This is a discussion on Reverse Beeps in 2007 within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Happy New Year. Got my 2007 Pkg 5 a few days ago, and am slowly being driven insane by the ...
Old 01-01-2007, 01:22 PM   #1
rstrack
Happy New Year. Got my 2007 Pkg 5 a few days ago, and am slowly being driven insane by the reverse beeps. I have tried the method found at Prius Chat with the ODO button, hold 10 seconds, power off, power on, etc., but no success. Is there some difference for the 2007's? Has anyone been successful in muting the reverse beeps in a 2007?
Thanks Green Acres
rstrack is offline
Old 01-01-2007, 01:46 PM   #2
scoot
<div class='quotetop'>QUOTE(Green Acres @ Jan 1 2007, 10:22 AM) [snapback]369264[/snapback]</div>
Thanks Green Acres
Hi. Yes, the fix works correctly in the 2007 model. Perhaps you are not following the directions exactly -- I found them a bit confusing the first time. Here are the directions that I am using:
Disabling Reverse Beep
• Power on the car, Cycle ODO/TRIP, stopping on ODO, Power off the car. (the ODO button next to the KM/MPH button)
• Power on, within 6 seconds, hold ODO for at least 10 seconds.
• While still holding ODO shift into Reverse and back into Park. (Yes, Reverse then press the Park button)
• b-on shows on speedometer display, press ODO to cycle to "b-off". (where the ODO display _was_, now you should have "b-on" or "b-off". Set it to b-off with the ODO button and then power the car off. Now when you turn on the car and put it in reverse, the annoying beep inside the car will not happen.
scoot is offline
Old 01-01-2007, 03:22 PM   #3
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 7
Be sure you're sitting on the driver's side.
It took me two tries before I got it off.
Godiva is offline
Old 01-02-2007, 11:11 AM   #4
klevitsky
The first step may be somewhat confusing too, even if your car is already on ODO when you power it on in step 1, you still have to cycle through the Trip A, Trip B and then stop on ODO.
I have done this successfully on first try in my 2007.
klevitsky is offline
Old 01-02-2007, 11:40 AM   #5
daveleeprius
Heh heh heh you think so?
It took me two tries on my 2007 as well, but so glad it's gone. Was driving me batty. Now I wonder if when I take the car in later this year for the first oil change (six months coming up in March) if it will get reset by the dealer?
Dave
daveleeprius is offline
Old 01-02-2007, 09:04 PM   #6
jdom41
Thanks Scoot for the "backup" beep fix. It worked fine on my new 07 today altho it took a couple of tries to get the hang of it.
Schnozz
jdom41 is offline
Old 01-05-2007, 11:00 AM   #7
svbb
svbb's Avatar
GREAT tip--I got it on the second try. Thanks, scoot, for the concise instructions!
svbb is offline
Old 01-07-2007, 12:46 PM   #8
scoot
<div class='quotetop'>QUOTE(SteveB @ Jan 5 2007, 08:00 AM) [snapback]371246[/snapback]</div>
You're welcome. The instructions are concise because I got it wrong the first few times myself, although the instructions I was reading were correct. I just needed more detail.
scoot is offline
Old 02-20-2007, 07:41 PM   #9
jobob
Post
Thanks Scoot, Well I won't admit how many times it took me, BUT the annoying beep is gone. Thanks!!
jobob is offline
Old 02-21-2007, 02:19 AM   #10
mrjpaterson
<div class='quotetop'>QUOTE(scoot @ Jan 7 2007, 12:46 PM) [snapback]372090[/snapback]</div>
I'm going to try this tomorrow! It works on all models, then? I hope it won't be as frustrating as the garage door opener that took me three days to finally get right. (Turns out that in Canada cycling off and on very two seconds the transmitter means to actually press and hold the button for two seconds, then to rapidly press again--kind of contrary to how I would've used it to open the door, but oh well...)
James
mrjpaterson is offline
Does anyone know *why* the Prius beeps in reverse? teyde Gen II Prius Technical Discussion 34 04-24-2009 03:16 PM
How to Silence Reverse Beeper 2007 ? dorf Gen II Prius Main Forum 3 07-14-2008 02:54 PM
3 Beeps? Renocat Gen II Prius Main Forum 12 09-11-2006 11:26 AM
Reverse Beeps and JBL wilco Gen II Prius Audio and Electronics 8 11-03-2005 03:53 PM
