| This is a discussion on 2010 Prius news from Detroit - published on Jan 13th ??? within the Prius and Hybrid News forums, part of the News & Newbies category; Note from Danny: Images & link removed per Toyota's request. Toyota's official press images will be available in a little ... |
| | LinkBack (10) | Thread Tools |
#1 |
My Car: 2010 Prius Model: N/A Package: G Thanks: 37
Friends: 11 | Note from Danny: Images & link removed per Toyota's request. Toyota's official press images will be available in a little over 12 hours and I am pleased to announce that you'll be able to view the 2010 Prius reveal LIVE here on PriusChat via streaming video. We all appreciate the enthusiasm that the community is showing and hope that you'll join us at 11:30am EST tomorrow morning. Danny Last edited by Danny; 01-11-2009 at 08:51 PM. |
| resident lab rat Join Date: Mar 2005 Location: south of lake Michigan
Friends: 26 | i will trust you on the translation ooh, they have an article on the is-f too. wish i could read japanese! |
| Toyota Fanatic Join Date: Jul 2008 Location: Sacramento, California
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 23
Friends: 4 | Great picture, that is my color choice for my 2010 and now its my wallpaper I just ran the link through Babblefish and it shows a "Pre crash safety system" " ultra high frequency radar system " wow! that must be the lens that we saw in the windshield I just figured out that Babblefish is translating Prius as Pre-Mortar I found info on the pre-crash safety system here: http://www.autonews24h.com/Auto-Indu...News/2455.html Last edited by rcsting; 01-10-2009 at 12:07 AM. |
Friends: 4 | Here is part of the article regarding the display but it is tough to figure out the translation but its another "worldwide first" The cockpit which actualizes high visibility operativity e.g., the worldwide first “touch tracer display” which indicates the place where the ▽ finger touches in center meter is adopted, To 3.進 the basic efficiency which is converted Last edited by rcsting; 01-09-2009 at 11:30 PM. |
| hybrid car with a hybrid seat Join Date: Apr 2008 Location: NorCal
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 70
Friends: 4 | This car will sell very well. I'm interested to see the new combined horsepower, curb weight, passenger/cargo weight limit capacity, dimensions, fuel economy, and emissions index. I would imagine the lights just above the fog lights are daytime running lights (DRL). Last edited by cycledrum; 01-09-2009 at 11:38 PM. |
| Member Join Date: Sep 2008 Location: Sydney
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 1
Friends: 0 | What's MG2 reduction gears? |
My Car: 2004 Prius Model: Package: #9 Thanks: 57
Friends: 27 | that picture does not have the headlight washers. |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 25
Friends: 11 | |
Friends: 11 | In translation is says more such as: "altogether vehicle such as decrease of the electric power consumption with the LED conversion of the lamps with the multiplier effect of improvement of energy efficiency" "fuel economy efficiency of worldwide highest level and 2.4L Actualizing the power efficiency like the car" "The Toyota first “solar ventilation system which uses the electric power which generates electricity with the solar panel which is loaded onto the ▽ moon roof, ventilates the interior” With the switch of the ▽ smart key, from the external air conditioner operation the worldwide first “remote air conditioner system which is possible”" "As the wide interior space is created with the thin-shaped conversion and the like of the ▽ front seat seat back, by the fact that miniaturization, and arrangement of the hybrid battery are modified, luggage capacity from the current model car approximately 30L enlargement The ▽ pre- crash safety system (ultra high frequency radar system) in addition to new setting, pursuing class *3 top-level safe efficiency e.g., S-VSC and 7 SRS air bags, active headrest (the driver's seat suicide seat) it equips, With the second look at the ▽ platform, as smooth riding comfort, the straight advancing stability where at high speed is superior is actualized, actualizing the silent characteristic which excels by the fact that the acoustic material damping material is arranged effectively in the high rigid body" Wow, babel fish really brings meaning to lost in translation Just did the conversion and the 30L enlargement of the 'trunk' works out to 1.05 cubic feet. Last edited by Paradox; 01-10-2009 at 09:00 AM. Reason: did conversion |
Friends: 0 | Hi nameless..., In the original THS/HSD Prius drive train the MG2 (torquer motor) rotor was directly coupled with the ring gear of the PSD. The motor and ring gear turned at the same speed. This requires a large heavy MG2, which is why the Prius leans a little to the left. In later HSD systems, starting with the RX400h the ring gear was made a tube, and a secondary planetary gearset was added on the far end of the ring gear (away from the PSD planetary gear set that couples the ring gear, engine and MG1). The motor rotor communicates to that second planetary gear set. The advantage is that you can have a smaller diameter, lighter weight motor, with the same power (by spinning at a higher RPM which is possible because its smaller in diameter), and the torque gets multiplied up through the secondary planetary gear set. They seem to also be able to do away with the chain drive from the ring gear to the axle in these configurations, although I do not know if that is the case with the new Prius. This makes for a smaller overall transmission package. |
| 13th, 2010, detroit, jan, news, prius, published |
LinkBack to this Thread: http://priuschat.com/forums/prius-hybrid-news/57277-2010-prius-news-detroit-published-jan-13th.html | ||||
| ????????: ???????? | This thread | Refback | 09-13-2009 02:22 AM | |
| First Air Conditioned Car, Compressed Air Car France, Convert Your Car To Compressed Air - Automotiverotisseriee | This thread | Refback | 03-14-2009 04:52 AM | |
| ????????: ???? | This thread | Refback | 02-07-2009 08:09 PM | |
| ????? | This thread | Refback | 02-01-2009 08:11 AM | |
| ????? | This thread | Refback | 01-18-2009 10:33 PM | |
| ????? | This thread | Refback | 01-15-2009 09:17 AM | |
| ????????: ????????????? | This thread | Refback | 01-13-2009 08:03 AM | |
| ????。Japanese Green Cars: News on new Prius from Gazoo | This thread | Refback | 01-11-2009 05:14 AM | |
| ????。Japanese Green Cars | This thread | Refback | 01-10-2009 09:01 PM | |
| Uuden Priuksen tiedot julki - Suomi24 Keskustelu | This thread | Refback | 01-10-2009 05:14 PM | |
| BREAKING NEWS! 2010 Prius Photos posted on PriusChat First! Confirmed real! | Danny | Prius and Hybrid News | 182 | 04-23-2009 11:14 PM |
| All-new 2010 Prius to Debut at Detroit Show | clett | Prius and Hybrid News | 27 | 12-15-2008 08:30 PM |
| Automotive News say 2010 Prius will be..... | edwjmcgrath | Gen III 2010 Prius Main Forum | 32 | 08-24-2008 06:35 PM |
| Prius vs. Honda Civic Hybrid by the Detroit News | bookrats | Other Cars | 0 | 05-05-2004 03:40 PM |
| NEWS: Detroit reporter view on Prius vs. Silverado Hybrid | Atoyot | Gen II Prius Main Forum | 7 | 02-19-2004 06:34 PM |
