| This is a discussion on Toyota to release 2 different Prius-es to US & Europe within the Prius and Hybrid News forums, part of the News & Newbies category; Bob, I am not an engineer but the way I vision the 1.8l could be utilized to generate more power ... |
| View Poll Results: How many more MPGs will the EU Prius have to get for you to want to import one? | |||
| 5 MPGs and I'm taking a European vacation | | 1 | 1.35% |
| 10 MPGs and I'll push it on the boat myself | | 9 | 12.16% |
| I just think Toyota's making a mistake with a larger engine while sacrificing MPGs | | 50 | 67.57% |
| Import? No thanks, I want the power! | | 14 | 18.92% |
| Voters: 74. You may not vote on this poll | |||
| | LinkBack (23) | Thread Tools |
| | #81 |
Friends: 59 | Bob, I am not an engineer but the way I vision the 1.8l could be utilized to generate more power without the partial power or pumping loss is described below: To make the point across easier, I am going to make up some numbers. Let's say the current 1.5l Atkinson cycle ICE use the whole 1.5l displacement when the gasoline ignites and expands as the pistons move. However, during the compression cycle, some of the gas goes back into the manifold (say 0.5l) and when it is closed, only 1.0l of air and fuel got compressed. This is why Prius has much higher compression ratio (13:1) than a non-hybrid car with an Otto cycle. Remember, Prius ICE is not turbo/supercharged and it runs on 87 Octane regular gas without knocking. Toyota has a better explanation with pics and graphs. Now, going to 1.8l ICE.... If we use the whole 1.8l during the expansion cycle and compress only 1.0l (hence 0.8l back in the manifold), you are extracting more energy by allowing the piston to travel further upon the ignition. In that explanation, I see the 1.8l ICE making 15kW almost efficient as the current 1.5l ICE. The benefit of having 1.8l ICE is to make more power and less noise at the output people normally use. In summary, 1.8l can be used to further increase the ratio of the expansion cycle.
__________________ Prius shaped the form of future cars. Hybrid Synergy Drive is the engine of change that moved us forward. Kyowa KR206 17" Black Chrome Lips | Sherwood Wood Dash (Birds Eye) | Infinity 6020CS Front | Kappa 62.7i Rear | B-Quiet Ultimate | LED Interior+License Plate | EV Button | Auterra Dyno Scan | Professionally Self-Installed Leather Last edited by usbseawolf2000; 01-08-2009 at 03:07 PM. |
| | #82 | |
| Senior Member Join Date: Sep 2005 Location: Outer Banks of NC.. Work in SE Virginia
My Car: 2005 Prius Model: Package: #4 Thanks: 13
Friends: 2 | Quote:
In NA with greater distances and less traffic density the speeds are relatively higher for longer distances. It's nothing to go on a trip here for 1000 miles at 75-80 mi. I don't have a scanguage to monitor the data but if the Prius pulls 15 kW at steady state cruising at 60 which in my view is the sweet spot for this Gen 2, then what is the demand at 75 or 80 mph? | |
| | #83 | |
| Member Join Date: Jun 2006
If the 1.8L has a similar expansion ratio to the 1.5L then at low power outputs it will be less efficient (even the 1.5L efficiency drops below about 12-15KW output that is needed for low to moderate speeds). kevin | |
| | #84 |
| http://prius-pt.com - Portugal Join Date: Jan 2008 Location: Moita, Portugal
My Car: 2006 Prius Model: Package: T Spirit Thanks: 69
Friends: 5 | OK guys, I was asked secrecy from the local Press Officer here in Portugal about this but I was just informed that at least one of our dealers is already spreading the word among its customers so no more reasons for keeping it under cover: EUROPE WILL GET EXACTLY THE SAME 1.8 LITRE ENGINE AS THE USA MARKET According to this salesperson the presentation in Portugal is scheduled for June 11th, and a selected group of customers should have a gathering shortly after to do some test driving. So there you go, Toyota changed its mind and decided to go for one single engine all over the world. The equipment and accessories will differ from market to market as usual, but the engines and MGs will be the same all over. Last edited by jprates; 01-08-2009 at 06:56 PM. |
| | #85 |
Friends: 1 | am i the only one to notice that the new prius looks more like a honda, and the new honda looks more like a prius? ill probably wait until 2012 to get another one, just because that is how much i have left on my financing however if i can get nav and the sunroof and the touring for less then say 26,000 i might trade in. |
| | #86 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Quote:
The 1.5L engine seems to lose efficiency above 2,600 rpm and really tanks above 4,100 rpm (NHW11 testing.) If the 1.8 L. engine can avoid excursions into these areas, producing diesel-like efficiencies at higher power levels, it will shine on the high speed benchmarks and acceleration loads. Remember the mileage tests involve dictated speed changes and excursions into higher rpms drives the engine into worse thermodynamic efficiency regions. A slower turning, larger displacement engine can produce enough power and minimize excursion into inefficient regions. One of the clever aspects of both input and output valve timing and phase management is the ability to implement a stealthy exhaust gas recirculation. What this does is help keep the engine effective expansion ratio up at variable power levels. This can be a clever way to keep emissions low while maintaining efficiency across a broad power band. What I'm hoping to hear there is a higher speed, EV mode. The current 42 mph is just under the EU "extra urban" speed for over half of the test. If the EV mode can be higher than this limit, the vehicle should test with outstanding mileage. It will also look better on the USA tests. We might even see a return of the "real mileage is worse" claims but I won't mind. Bob Wilson | |
| | #87 | |
Friends: 5 | Quote:
Take a look at post #24 on this thread. The bigger 1.5L 2004 Prius ICE takes a lot more time to warm-up compared with the smaller 1.3L 2009 Insight ICE, and the Insight wins the ECE15 test. This happens because the ECE15 includes the warm-up time during its execution and there is no way a Prius can warm up in only 200 seconds that the test takes. The ICE is almost always running and you never reach stage 5 of the hybrid system. An even bigger engine will do a lot worse IMHO. I expect the 1.8L to do worse or the same at best than the present 1.5L block, but win easily on the NEDC (mixed circuit cycle). Do you agree with this analysis? | |
| | #88 |
Friends: 5 | Sorry Bob, post #24 is from another thread, here: Leaked document reveals Honda Insight mpg & CO2 |
| | #89 | |
I do not seem to have the cool down issue in pulse and glide in cold weather with the grill block I am using. I have one 9 inch long grill slot opening in front of the transmission. The rest are blocked off. Temps here have been in the teens to mid twenties during commute time. Even with this configuration, I only pulse the heater on briefly as it pulls the engine temp below 80 C if I were to run it continuously. The real solution to winter heat is not to use the engine as a furnace, as its inefficeint at that. But to make an actual furnace and run it off gasoline. | |
| | #90 | |
| Senior Member Join Date: Sep 2005 Location: Eastern Europe
Friends: 1 | you guys need to read about gas recirculation in new RX450h, where they managed to cut off warm up by 15 minutes in -5C Quote:
Also, I am pretty sure that ECE tests do not test vehicle in cold conditions? I believe the difference in city mileage should come from increased engine shut-off, same as in Ford Fusion, which is more aggresive than in previous hybrids, of course as well as with having smaller engine and smaller vehicle. | |
| europe, priuses, release, toyota |
| Watchout Toyota! VW, Audi (and maybe Porsche) aim to release Li-Ion batteries in 2010 | Rybold | Prius and Hybrid News | 17 | 11-19-2008 11:21 AM |
| Toyota to produce iPod Integration Kit...in Europe | gwelgrin | Gen II Prius Audio and Electronics | 0 | 05-18-2007 08:15 PM |
| Connectors and wiring info for non-Toyota GPS install in 2005 Prius (Europe) | Solar Hydro | Gen II Prius Audio and Electronics | 5 | 09-19-2006 07:56 PM |
| 2007 Toyota Prius Press Release (8/17/06) | Vegemann | Gen II Prius Main Forum | 1 | 08-19-2006 06:32 PM |
| Toyota brings forward PHEV release date | clett | Prius and Hybrid News | 12 | 07-31-2006 03:11 PM |
