| This is a discussion on Problem car within the Generation 1 Prius Discussion forums, part of the Gen II Prius Main Forum category; From Volume 1 of the Toyota Maintenance manual: P3120 - HV Transaxle Malfunction (with these subcodes) 234 - small reduction ... |
Problem car
| | #11 |
My Car: 2010 Prius Model: III Package: #1 Thanks: 145
Friends: 20 | From Volume 1 of the Toyota Maintenance manual: P3120 - HV Transaxle Malfunction (with these subcodes)
Can you read out the sub-codes? They can point you to a specific area and/or connector and pins. Do you live in an area with a fair population of rodents? They seem to like chewing on wires. Bob Wilson |
| | #12 |
| Member Join Date: Oct 2009 Location: Vancouver BC
My Car: 2003 Prius Model: N/A Package: Base (Canada) Thanks: 5
Friends: 0 | Thanks Bob, I will be able to use those on mine before I get my manuals. I suspect the worst though because of the report of shuddering before it went. |
| | #13 | |
| Member Join Date: Jul 2009 Location: Modesto, Ca
My Car: 2001 Prius Model: N/A Package: Base - CA Thanks: 0
Yes I am more than frustrated! I keep it simple and short. I have a code P3120 on the 01 Prius. | |
| | #14 | |
One code left please God and Prius forum help me to alleviate my pain to get this headache Prius fixes | |
| | #15 | |
| | #16 | |
Friends: 44 | Quote:
You must have yet another story associated with that rusty front disc rotor and the front suspension. Its interesting that you felt refilling the inverter coolant loop was the hardest part of the job. I have experience replacing the coolant and would have characterized physically removing and replacing the transaxle as 40x harder... And you did this complete job 3x... techinfo.toyota.com has complete repair manual info including the electrical wiring diagrams. I think you are on the right track, looking for bad wiring. Good luck. Last edited by Patrick Wong; 10-27-2009 at 08:47 PM. | |
| | #17 | |
I got the wiring print out from Toyota dealer where i took the car there twice to have it scanned. Just now i recheck the wiring and it is definitely okay. I am suspecting the ECM. Read my post to Bob Wilson as i describe in detail of what i found today. Oh i know i am on the right track all right as there is nothing else. I had replaced and cleared all codes for battery pack, inverter, now it is still the transaxle left but i have the P3120 with ECM module not the transaxle itself on my scanner. It is time to ask Bob further. If you think about it that is very much it for the hybrid portion of this car battery pack, inverter, transaxle, ECM. These are the main 4 main modules of the Prius I bet it also applies to the 2nd and 3rd gen. with some minor change. Yep you were right i have a story to the rusty disc and bearing axle. Those came from the 98 Mercedes Benz E300 Turbo Diesel i bought and had it shipped from the East coast to California. Long story short i had a dealer that lied to me and sold it to me online. I ended up spendng 6 months fixing that car with the rear axle noise and 50% electrical problem not working. Yep i work on diesel too Mercedes and VW TDI'S. I bought and sold many VW Jetta, Beetle, Golf TDI'S and only a couple Mercedes diesel when i still was a dealer this year. I just folded up the business this month as i plan to move out of Ca by the end of this year 2009. Get to go to ask Bob about the Prius. Do you have any expertise you can help me with this 01? I still have the 03 Prius with even more codes than this one. One at a time at this point! | |
| | #18 | |
I went to check the wiring on the sensor today between the MG2 and the ECM. Wiring checked out okay with the the one that has 2 wires red/white and gray on it. I have noticed this pattern. Upon clearing the code and restart the car it ran fine with no code for about 5 minutes. After that code P3120 popped back on. My scanner keeps showing P3120 with ECM module showing when i click on the + on the scanner. I repeated the whole procedure and still same code. I had replaced everything else on this car except this thing. Is it safe to presume it is the ECM to be replaced? See attachment for the different ECM that i have. I notate on there so you know which one does what. I am tempting to swap with the 03 that i have but hold off until i have more info. I got a feeling it will do the same thing lit up the console but will not start the engine! That 03 Prius has problem with multiple codes at this point. I am trying to concentrate getting the 01 fixes first. What do you think before i order the correct ECM for this model year? More money spending on this car but I am very close to fixing it. I want to finish it. By the way this it not related to this issue but I finally took heart to take apart completely the battery pack of this car i replaced last year. I was irritating to see it sitting in my garage with the car still unrepair. See pictures. I had 3 weak cells and found a way to charge individual cell with radio control car battery charger. A bit too late had i known this info. last year i could had gone ahead and did this way instead of spending $1000 for a used battery pack. I am selling good individual cell and can show anyone how to take them apart and fix or replace bad subpack battery instead of the whole thing. Anyone interested let me know. Will save some big bucks if you have a battery pack for sure. | |
| | #19 | |
Friends: 20 | Quote:
From pp. DI-263 for MG2:
![]() Bob Wilson Last edited by bwilson4web; 10-28-2009 at 02:13 AM. | |
| | #20 |
Friends: 0 | Three "bad" transaxles would start hinting at me that the problem is nowhere near the transaxle. Have you taken a megger to all of your dead soldiers there, to check for winding problems? Have you looked at the resolver signals coming back at the ECU leads to make sure they're solid? When you replace one of these guys [and your efforts wrangling those heavy suckers are quite impressive, btw] it's very easy to damage the plastic connectors carrying the resolver and temp sensor wiring -- they're sensitive low-voltage things, they need to have NO flakiness back to the ECU. I don't know if your Autoenginuity can give you those info-codes correctly -- what version do you have, and have you asked their support folks about how specific they're able to get on the 01 - 03 Prius? This is one of the grey areas of aftermarket scantools, those bloody-annoying info-codes. . But it sounds like it's time for a good point-diagnosis rather than trying to parts-swap your way out of the problem... . _H* |
| car, problem |
| Is this going to be a problem? | gilmore753 | Gen II Prius Main Forum | 7 | 08-24-2008 08:48 AM |
| VSC problem | HardCase | Gen II Prius Technical Discussion | 6 | 08-01-2008 08:56 AM |
| Problem | SSimon | Gen II Prius Care, Maintenance and Troubleshooting | 21 | 02-08-2008 03:09 PM |
| Well there's your problem! | bsoft | Gen II Prius Main Forum | 32 | 07-18-2006 09:46 AM |
| Climate System Problem (Thought to be MFD Problem) | losaltosprius | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 03-17-2005 06:08 PM |
