| This is a discussion on [ KB ] How to eliminate Reverse Beep & Seatbelt Beep within the Knowledge Base Articles Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Category: 4 Known Issues Type: Modifications Article Name: How to eliminate Reverse Beep & Seatbelt Beep Author: AdminCoop Description: Step ... |
| Admin/Founder Join Date: Nov 2003 Location: Charlotte, NC
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 38
Friends: 37 | Category: 4 Known Issues Type: Modifications Article Name: How to eliminate Reverse Beep & Seatbelt Beep Author: AdminCoop Description: Step by step instructions on how to eliminate the Reverse & Seatbelt Beeps >>Read Full Article
__________________ Follow PriusChat on and ![]()
Extended Warranty - $1055 : Pre-Paid Maintenance - $875 |
| The Following User Says Thank You to Danny For This Useful Post: | Leadfoot (06-11-2009) |
Friends: 0 | There is one caveat to this procedure. No one can sit in the passenger seat while attempting to complete this task. A funny story: This weekend my wife and I decided to turn off the beeper. We like to support each other and do things together. So I would touch the buttons from the driver's seat while she read the directions to me from the passenger's seat. Each time we tried to turn off the beeper "b-on" would never appear. We tried it at least 6 times. Then she got out of the car to do something else and the directions worked perfect. Except I didn't know how to change the setting - she was reading the directions and left. I got all excited and called her back to show her that it worked. She sat in the seat and it didn't work. I tried a couple of more times and then realized - it might not work when someone is sitting in the passenger seat. Sure enough, when she got up it worked again. Howie |
| Senior Member Join Date: Jan 2004 Location: Vancouver, WA (near Portland)
Friends: 0 | That explains why it didn't work the first time I tried it, too. I had some books on the seat! Thanks for the info! |
| Senior Member Join Date: May 2004
Friends: 0 | Wouldn't it be much simpler if the screen had a settings menu in which you could turn the beep on or off? I can't believe that Toyota would make a simple procedure so complex, especially in a car equipped with four computers and an LCD screen. |
Friends: 0 | Like the previous reply my wife and I were both in the car and finally after dozens of attempts she suggested we try it with the emergency brake on - low and behold the elusive "b on" appeared! We were then able to disable the annoying beeping!! She was sitting in the passenger's seat when we disabled the beeper. |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 215
Friends: 18 | Brian and I were helping someone disable their reverse beep at the Sierra Club event. We couldn't seem to get it done together, but when Brian went to his car to do it alone, it worked in his. I then moved from the passenger seat to the driver's seat, and of course it then worked. In the cars we were trying it in, the passenger seat needed to be unoccupied. Last edited by HTMLSpinnr; 03-24-2009 at 07:13 PM. |
Friends: 0 | While the recipe for disabling the back-up beeper worked great in my car, when I tried doing it for a friend in her car, it wouldn't work. (She was sitting in the passenger seat, I in the driver's seat.) For kicks and out of desperation, we fastened our setabelts and then performed the sequence and voila, it worked. I honestly don't know whether she had the emergency brake engaged or not. |
Friends: 0 | I cant get this to work in a brand-new european prius. Belt warning does work however, so i seem to be close. What happens is that when i release the odo button the odo readout will roll over to odoA Any more clues ? Peter |
| Senior Member Join Date: Mar 2004 Location: Seattle, WA
Friends: 0 | I'm renting a Prius this weekend (Know Thy Obsession). Besides being an education for myself, it's the first time my partner has had a chance to ride in a Prius. Last evening, I was about to back into a parking space; I turned to her and said, "You're not going to like this." And then, of course, BEEP-BEEP-BEEP. I parked, and she looked at me and said, "Can you turn this off?" I replied to the affirmative, at which point she said, "Good -- 'cause that noise would drive me crazy when I get one of these!" ...It's a very addictive car.
__________________ "Have you ever noticed.... Anybody going slower than you is an idiot, and anyone going faster than you is a maniac?" -- George Carlin</span> Jeff Meyer <span style=\'color:green\'>Tideland '05 AM Package, 12 November 2004 |
| beep, eliminate, reverse, seatbelt |
| Is disabling reverse/seatbelt beep reversible? | acousticbiker | Gen II Prius Main Forum | 4 | 07-08-2006 11:54 PM |
| Disabling reverse beep/seatbelt beep on an 06' | Paradox | Gen II Prius Main Forum | 31 | 05-30-2006 10:53 PM |
| Seatbelt Beep on/off | Tideland Prius | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 12-22-2005 04:44 PM |
| Eliminate the Beep in the UK | kenninuk | Knowledge Base Articles Discussion | 1 | 07-15-2005 11:37 AM |
| Disabling the reverse beep (and seatbelt beep) | dougkm | Gen II Prius Main Forum | 1 | 12-01-2003 07:42 AM |
