [I just got a warranty enhancement letter from Toyota regarding this known issue. They say it's most commonly due to a dirty throttle body.] I googled and one site said if you turn on and off 4 times, it will reset. I did this and all but the check engine light went off and the car ran fine. I drove it around the block and the check engine light went off. This is definitely true! This works most of the time, but not always. I have had the screens and warnings stay lit after cycling the key multiple times. While the car ran perfectly, it won't reset itself. This got me home thankfully. My wife drove it to work on Manday and half way there, she got all of the warning lights that I got after the battery replacement. She called me and said the car was running fine and went to work. When she left to come home, she started the car and got all of the warning lights. but the car was running fine and then half way home, she said the brake light also came on and it felt like someone was appplying the brakes. This happened to my wife once. She ran the car out of gas (two bars were still showing) and ran the traction battery (HV battery) down too low. Last edited by SpeedyG40; 09-06-2009 at 10:33 AM. |
| | #14 | |
| Junior Member Join Date: Sep 2009 Location: florida
My Car: 2001 Prius Model: I Package: N/A Thanks: 0
The dealer did not pick up the tab, Toyota paid paid the bill. The new battery has been in the car for two weeks now and I have driven about 300 miles. Milage is only 40 MPG, I use to get 43 MPG. | |
| developed, problem, triangle |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/64973-problem-developed-triangle.html | ||||
| Generation 1 Prius Discussion on PriusChat Forums | BoardReader | This thread | Refback | 10-07-2009 08:34 PM | |
| My Prius has developed a very annoying rattle | jc1745 | Gen II Prius Main Forum | 21 | 10-03-2009 01:45 PM |
| My 08 developed a rattle! | branchero | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 08-21-2008 07:44 PM |
| Red Triangle with "Problem" on the MFD? | randreed | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 09-18-2007 10:20 AM |
| Problem Icon - Exclamation inside triangle | Mary Lou In Ohio | Gen II Prius Technical Discussion | 4 | 09-04-2006 08:34 AM |
| Biodegradable phone is developed | Areometer | Environmental Discussion | 4 | 03-09-2005 10:34 AM |
