| This is a discussion on 2001 prius battery problem and pictures within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; A couple weeks ago, my 2001 prius would drive normally for about 10 miles then decide to go into limp ... |
#1 |
Friends: 0 | A couple weeks ago, my 2001 prius would drive normally for about 10 miles then decide to go into limp mode, turtle light triangle brake light, check engine light. I also noticed that the MFD shows the battery as full, then all of a sudden it would drop to the last "bar" then recharge, that would happen about 5 times then the warning lights come up. This prius was a salvage car restored, roughly 40-50k miles later this starting happening. the vehicle was not covered under any warranty so the battery seal TSB was not performed on this car. I have worked on the HV battery before, with my charger, so I understand the dangers associated with high DC voltage. Today I removed the HV battery from the vehicle and examined the copper plates which were severely corroded. Here is the imageshack gallery: ImageShack Gallery ![]() ![]() this is the area with worst corossion, i recorded the lowest voltage accross on this module, 7.2 volts vs the rest which were 7.8 volts. ![]() heres some questions, would any experts here suggest removing copper plates, cleaning them with a solution and wipe around the positive and negative terminals, then applying a sealant ? also can i use muriatic acid to clean the oxidation off the copper?
__________________ 2005 Toyota Prius Hybrid Package 9 2001 Toyota Prius 2005 Honda Accord Hybrid 3.0 V6 Last edited by statultra; 08-02-2009 at 11:30 AM. |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 9
Friends: 12 | There was a TSB which added sealant to prevent corossion. It's likely your Prius didn't have that work done, but could still benefit. There may be details in the TSB of what to look for and how to deal with it. Sorry, I don't have the number readily available... but someone else may chime in for that. . |
Friends: 0 | I'd say that if the battery terminal posts themselves aren't corroded too badly it's definitely worth cleaning up the copper bar strips and reassembling. Using de-oxit or some other contact cleaner/restorer couldn't hurt, as well as a bit of elbow grease with scotchbrite or something nastier where needed. You're possibly fortunate that the reseal TSB wasn't done, as that makes the second go-round on that job much messier -- then you'd have to soak all the old goo off with acetone or somethibg and then get back down to bare copper. . While the pack is apart into separate modules you can individually load-test and re-equalize each one and determine which if any really have gotten weaker over time. . Hopefully you've got something else to drive in the meantime, as all this might take a while! . _H* |
Friends: 0 | i checked all the batteries with a volt meter, i got the copper plates off and the orange things surrounding it, the terminals itself look really clean. I measured 7.8 volts on all the individual modules except for one, which read 6.5 volts. This set that read this low voltage had some real good corrosion. Luckily i finished rebuilding the accord hybrid in time, so I have that and the 05 prius to drive. I was planning on repainting the 2001 prius and this ruined my plans also I was wondering since each module is 7.8 volts wouldn't that make the total voltage 296? which is considerably too high i think. My guess is the compression was giving the battery ECU a false capacity reading and making the hybrid system charge the battery continuously Last edited by statultra; 08-02-2009 at 01:30 PM. |
Friends: 20 | Quote:
There are two approaches:
| Senior Member Join Date: Jul 2005 Location: Raleigh, NC
My Car: 2004 Prius Model: I Package: #7 Thanks: 9
Friends: 10 | |
Friends: 0 | ok i made a typo, the one that measured 6.5 is located where there was no visible corossion, Im thinking that maybe the corossion could cause varying voltages between the modules. i also checked each module to the battery case, one of the modules, specifically the one that had major corrosion read 2.4 volts to the battery case, the rest of them read 0 volts. the bus bars are removed and i cleaned them and have them sealed until im ready to reinstall, tommorow im probably going to buy some 3m contact adhesive similar to what toyota used for the TSB. im not sure whether or not to keep going with this battery or to purchase a salvage battery |
| | #8 | ||
Friends: 44 | Quote:
Your traction battery ECU may have logged DTC P3009 "high voltage leak" fault code, as well as a DTC related to the failed module pair. Classic salvage batteries tend to be pretty expensive since the demand seems to be greater than supply; while the expected remaining lifetime of the salvage battery may not be too great since it typically will be at least six years old. If you plan to keep your car you might do better buying two 2G battery assemblies and taking 38 modules out of the 56 available to install in your Classic battery case.
__________________ 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. Last edited by Patrick Wong; 08-02-2009 at 10:46 PM. | ||
![]() ![]() The terminals come out of the plastic case and have an O-ring seal. The module on the right, a failed module, had leakage around the O-ring and the photo shows some of gunk used in the sealing TIS. If you get a chance, it would help to get a reading of all modules number 1-38 where 1 is adjacent to the control electronics. This will give a rough indication of how the modules have aged. The electrolyte, KOH, is 'slippery' stuff as it combines with the fats on our skin to make soap. Any that leaks will make a conductive path to ground but the stuff is dang near invisible. The Prius system detects very high resistances under 10 MOHM and declares them to be a fault. It may be worth while to try and measure the DC resistance between the terminal of each module and the case. There is no guarantee but any module that shows a detectable resistance would be one I'd schedule for a through cleaning, drying and wipe down. GOOD LUCK! Bob Wilson | |
My Car: 2008 Prius Model: Package: T3 Thanks: 7
Friends: 0 | 1.2V is actually a very low voltage for a NiMH cell, and approximates to a completely discharged cell. The following chart is for NiCd but NiMH is reportedly similar: ![]() (source) The chart for Gen 2 State-of-Charge reporting looks like this: ![]() (source) 7.8V per module comes to 1.3V per cell, which would appear as four bars while discharging but only two when charging; 6.6V for that module is pretty much dead. I wouldn't say that 6.6V necessarily indicated a shorted cell in that module, it could be more than one cell with low output, but I don't think it would be recovered by charging. |
| 2001, battery, pictures, prius, problem |
LinkBack to this Thread: http://priuschat.com/forums/generation-1-prius-discussion/66436-2001-prius-battery-problem-pictures.html | ||||
| Generation 1 Prius Discussion on PriusChat Forums | BoardReader | This thread | Refback | 09-15-2009 07:26 PM | |
| socialmedian: 2001 prius battery problem and pictures | This thread | Refback | 08-25-2009 12:29 AM | |
| 2001 Prius battery problem...replace cells? | lutung | Gen II Prius Technical Discussion | 9 | Yesterday 06:46 AM |
| 2001 Prius Warning lights and check engine problem | shanerm5 | Generation 1 Prius Discussion | 2 | 07-24-2009 09:52 PM |
| Prius 2001 battery fire | tochatihu | Gen II Prius Main Forum | 22 | 05-19-2009 08:30 PM |
| Problem with 2001 prius says not to drive | BowerR64 | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 03-26-2006 07:27 PM |
| Accelerator pedal problem 2001 prius | av_in_bc | Gen II Prius Main Forum | 3 | 12-20-2004 02:37 PM |
