Understanding NiMH hypercycles (to prolong Prius HV battery life)
My Car: 2006 Prius Model: Package: #3 Thanks: 1,273
Friends: 82 | ![]() What is hypercycle? Hypercycle is a technique to use a rechargeable NiMH battery to extend it's life cycle and maximize overall usage. Example: 10% Depth of Discharge x 300,000 cycles = 3,000,000 overall percentages 60% Depth of Discharge x 10,000 cycles = 600,000 overall percentages The difference is 5 times more in overall usage. How do I hypercycle NiMH battery? The short answer is to use it a little at a time. As the graph above shows, you would get about 700 cycles if you use 100% at a time. This means you charge it fully and draining it until empty. Isn't it how you use those rechargeable AA NiMH batteries? Yes, the worst possible way and now you know. If you discharge it at 60%, NiMH would be good for 10,000 cycles! That's more than 27 years if you use one cycle every single day! This gets better with 50% depth of discharge as it would double the cycles to 20,000. A little dirty secret NiMH battery charger and rechargeable battery manufactures don't want you to know. How does Prius use the NiMH traction battery? Prius normally uses less than 10% at a time. It is also known as one hypercycle. Prius HV battery is used when the gas engine is inefficient and therefore unlike an electric vehicle, no more than 10% is usually used at a time. This understanding enables NiMH to last 300,000 cycles! Toyota has warranty for 10 years or 150,000 miles on the pack. This means, Toyota believes an owner will average 2 HV cycles per miles. If an owner averages 1 HV cycle per mile, the HV battery pack would last 300,000 miles! If an owner drives mostly highway and use only 0.5 HV cycle per mile, it should last 600,000 miles! See below link for more: http://sites.google.com/site/usbseaw...h-of-discharge I finally got some time to write up what I learned and studied about NiMH over 5 years. I came up with term "hypercycling" to easily explain why Prius battery would last a very long time to those acquiring minds new to hybrids. I am sharing information here to learn from many knowledgeable people. I am no expert but the information is what I believe to be accurate from my experience. Feel free to contribute your thoughts.
__________________ Green minds thrive in the Prius family. Hybrid Synergy Drive is the engine of change that moved us forward. Luxury: Sherwood Dash Kit | Bartlett Leather Seats | Kenwood DNX6960 Performance: Kyowa KR206 17" Black Chrome Lips | Tanabe Strut Tower Bar Audio: Infinity 6020CS Front | Kappa 62.7i Rear | BASS600 Subwoofer | B-Quiet Ultimate Lighting: Morimoto Mini H1 Projectors | LED Interior+License Plate Others: EV Button | Torque (Android OBDII App) |
| Thanked by 21 Users: | 2009Prius (07-09-2009), andyprius (08-08-2010), Angelfish01 (09-22-2010), bythesea (11-29-2009), DaveinOlyWA (07-09-2009), devious1 (07-09-2009), djasonw (07-10-2009), eco-geek (03-05-2010), fredthepostman (07-10-2009), Fred_H (07-09-2009), GrumpyCabbie (03-04-2010), jdcollins5 (03-03-2010), ksstathead (03-03-2010), northwichita (07-13-2009), Pr10pilot (08-21-2010), Presto (03-04-2010), priuslaw (07-10-2009), seilerts (02-17-2011), Spartane (07-18-2009), Staska (12-07-2011), Tideland Prius (01-17-2012) |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 203
Friends: 14 | great info and pretty much the way lead acid batteries works which leads to the " great lie" EV car manufacturers are perpetuating. my EV was supposed to have a range up to 40 miles well that was at 25 mph. that was too slow, so i had the thing reset to do 35 mph. well, that dropped the range to just under 30. that was ok, but soon realized that my batteries were starting to fail and that happened in less than a year. batteries replaced, started charging at work so now, i rarely use more than 50% of my charge before recharging. so far so good. Li does not have the charge life issues, only the cost issues. not putting any more money into the Zenn, holding out for a highway capable EV that will do at least 100 miles
__________________ My Blue 2010 : Last tank 506.9 @ 47.8 pump (53.0 MFD) 8.29 CPM, Lifetime:37,908.7 miles MPG pump. 50.02 (55.12 MFD) 6.58 CPM. Summer MPG 53.79 Winter: 47.71 My 2011 Nissan Leaf this week; 312.3 miles; LT; 16,126.7 miles @2.65 CPM. (2.17 MTD) fuel cost; weekly $6.87 Lifetime $427.95 If my Prius was a Leaf; last fillup would have been $11.04 instead of $42.00 ( $2.17 cents per mile) |
| A Wimpy DIYer Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: N/A Package: #2 Thanks: 678
Friends: 22 | So I suppose it is bad for the battery life to run it down to 3 to 4 bars as opposed to keeping it at 6 bars? |
Friends: 14 | Quote:
10% can also mean running from 70% to 60% which i think you will find is just about where your Pri spends most of its time. on a Pri... well, at least on the classics, 8 bars is 80%, zero bars is 40 %... running between 6 bars to 3 bars is probably around a 15% change give or take. | |
Friends: 60 | This seems to support the notion that owners who live in mountainous terrain can expect shorter traction battery life. I live at 1,100 ft elevation and have had two battery failures (thankfully covered under the hybrid system warranty) out of three Toyota hybrids. The 2004's battery hasn't failed yet but it cycles daily from eight green bars down to two red bars. The SOC is moving up and down more quickly than in the past, which implies reduced battery capacity. |
| Thanked by 2 Users: | GrumpyCabbie (03-05-2010), ksstathead (03-03-2010) |
| Senior Member Join Date: Jul 2009 Location: Colorado
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 10
Friends: 0 | So for those of us who are not the science types and not the math types, and who are new or recently new to Hybrids & Prius specifically, what does this mean in terms of our everyday driving? At lower speeds, say 40 mph and below, can we effectively control the battery discharge? I think this is different from controlling the point in acceleration when the gas engine engages by aggressive take-offs, jack-rabbit starts, or other fuel inefficient practices. Thanks, TK |
Friends: 82 | Quote:
My calculation indicates that 10 seconds of battery acceleration (near threshold) uses 5% of the pack. It is almost as hard on the pack as doing 0-60 floored acceleration. To understand how many percent each block of the battery represent on the MFD, see the graphs below from Wayne Brown's site. More information with scenarios are available in the link I provided in my original post. ![]() | |
| Senior Member Join Date: Dec 2009 Location: chicago
My Car: 2010 Prius Model: III Package: Base Thanks: 23
Friends: 0 | Any comment/updates on how the above information on prolonging battery life applies to the Gen 3? |
Friends: 82 | The same should apply for 2010 Prius. EV mode was made available from factory but Toyota put in more restrictions to prevent unintended abuse. |
| Thanked by: | jdcollins5 (03-03-2010) |
Friends: 14 | so by limiting EV mode to max 25 mph, i guess we now know the max safe amperage levels...so how much would that be for Gen 2 owners who can monitor that? |
| battery, hypercycles, life, nimh, prius, prolong, understanding |
| 2nd Nimh battery pack | toyotechwv | Prius PHEV Plug-In Modifications | 30 | 05-14-2009 06:09 PM |
| Next Gen Prius to have 67% larger NiMH battery with 71 MPG (vs. 50 MPG current Gen) | usbseawolf2000 | Prius, Hybrid, EV and Alt-Fuel News | 18 | 07-28-2008 03:54 PM |
| Nimh HV battery and discharge 40 amps | Flying White Dutchman | Gen II Prius Technical Discussion | 16 | 07-27-2008 01:29 AM |
| Does donating blood prolong your life? | burritos | Fred's House of Pancakes | 31 | 08-18-2007 12:37 AM |
| document on what % of the NiMH battery is recyclable | cwerdna | Gen II Prius Main Forum | 1 | 07-04-2006 11:08 PM |
